Concept for the template class passed for Skeleton_blocker_complex. Most importantly, it contains the nodes for vertices and edges (Graph_vertex and Graph_edge) that are stored in the simplicial complex. The user can redefine these classes to attach additional information to vertices and edges.
More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/concept/Skeleton_blocker/SkeletonBlockerDS.h>
typedef int | boost_vertex_handle |
| | index that allows to find the vertex in the boost graph
The documentation for this struct was generated from the following file:
- /home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/concept/Skeleton_blocker/SkeletonBlockerDS.h
