The type of edges that are stored the boost graph. An Edge must be Default Constructible and Equality Comparable. More...
Public Member Functions | |
void | setId (Root_vertex_handle a, Root_vertex_handle b) |
Allows to modify vertices of the edge. | |
Root_vertex_handle | first () const |
Returns the first vertex of the edge. | |
Root_vertex_handle | second () const |
Returns the second vertex of the edge. | |
GUDHI Version 3.4.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Jan 22 2021 09:41:16 for GUDHI by Doxygen 1.8.13 |
