Concept of the template parameter for the class Gudhi::Simplex_tree<SimplexTreeOptions>.
More...
#include <concept/Simplex_tree/SimplexTreeOptions.h>
Public Types | |
| typedef IndexingTag | Indexing_tag |
| Forced for now. | |
| typedef VertexHandle | Vertex_handle |
| Must be a signed integer type. It admits a total order <. | |
| typedef FiltrationValue | Filtration_value |
| Must be comparable with operator<. | |
| typedef SimplexKey | Simplex_key |
| Must be an integer type. | |
| typedef SimplexData | Simplex_data |
| Optional, can be omitted. | |
Static Public Attributes | |
| static const bool | store_key |
If true, each simplex has extra storage for one Simplex_key. Necessary for Persistent_cohomology. | |
| static const bool | store_filtration |
If true, each simplex has extra storage for one Filtration_value, and this value is propagated by operations like Gudhi::Simplex_tree::expansion. Without it, Persistent_cohomology degenerates to computing usual (non-persistent) cohomology. | |
| static constexpr bool | contiguous_vertices |
| If true, the list of vertices present in the complex must always be 0, ..., num_vertices-1, without any hole. | |
| static const bool | link_nodes_by_label |
If true, the lists of Node with same label are stored to enhance cofaces and stars access. | |
| static const bool | stable_simplex_handles |
| If true, Simplex_handle will not be invalidated after insertions or removals. | |
A model for this is Gudhi::Simplex_tree_options_full_featured or Gudhi::Simplex_tree_options_minimal. If you want to provide your own, it is recommended that you derive from it and override some parts instead of writing a class from scratch.
