Gudhi::rips_complex::Sparse_rips_complex< Filtration_value > Class Template Reference
Sparse Rips complex data structure. More...
Public Member Functions
template<typename RandomAccessPointRange , typename Distance >
 Sparse_rips_complex (const RandomAccessPointRange &points, Distance distance, double epsilon, Filtration_value mini=-std::numeric_limits< Filtration_value >::infinity(), Filtration_value maxi=std::numeric_limits< Filtration_value >::infinity())
 Sparse_rips_complex constructor from a list of points. More...
template<typename DistanceMatrix >
 Sparse_rips_complex (const DistanceMatrix &distance_matrix, double epsilon, Filtration_value mini=-std::numeric_limits< Filtration_value >::infinity(), Filtration_value maxi=std::numeric_limits< Filtration_value >::infinity())
 Sparse_rips_complex constructor from a distance matrix. More...
template<typename SimplicialComplexForRips >
void create_complex (SimplicialComplexForRips &complex, int dim_max)
 Fills the simplicial complex with the sparse Rips graph and expands it with all the cliques, stopping at a given maximal dimension. More...
Detailed Description
template<typename Filtration_value>
class Gudhi::rips_complex::Sparse_rips_complex< Filtration_value >
This class is used to construct a sparse \((1+O(\epsilon))\)-approximation of Rips_complex, i.e. a filtered simplicial complex that is multiplicatively \((1+O(\epsilon))\)-interleaved with the Rips filtration. More precisely, this is a \((1,\frac{1}{1-\epsilon}\)-interleaving.
Template Parameters
Filtration_valueis the type used to store the filtration values of the simplicial complex.
Constructor & Destructor Documentation
◆ Sparse_rips_complex() [1/2]
template<typename Filtration_value >
Gudhi::rips_complex::Sparse_rips_complex< Filtration_value >::Sparse_rips_complex ( const RandomAccessPointRange &  points,
Distance  distance,
double  epsilon,
Filtration_value  mini = -std::numeric_limits<Filtration_value>::infinity(),
Filtration_value  maxi = std::numeric_limits<Filtration_value>::infinity()
inline
Parameters
[in]pointsRange of points.
[in]distanceDistance function that returns a Filtration_value from 2 given points.
[in]epsilonApproximation parameter. epsilon must be positive.
[in]miniMinimal filtration value. Ignore anything below this scale. This is a less efficient version of Gudhi::subsampling::sparsify_point_set().
[in]maxiMaximal filtration value. Ignore anything above this scale.
◆ Sparse_rips_complex() [2/2]
Gudhi::rips_complex::Sparse_rips_complex< Filtration_value >::Sparse_rips_complex ( const DistanceMatrix &  distance_matrix,
double  epsilon,
inline
Parameters
[in]distance_matrixRange of range of distances. distance_matrix[i][j] returns the distance between points \(i\) and \(j\) as long as \( 0 \leqslant j < i \leqslant distance\_matrix.size().\)
Member Function Documentation
◆ create_complex()
void Gudhi::rips_complex::Sparse_rips_complex< Filtration_value >::create_complex ( SimplicialComplexForRips &  complex,
int  dim_max
inline
Template Parameters
SimplicialComplexForRipsmust meet SimplicialComplexForRips concept.
Parameters
[in]complexthe complex to fill
[in]dim_maxmaximal dimension of the simplicial complex.
Exceptions
std::invalid_argumentIn debug mode, if complex.num_vertices() does not return 0.
The documentation for this class was generated from the following file:
GUDHI  Version 3.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Wed May 20 2020 07:53:47 for GUDHI by Doxygen 1.8.13
