Root_vertex_handle and Vertex_handle are similar to global and local vertex descriptor used in boost subgraphs and allow to localize a vertex of a subcomplex on its parent root complex. More...
In gross, vertices are stored in a vector and the Root_vertex_handle and Vertex_handle store indices of a vertex in this vector.
For the root simplicial complex, the Root_vertex_handle and Vertex_handle of a vertex are the same.
For a subcomplex L of a simplicial complex K, the local descriptor, ie the Vertex_handle, of a vertex v (that belongs to L) is its position in the vector of vertices of the subcomplex L whereas its Root_vertex_handle (global descriptor) is the position of v in the vector of the vertices of the root simplicial complex K.
GUDHI Version 3.4.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Jan 22 2021 09:41:16 for GUDHI by Doxygen 1.8.13 |
