Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::Num_inconsistencies Struct Reference
Type returned by Tangential_complex::number_of_inconsistent_simplices. More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/include/gudhi/Tangential_complex.h>
Public Attributes
std::size_t num_simplices = 0
 Total number of simplices in stars (including duplicates that appear in several stars)
std::size_t num_inconsistent_simplices = 0
 Number of inconsistent simplices.
std::size_t num_inconsistent_stars = 0
 Number of stars containing at least one inconsistent simplex.
Detailed Description
template<typename Kernel_, typename DimensionTag, typename Concurrency_tag = CGAL::Parallel_tag, typename Triangulation_ = CGAL::Default>
struct Gudhi::tangential_complex::Tangential_complex< Kernel_, DimensionTag, Concurrency_tag, Triangulation_ >::Num_inconsistencies
The documentation for this struct was generated from the following file:
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:28 for GUDHI by Doxygen 1.9.2
