Simple traits that is a model of SkeletonBlockerDS and can be passed as a template argument to Skeleton_blocker_complex.
More...
| struct | Root_vertex_handle |
| | Global and local handle similar to boost subgraphs. Vertices are stored in a vector. For the root simplicial complex, the local and global descriptors are the same. For a subcomplex L and one of its vertices 'v', the local descriptor of 'v' is its position in the vertex vector of the subcomplex L whereas its global descriptor is the position of 'v' in the vertex vector of the root simplicial complex. More...
The documentation for this struct was generated from the following file:
