Simple traits that is a model of SkeletonBlockerDS and can be passed as a template argument to Skeleton_blocker_complex.
More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Skeleton_blocker/Skeleton_blocker_simple_traits.h>
| struct | Root_vertex_handle |
| | Global and local handle similar to boost subgraphs. Vertices are stored in a vector. For the root simplicial complex, the local and global descriptors are the same. For a subcomplex L and one of its vertices 'v', the local descriptor of 'v' is its position in the vertex vector of the subcomplex L whereas its global descriptor is the position of 'v' in the vertex vector of the root simplicial complex. More...
typedef int | boost_vertex_handle |
| | index that allows to find the vertex in the boost graph
The documentation for this struct was generated from the following file:
