Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ > Class Template Reference
Tangential complex data structure. More...
#include <gudhi/Tangential_complex.h>
Classes
struct  Fix_inconsistencies_info
 Type returned by Tangential_complex::fix_inconsistencies_using_perturbation. More...
struct  Num_inconsistencies
 Type returned by Tangential_complex::number_of_inconsistent_simplices. More...
Public Member Functions
template<typename Point_range >
 Tangential_complex (Point_range points, int intrinsic_dimension, const K &k=K())
 Constructor from a range of points. Points are copied into the instance, and a search data structure is initialized. Note the complex is not computed: compute_tangential_complex must be called after the creation of the object. More...
 ~Tangential_complex ()
 Destructor.
int intrinsic_dimension () const
 Returns the intrinsic dimension of the manifold.
int ambient_dimension () const
 Returns the ambient dimension.
Point get_point (std::size_t vertex) const
 Returns the point corresponding to the vertex given as parameter. More...
Point get_perturbed_point (std::size_t vertex) const
 Returns the perturbed position of the point corresponding to the vertex given as parameter. More...
std::size_t number_of_vertices () const
 Returns the number of vertices.
void compute_tangential_complex ()
 Computes the tangential complex. More...
Fix_inconsistencies_info fix_inconsistencies_using_perturbation (double max_perturb, double time_limit=-1.)
 Attempts to fix inconsistencies by perturbing the point positions. More...
Num_inconsistencies number_of_inconsistent_simplices (bool verbose=false) const
template<typename Simplex_tree_ >
int create_complex (Simplex_tree_ &tree, bool export_inconsistent_simplices=true) const
 Exports the complex into a Simplex_tree. More...
void set_max_squared_edge_length (FT max_squared_edge_length)
 Sets the maximal possible squared edge length for the edges in the triangulations. More...
Detailed Description
template<typename Kernel_, typename DimensionTag, typename Concurrency_tag = CGAL::Parallel_tag, typename Triangulation_ = CGAL::Default>
class Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >
The class Tangential_complex represents a tangential complex. After the computation of the complex, an optional post-processing called perturbation can be run to attempt to remove inconsistencies.
Template Parameters
Kernel_requires a CGAL::Epick_d class, which can be static if you know the ambiant dimension at compile-time, or dynamic if you don't.
DimensionTagcan be either Dimension_tag<d> if you know the intrinsic dimension at compile-time, or CGAL::Dynamic_dimension_tag if you don't.
Concurrency_tagenables sequential versus parallel computation. Possible values are CGAL::Parallel_tag (the default) and CGAL::Sequential_tag.
Triangulation_is the type used for storing the local regular triangulations. We highly recommend to use the default value (CGAL::Regular_triangulation).
Examples
example_basic.cpp, and example_with_perturb.cpp.
Constructor & Destructor Documentation
◆ Tangential_complex()
template<typename Kernel_ , typename DimensionTag , typename Concurrency_tag = CGAL::Parallel_tag, typename Triangulation_ = CGAL::Default>
Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::Tangential_complex ( Point_range  points,
const K &  k = K()
inline
Parameters
[in]pointsRange of points (Point_range::value_type must be the same as Kernel_::Point_d).
[in]intrinsic_dimensionIntrinsic dimension of the manifold.
[in]kKernel instance.
Member Function Documentation
◆ compute_tangential_complex()
void Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::compute_tangential_complex ( )
inline
Exceptions
std::invalid_argumentIn debug mode, if the computed star dimension is too low. Try to set a bigger maximal edge length value with Tangential_complex::set_max_squared_edge_length if this happens.
Examples
◆ create_complex()
int Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::create_complex ( Simplex_tree_ &  tree,
bool  export_inconsistent_simplices = true
) const
inline
Template Parameters
Simplex_tree_must be a Simplex_tree.
Parameters
[out]treeThe result, where each Vertex_handle is the index of the corresponding point in the range provided to the constructor (it can also be retrieved through the Tangential_complex::get_point function.
[in]export_inconsistent_simplicesAlso export inconsistent simplices or not?
Returns
The maximal dimension of the simplices.
Examples
◆ fix_inconsistencies_using_perturbation()
Fix_inconsistencies_info Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::fix_inconsistencies_using_perturbation ( double  max_perturb,
double  time_limit = -1.
inline
Parameters
[in]max_perturbMaximum length of the translations used by the perturbation.
[in]time_limitTime limit in seconds. If -1, no time limit is set.
Examples
◆ get_perturbed_point()
Point Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::get_perturbed_point ( std::size_t  vertex) const
inline
Parameters
[in]vertexVertex handle of the point to retrieve.
Returns
The perturbed position of the point found.
◆ get_point()
Point Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::get_point ( std::size_t  vertex) const
inline
Parameters
Returns
The point found.
◆ number_of_inconsistent_simplices()
Num_inconsistencies Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::number_of_inconsistent_simplices ( bool  verbose = false) const
inline
Returns the number of inconsistencies
Parameters
[in]verboseIf true, outputs a message into std::cerr.
Examples
example_basic.cpp.
◆ set_max_squared_edge_length()
void Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::set_max_squared_edge_length ( FT  max_squared_edge_length)
inline
Parameters
[in]max_squared_edge_lengthMaximal possible squared edge length.
If the maximal edge length value is too low Tangential_complex::compute_tangential_complex will throw an exception in debug mode.
The documentation for this class was generated from the following file:
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:28 for GUDHI by Doxygen 1.9.2
