The concept SimplicialComplexForCech describes the requirements for a type to implement a simplicial complex, that can be created from a Cech_complex.
More...
Public Types | |
| typedef unspecified | Simplex_handle |
| typedef unspecified | Vertex_handle |
| typedef unspecified | Filtration_value |
Public Member Functions | |
| int | assign_filtration (Simplex_handle simplex, Filtration_value filtration) |
| Simplex_vertex_range | simplex_vertex_range (Simplex_handle const &simplex) |
| Returns a range over vertices of a given simplex. | |
| template<class ProximityGraph > | |
| void | insert_graph (const ProximityGraph &proximity_graph) |
Inserts a given Gudhi::ProximityGraph in the simplicial complex. | |
| template<typename Blocker > | |
| void | expansion_with_blockers (int max_dim, Blocker block_simplex) |
| Expands the simplicial complex containing only its one skeleton until a given maximal dimension. expansion can be blocked by the blocker oracle. | |
| std::size_t | num_vertices () |
| typedef unspecified Gudhi::cech_complex::SimplicialComplexForCech::Filtration_value |
Handle to specify the simplex filtration value.
| typedef unspecified Gudhi::cech_complex::SimplicialComplexForCech::Simplex_handle |
Handle to specify a simplex.
| typedef unspecified Gudhi::cech_complex::SimplicialComplexForCech::Vertex_handle |
Handle to specify a vertex. Must be a non-negative integer.
| int Gudhi::cech_complex::SimplicialComplexForCech::assign_filtration | ( | Simplex_handle | simplex, |
| Filtration_value | filtration | ||
Assigns the 'simplex' with the given 'filtration' value.
| std::size_t Gudhi::cech_complex::SimplicialComplexForCech::num_vertices | ( | ) |
Returns the number of vertices in the simplicial complex.
| GUDHI Version 3.4.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Jan 22 2021 09:41:16 for GUDHI by Doxygen 1.8.13 |
