11#ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
12#define SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
14#include <gudhi/Skeleton_blocker/Skeleton_blocker_simplex.h>
18namespace skeleton_blocker {
25template<
typename Vertex_handle>
30 virtual void on_add_vertex(Vertex_handle) = 0;
31 virtual void on_remove_vertex(Vertex_handle) = 0;
33 virtual void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) = 0;
34 virtual void on_remove_edge(Vertex_handle a, Vertex_handle b) = 0;
52 virtual void on_add_blocker(
54 virtual void on_delete_blocker(
63template<
67 void on_add_vertex(Vertex_handle) { }
69 void on_remove_vertex(Vertex_handle) { }
71 void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) { }
73 void on_remove_edge(Vertex_handle a, Vertex_handle b) { }
81 void on_delete_blocker(
const Skeleton_blocker_simplex<Vertex_handle>*) { }
89template<
93 void on_add_vertex(Vertex_handle v) {
94 std::cerr <<
"on_add_vertex:" << v << std::endl;
97 void on_remove_vertex(Vertex_handle v) {
98 std::cerr <<
"on_remove_vertex:" << v << std::endl;
101 void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) {
102 std::cerr <<
"on_add_edge_without_blockers:" << a <<
"," << b << std::endl;
105 void on_remove_edge(Vertex_handle a, Vertex_handle b) {
106 std::cerr <<
"on_remove_edge:" << a <<
110 std::cerr <<
"on_changed_edge:" << a <<
114 std::cerr <<
"on_swaped_edge:" << a <<
"," << b <<
"," << x << std::endl;
118 std::cerr <<
"on_add_blocker:" << b << std::endl;
121 void on_delete_blocker(
const Skeleton_blocker_simplex<Vertex_handle>* b) {
122 std::cerr <<
"on_delete_blocker:" << b << std::endl;
128namespace skbl = skeleton_blocker;
A dummy visitor of a simplicial complex that does nothing.
Definition: Skeleton_blocker_complex_visitor.h:65
void on_changed_edge(Vertex_handle a, Vertex_handle b)
Called when an edge changes, during the contraction of an edge.
Definition: Skeleton_blocker_complex_visitor.h:75
void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x)
Called when performing an edge contraction when an edge bx is replaced by an edge ax (not already pre...
Definition: Skeleton_blocker_complex_visitor.h:77
A visitor that prints the visit information.
Definition: Skeleton_blocker_complex_visitor.h:91
Definition: Skeleton_blocker_complex_visitor.h:109
Definition: Skeleton_blocker_complex_visitor.h:113
Interface for a visitor of a simplicial complex.
Definition: Skeleton_blocker_complex_visitor.h:26
virtual void on_changed_edge(Vertex_handle a, Vertex_handle b)=0
virtual void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x)=0
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:38
