11 #ifndef SPARSE_RIPS_COMPLEX_H_    12 #define SPARSE_RIPS_COMPLEX_H_    14 #include <gudhi/Debug_utils.h>    15 #include <gudhi/graph_simplicial_complex.h>    16 #include <gudhi/choose_n_farthest_points.h>    18 #include <boost/graph/adjacency_list.hpp>    19 #include <boost/range/metafunctions.hpp>    25 namespace rips_complex {
    44 template <
typename Filtration_value>
    48   typedef typename boost::adjacency_list<boost::vecS, boost::vecS, boost::directedS,
    49                                          boost::property<vertex_filtration_t, Filtration_value>,
    50                                          boost::property<edge_filtration_t, Filtration_value>>
    53   typedef int Vertex_handle;
    65   template <
typename RandomAccessPo
intRange,
typename Distance>
    68     GUDHI_CHECK(epsilon > 0,
"epsilon must be positive");
    69     auto dist_fun = [&](Vertex_handle i, Vertex_handle j) {
return distance(points[i], points[j]); };
    70     Ker<decltype(dist_fun)> kernel(dist_fun);
    72                                           std::back_inserter(sorted_points), std::back_inserter(params));
    73     compute_sparse_graph(dist_fun, epsilon, mini, maxi);
    86   template <
typename DistanceMatrix>
    89                             [&](Vertex_handle i, Vertex_handle j) {
return (i==j) ? 0 : (i<j) ? distance_matrix[j][i] : distance_matrix[i][j]; },
    90                             epsilon, mini, maxi) {}
   102   template <
typename SimplicialComplexForRips>
   105                 std::invalid_argument(
"Sparse_rips_complex::create_complex - simplicial complex is not empty"));
   112     const int n = boost::size(params);
   113     std::vector<Filtration_value> lambda(n);
   116       lambda[sorted_points[i]] = params[i];
   117     double cst = epsilon_ * (1 - epsilon_) / 2;
   119       auto filt = complex.filtration(sh);
   120       auto mini = filt * cst;
   121       for(
auto v : complex.simplex_vertex_range(sh)){
   127     complex.expansion_with_blockers(dim_max, block);
   132   template <
class Distance>
   134     typedef std::size_t Point_d;
   135     Ker(Distance& d) : dist(d) {}
   137     typedef Distance Squared_distance_d;
   138     Squared_distance_d& squared_distance_d_object()
 const {
return dist; }
   143   template <
typename Distance>
   145     const auto& points = sorted_points;
   146     const int n = boost::size(points);
   147     double cst = epsilon * (1 - epsilon) / 2;
   149     new (&graph_) Graph(n);
   151     typename boost::graph_traits<Graph>::vertex_iterator v_i, v_e;
   152     for (std::tie(v_i, v_e) = vertices(graph_); v_i != v_e; ++v_i) {
   155       put(vertex_filtration_t(), graph_, v, 0);
   161     for (
int i = 0; i < n; ++i) {
   162       auto&& pi = points[i];
   164       if (li < mini)
break;
   165       for (
int j = i + 1; j < n; ++j) {
   166         auto&& pj = points[j];
   167         auto d = dist(pi, pj);
   169         if (lj < mini)
break;
   170         GUDHI_CHECK(lj <= li,
"Bad furthest point sorting");
   174         if (d * epsilon <= 2 * lj)
   176         else if (d * epsilon > li + lj)
   179           alpha = (d - lj / epsilon) * 2;
   181           if (epsilon < 1 && alpha * cst > lj)
   186           add_edge(pi, pj, alpha, graph_);
   195   std::vector<Vertex_handle> sorted_points;
   197   std::vector<Filtration_value> params;
   204 #endif  // SPARSE_RIPS_COMPLEX_H_ void choose_n_farthest_points(Kernel const &k, Point_range const &input_pts, std::size_t final_size, std::size_t starting_point, PointOutputIterator output_it, DistanceOutputIterator dist_it={})
Subsample by a greedy strategy of iteratively adding the farthest point from the current chosen point...
Definition: choose_n_farthest_points.h:66
void expansion(int max_dim)
Expands the simplicial complex containing only its one skeleton until a given maximal dimension as ex...
void insert_graph(const OneSkeletonGraph &skel_graph)
Inserts a given Gudhi::rips_complex::Rips_complex::OneSkeletonGraph in the simplicial complex...
The concept SimplicialComplexForRips describes the requirements for a type to implement a simplicial ...
Definition: SimplicialComplexForRips.h:21
Definition: SimplicialComplexForAlpha.h:14
Sparse_rips_complex(const DistanceMatrix &distance_matrix, double epsilon, Filtration_value mini=-std::numeric_limits< Filtration_value >::infinity(), Filtration_value maxi=std::numeric_limits< Filtration_value >::infinity())
Sparse_rips_complex constructor from a distance matrix.
Definition: Sparse_rips_complex.h:87
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Sparse_rips_complex(const RandomAccessPointRange &points, Distance distance, double epsilon, Filtration_value mini=-std::numeric_limits< Filtration_value >::infinity(), Filtration_value maxi=std::numeric_limits< Filtration_value >::infinity())
Sparse_rips_complex constructor from a list of points.
Definition: Sparse_rips_complex.h:66
std::size_t num_vertices()
Returns the number of vertices in the simplicial complex.
unspecified Simplex_handle
Handle type to a simplex contained in the simplicial complex.
Definition: SimplicialComplexForRips.h:26
Sparse Rips complex data structure.
Definition: Sparse_rips_complex.h:45
void create_complex(SimplicialComplexForRips &complex, int dim_max)
Fills the simplicial complex with the sparse Rips graph and expands it with all the cliques...
Definition: Sparse_rips_complex.h:103
