virtual void | on_changed_edge (Vertex_handle a, Vertex_handle b)=0 |
| | Called when an edge changes, during the contraction of an edge.
virtual void | on_swaped_edge (Vertex_handle a, Vertex_handle b, Vertex_handle x)=0 |
| | Called when performing an edge contraction when an edge bx is replaced by an edge ax (not already present). Precisely, this methods is called this way in contract_edge : add_edge_without_blockers(a,x) on_swaped_edge(a,b,x) remove_edge(b,x)
template<typename Vertex_handle>
class Gudhi::skeleton_blocker::Skeleton_blocker_complex_visitor< Vertex_handle >
Interface for a visitor of a simplicial complex.
