Global and local handle similar to boost subgraphs. Vertices are stored in a vector. For the root simplicial complex, the local and global descriptors are the same. For a subcomplex L and one of its vertices 'v', the local descriptor of 'v' is its position in the vertex vector of the subcomplex L whereas its global descriptor is the position of 'v' in the vertex vector of the root simplicial complex. More...
GUDHI Version 3.4.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Jan 22 2021 09:41:16 for GUDHI by Doxygen 1.8.13 |
