Simple traits that is a model of SkeletonBlockerGeometricDS and can be passed as a template argument to Skeleton_blocker_geometric_complex.
More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Skeleton_blocker/Skeleton_blocker_simple_geometric_traits.h>
| typedef GeometryTrait | GT |
| typedef GeometryTrait::Point | Point |
typedef int | boost_vertex_handle |
| | index that allows to find the vertex in the boost graph
template<typename GeometryTrait>
struct Gudhi::skeleton_blocker::Skeleton_blocker_simple_geometric_traits< GeometryTrait >
- Examples
- Garland_heckbert.cpp.
The documentation for this struct was generated from the following file:
