SimplicialComplexForCech.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Vincent Rouvreau
4  *
5  * Copyright (C) 2018 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef CONCEPT_CECH_COMPLEX_SIMPLICIAL_COMPLEX_FOR_CECH_H_
12 #define CONCEPT_CECH_COMPLEX_SIMPLICIAL_COMPLEX_FOR_CECH_H_
13
14 namespace Gudhi {
15
16 namespace cech_complex {
17
23  typedef unspecified Simplex_handle;
25  typedef unspecified Vertex_handle;
27  typedef unspecified Filtration_value;
28
30  int assign_filtration(Simplex_handle simplex, Filtration_value filtration);
31
34  Simplex_vertex_range simplex_vertex_range(Simplex_handle const & simplex);
35
37  template<class ProximityGraph>
38  void insert_graph(const ProximityGraph& proximity_graph);
39
42  template< typename Blocker >
43  void expansion_with_blockers(int max_dim, Blocker block_simplex);
44
46  std::size_t num_vertices();
47
48 };
49
50 } // namespace alpha_complex
51
52 } // namespace Gudhi
53
54 #endif // CONCEPT_ALPHA_COMPLEX_SIMPLICIAL_COMPLEX_FOR_ALPHA_H_
Definition: SimplicialComplexForCech.h:27
Simplex_vertex_range simplex_vertex_range(Simplex_handle const &simplex)
Returns a range over vertices of a given simplex.
Definition: SimplicialComplexForAlpha.h:14
Expands the simplicial complex containing only its one skeleton until a given maximal dimension...
Definition: SimplicialComplexForCech.h:25
Definition: SimplicialComplexForCech.h:23
void insert_graph(const ProximityGraph &proximity_graph)
Inserts a given Gudhi::ProximityGraph in the simplicial complex.
The concept SimplicialComplexForCech describes the requirements for a type to implement a simplicial ...
Definition: SimplicialComplexForCech.h:21
GUDHI  Version 3.4.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Jan 22 2021 09:41:15 for GUDHI by Doxygen 1.8.13
