11 #ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLE_GEOMETRIC_TRAITS_H_    12 #define SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLE_GEOMETRIC_TRAITS_H_    14 #include <gudhi/Skeleton_blocker/Skeleton_blocker_simple_traits.h>    21 namespace skeleton_blocker {
    29 template<
typename GeometryTrait>
    33   typedef GeometryTrait
GT;
    34   typedef typename GT::Point
Point;
    36   typedef typename Skeleton_blocker_simple_traits::Graph_vertex Simple_vertex;
    50     const Point& point()
 const {
    55   class Simple_geometric_edge :
    56   public Skeleton_blocker_simple_traits::Graph_edge {
    59     Simple_geometric_edge()
    60         : Skeleton_blocker_simple_traits::Graph_edge(),
    78   typedef Skeleton_blocker_simple_traits::Graph_edge Graph_edge;
    83 namespace skbl = skeleton_blocker;
    87 #endif  // SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLE_GEOMETRIC_TRAITS_H_ GeometryTrait GT
Definition: SkeletonBlockerGeometricDS.h:32
Vertex with a point attached.
Definition: Skeleton_blocker_simple_geometric_traits.h:41
Definition: SimplicialComplexForAlpha.h:14
Class that represents a geometric complex that can be simplified. The class allows access to points o...
Definition: Skeleton_blocker_geometric_complex.h:28
GeometryTrait::Point Point
Definition: SkeletonBlockerGeometricDS.h:37
Global and local handle similar to boost subgraphs. Vertices are stored in a vector. For the root simplicial complex, the local and global descriptors are the same. For a subcomplex L and one of its vertices 'v', the local descriptor of 'v' is its position in the vertex vector of the subcomplex L whereas its global descriptor is the position of 'v' in the vertex vector of the root simplicial complex.
Definition: Skeleton_blocker_simple_traits.h:38
Simple traits that is a model of SkeletonBlockerDS and can be passed as a template argument to Skelet...
Definition: Skeleton_blocker_simple_traits.h:29
Simple traits that is a model of SkeletonBlockerGeometricDS and can be passed as a template argument ...
Definition: Skeleton_blocker_simple_geometric_traits.h:30
