FilteredComplex.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clément Maria
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
17{
19 typedef unspecified Simplex_handle;
23 typedef unspecified Filtration_value;
24
28 typedef unspecified Indexing_tag;
29
35 size_t num_simplices();
43
47 Simplex_handle simplex ( size_t idx );
52typedef unspecified Boundary_simplex_iterator;
57typedef unspecified Boundary_simplex_range;
58
70
75typedef unspecified Filtration_simplex_iterator;
79typedef unspecified Filtration_simplex_range;
84
91 typedef unspecified Simplex_key;
110//typedef unspecified Complex_simplex_iterator;
111//typedef unspecified Complex_simplex_range;
112
113/*
114* Returns a range over all the simplices of a
115* complex.
116*/
117//Complex_simplex_range complex_simplex_range();
118
119/*************************************************/
128//int is_before_in_filtration(Simplex_handle s, Simplex_handle t);
129/*************************************************/
130
131};
The concept FilteredComplex describes the requirements for a type to implement a filtered cell comple...
Definition: FilteredComplex.h:17
Iterator on the simplices belonging to the boundary of a simplex.
Definition: FilteredComplex.h:52
Iterator over all simplices of the complex in the order of the indexing scheme.
Definition: FilteredComplex.h:75
Range giving access to the simplices in the boundary of a simplex.
Definition: FilteredComplex.h:57
Data stored for each simplex.
Definition: FilteredComplex.h:91
Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
void assign_key(Simplex_handle sh, Simplex_key n)
Store a number for a simplex, which can later be retrieved with key(sh).
Simplex_handle null_simplex()
Returns a Simplex_handle that is different from all simplex handles of the simplices.
Filtration_simplex_range filtration_simplex_range()
Returns a range over the simplices of the complex in the order of the filtration.
Handle to specify a simplex.
Definition: FilteredComplex.h:19
Simplex_key null_key()
Returns a constant dummy number that is either negative, or at least as large as num_simplices()....
Range over the simplices of the complex in the order of the filtration.
Definition: FilteredComplex.h:79
Simplex_key key(Simplex_handle sh)
Returns the number stored for a simplex by assign_key.
Type for the value of the filtration function.
Definition: FilteredComplex.h:23
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Specifies the nature of the indexing scheme.
Definition: FilteredComplex.h:28
Simplex_handle simplex(size_t idx)
Returns the simplex that has index idx in the filtration.
Boundary_simplex_range boundary_simplex_range(Simplex_handle sh)
Returns a range giving access to all simplices of the boundary of a simplex, i.e. the set of codimens...
Returns the number of simplices in the complex.
