Gudhi::skeleton_blocker::SkeletonBlockerDS::Root_vertex_handle Struct Reference
Root_vertex_handle and Vertex_handle are similar to global and local vertex descriptor used in boost subgraphs and allow to localize a vertex of a subcomplex on its parent root complex. More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/concept/Skeleton_blocker/SkeletonBlockerDS.h>
Detailed Description
In gross, vertices are stored in a vector and the Root_vertex_handle and Vertex_handle store indices of a vertex in this vector.
For the root simplicial complex, the Root_vertex_handle and Vertex_handle of a vertex are the same.
For a subcomplex L of a simplicial complex K, the local descriptor, ie the Vertex_handle, of a vertex v (that belongs to L) is its position in the vector of vertices of the subcomplex L whereas its Root_vertex_handle (global descriptor) is the position of v in the vector of the vertices of the root simplicial complex K.
Examples
Skeleton_blocker_link.cpp.
The documentation for this struct was generated from the following file:
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:28 for GUDHI by Doxygen 1.9.2
