Simple traits that is a model of SkeletonBlockerGeometricDS and can be passed as a template argument to Skeleton_blocker_geometric_complex.
 More...
| typedef GeometryTrait | GT |
| typedef GeometryTrait::Point | Point |
| typedef int | boost_vertex_handle |
|  | index that allows to find the vertex in the boost graph
template<typename GeometryTrait>
struct Gudhi::skeleton_blocker::Skeleton_blocker_simple_geometric_traits< GeometryTrait >
- Examples:
- Contraction/Garland_heckbert.cpp, and Contraction/Rips_contraction.cpp.
The documentation for this struct was generated from the following file:
