Gudhi::Simplex_tree< SimplexTreeOptions > Class Template Reference
Simplex Tree data structure for representing simplicial complexes. More...
#include <gudhi/Simplex_tree.h>
Public Types
typedef Options::Filtration_value Filtration_value
 Type for the value of the filtration function. More...
typedef Options::Simplex_key Simplex_key
 Key associated to each simplex. More...
typedef Get_simplex_data_type< Options >::type Simplex_data
 Extra data stored in each simplex. More...
typedef Options::Vertex_handle Vertex_handle
 Type for the vertex handle. More...
typedef Simplex_tree_siblings< Simplex_tree, Dictionary > Siblings
 Set of nodes sharing a same parent in the simplex tree.
typedef Dictionary::const_iterator Simplex_handle
 Handle type to a simplex contained in the simplicial complex represented by the simplex tree. More...
Public Member Functions
template<class OtherSimplexTreeOptions >
bool operator== (const Simplex_tree< OtherSimplexTreeOptions > &st2) const
 Checks if two simplex trees are equal. Any extra data (Simplex_data) stored in the simplices are ignored in the comparison.
bool operator!= (const Simplex_tree< OtherSimplexTreeOptions > &st2) const
 Checks if two simplex trees are different.
Simplex_handle simplex (Simplex_key idx) const
 Returns the simplex that has index idx in the filtration. More...
void assign_filtration (Simplex_handle sh, Filtration_value fv)
 Sets the filtration value of a simplex. More...
Simplex_data & simplex_data (Simplex_handle sh)
 Returns the extra data stored in a simplex.
const Simplex_data & simplex_data (Simplex_handle sh) const
Vertex_handle null_vertex () const
 Returns a Vertex_handle different from all Vertex_handles associated to the vertices of the simplicial complex.
size_t num_vertices () const
 Returns the number of vertices in the complex.
bool is_empty () const
 Returns whether the complex is empty.
size_t num_simplices () const
 Returns the number of simplices in the simplex_tree. More...
std::vector< size_t > num_simplices_by_dimension () const
 Returns the number of simplices of each dimension in the simplex tree.
int dimension (Simplex_handle sh) const
 Returns the dimension of a simplex. More...
int upper_bound_dimension () const
 Returns an upper bound on the dimension of the simplicial complex. More...
int dimension () const
 Returns the dimension of the simplicial complex. More...
template<class SimplexHandle >
bool has_children (SimplexHandle sh) const
 Returns true if the node in the simplex tree pointed by the given simplex handle has children.
template<class InputVertexRange = std::initializer_list<Vertex_handle>>
Simplex_handle find (const InputVertexRange &s) const
 Given a range of Vertex_handles, returns the Simplex_handle of the simplex in the simplicial complex containing the corresponding vertices. Return null_simplex() if the simplex is not in the complex. More...
std::pair< Simplex_handle, bool > insert_simplex (const InputVertexRange &simplex, Filtration_value filtration=0)
 Insert a simplex, represented by a range of Vertex_handles, in the simplicial complex. More...
std::pair< Simplex_handle, bool > insert_simplex_and_subfaces (const InputVertexRange &Nsimplex, Filtration_value filtration=0)
 Insert a N-simplex and all his subfaces, from a N-simplex represented by a range of Vertex_handles, in the simplicial complex. More...
void assign_key (Simplex_handle sh, Simplex_key key)
 Assign a value 'key' to the key of the simplex represented by the Simplex_handle 'sh'.
std::pair< Simplex_handle, Simplex_handle > endpoints (Simplex_handle sh) const
Siblings const * self_siblings (SimplexHandle sh) const
Siblings * self_siblings (SimplexHandle sh)
Siblings * root ()
const Siblings * root () const
void set_dimension (int dimension, bool exact=true)
 Set a dimension for the simplicial complex. More...
void initialize_filtration (bool ignore_infinite_values=false) const
 Initializes the filtration cache, i.e. sorts the simplices according to their order in the filtration. More...
void maybe_initialize_filtration () const
 Initializes the filtration cache if it isn't initialized yet. More...
void clear_filtration () const
 Clears the filtration cache produced by initialize_filtration(). More...
Cofaces_simplex_range star_simplex_range (const Simplex_handle simplex) const
 Compute the star of a n simplex. More...
Cofaces_simplex_range cofaces_simplex_range (const Simplex_handle simplex, int codimension) const
 Compute the cofaces of a n simplex. More...
template<class OneSkeletonGraph >
void insert_graph (const OneSkeletonGraph &skel_graph)
 Inserts a 1-skeleton in an empty Simplex_tree. More...
template<class VertexRange >
void insert_batch_vertices (VertexRange const &vertices, Filtration_value filt=0)
 Inserts several vertices. More...
void expansion (int max_dim)
 Expands the Simplex_tree containing only its one skeleton until dimension max_dim. More...
void insert_edge_as_flag (Vertex_handle u, Vertex_handle v, Filtration_value fil, int dim_max, std::vector< Simplex_handle > &added_simplices)
 Adds a new vertex or a new edge in a flag complex, as well as all simplices of its star, defined to maintain the property of the complex to be a flag complex, truncated at dimension dim_max. To insert a new edge, the two given vertex handles have to correspond to the two end points of the edge. To insert a new vertex, the handles have to be twice the same and correspond to the number you want assigned to it. I.e., to insert vertex \(i\), give \(u = v = i\). The method assumes that the given edge was not already contained in the simplex tree, so the behaviour is undefined if called on an existing edge. Also, the vertices of an edge have to be inserted before the edge. More...
template<typename Blocker >
void expansion_with_blockers (int max_dim, Blocker block_simplex)
 Expands a simplex tree containing only a graph. Simplices corresponding to cliques in the graph are added incrementally, faces before cofaces, unless the simplex has dimension larger than max_dim or block_simplex returns true for this simplex. More...
void print_hasse (std::ostream &os) const
 Write the hasse diagram of the simplicial complex in os. More...
template<class Fun >
void for_each_simplex (Fun &&fun) const
bool make_filtration_non_decreasing ()
 This function ensures that each simplex has a higher filtration value than its faces by increasing the filtration values. More...
void clear ()
 Remove all the simplices, leaving an empty complex.
bool prune_above_filtration (Filtration_value filtration)
 Prune above filtration value given as parameter. More...
bool prune_above_dimension (int dimension)
 Remove all simplices of dimension greater than a given value. More...
void remove_maximal_simplex (Simplex_handle sh)
 Remove a maximal simplex. More...
std::pair< Filtration_value, Extended_simplex_type > decode_extended_filtration (Filtration_value f, const Extended_filtration_data &efd) const
 Retrieve the original filtration value for a given simplex in the Simplex_tree. Since the computation of extended persistence requires modifying the filtration values, this function can be used to recover the original values. Moreover, computing extended persistence requires adding new simplices in the Simplex_tree. Hence, this function also outputs the type of each simplex. It can be either UP (which means that the simplex was present originally, and is thus part of the ascending extended filtration), DOWN (which means that the simplex is the cone of an original simplex, and is thus part of the descending extended filtration) or EXTRA (which means the simplex is the cone point). See the definition of Extended_simplex_type. Note that if the simplex type is DOWN, the original filtration value is set to be the original filtration value of the corresponding (not coned) original simplex. More...
Extended_filtration_data extend_filtration ()
 Extend filtration for computing extended persistence. This function only uses the filtration values at the 0-dimensional simplices, and computes the extended persistence diagram induced by the lower-star filtration computed with these values. More...
Vertex_handle vertex_with_same_filtration (Simplex_handle sh) const
 Returns a vertex of sh that has the same filtration value as sh if it exists, and null_vertex() otherwise. More...
Simplex_handle edge_with_same_filtration (Simplex_handle sh) const
 Returns an edge of sh that has the same filtration value as sh if it exists, and null_simplex() otherwise. More...
Simplex_handle minimal_simplex_with_same_filtration (Simplex_handle sh) const
 Returns a minimal face of sh that has the same filtration value as sh. More...
void reset_filtration (Filtration_value filt_value, int min_dim=0)
 This function resets the filtration value of all the simplices of dimension at least min_dim. Resets all the Simplex_tree when min_dim = 0. reset_filtration may break the filtration property with min_dim > 0, and it is the user's responsibility to make it a valid filtration (using a large enough filt_value, or calling make_filtration_non_decreasing afterwards for instance). More...
Range and iterator methods
Complex_vertex_range complex_vertex_range () const
 Returns a range over the vertices of the simplicial complex. The order is increasing according to < on Vertex_handles.
Complex_simplex_range complex_simplex_range () const
 Returns a range over the simplices of the simplicial complex. More...
Skeleton_simplex_range skeleton_simplex_range (int dim) const
 Returns a range over the simplices of the dim-skeleton of the simplicial complex. More...
Filtration_simplex_range const & filtration_simplex_range (Indexing_tag=Indexing_tag()) const
 Returns a range over the simplices of the simplicial complex, in the order of the filtration. More...
Simplex_vertex_range simplex_vertex_range (Simplex_handle sh) const
 Returns a range over the vertices of a simplex. More...
Boundary_simplex_range boundary_simplex_range (SimplexHandle sh) const
 Returns a range over the simplices of the boundary of a simplex. More...
Boundary_opposite_vertex_simplex_range boundary_opposite_vertex_simplex_range (SimplexHandle sh) const
 Given a simplex, returns a range over the simplices of its boundary and their opposite vertices. More...
Constructor/Destructor
 Simplex_tree ()
 Constructs an empty simplex tree.
template<typename OtherSimplexTreeOptions , typename F >
 Simplex_tree (const Simplex_tree< OtherSimplexTreeOptions > &complex_source, F &&translate_filtration_value)
 Construct the simplex tree as the copy of a given simplex tree with eventually different template parameters. Therefore, should provide a method converting the filtration values of one tree to the another. All other values are already implicitly convertible if the concept of SimplexTreeOptions is respected (note that there is an eventual loss of precision or an undefined behaviour if a value is converted into a new type too small to contain it). Any extra data (Simplex_data) stored in the simplices are ignored in the copy for now. More...
 Simplex_tree (const Simplex_tree &complex_source)
 User-defined copy constructor reproduces the whole tree structure including extra data (Simplex_data) stored in the simplices.
 Simplex_tree (Simplex_tree &&complex_source)
 User-defined move constructor relocates the whole tree structure including extra data (Simplex_data) stored in the simplices. More...
 ~Simplex_tree ()
 Destructor; deallocates the whole tree structure.
Simplex_tree & operator= (const Simplex_tree &complex_source)
 User-defined copy assignment reproduces the whole tree structure including extra data (Simplex_data) stored in the simplices.
Simplex_tree & operator= (Simplex_tree &&complex_source)
 User-defined move assignment relocates the whole tree structure including extra data (Simplex_data) stored in the simplices. More...
Static Public Member Functions
static Simplex_key key (Simplex_handle sh)
 Returns the key associated to a simplex. More...
static Filtration_value filtration (Simplex_handle sh)
 Returns the filtration value of a simplex. More...
static Simplex_handle null_simplex ()
 Returns a Simplex_handle different from all Simplex_handles associated to the simplices in the simplicial complex. More...
static Simplex_key null_key ()
 Returns a fixed number not in the interval [0, num_simplices()).
Range and iterator types
The naming convention is Container_content_(iterator/range). A Container_content_range is essentially an object on which the methods begin() and end() can be called. They both return an object of type Container_content_iterator, and allow the traversal of the range [ begin();end() ).
typedef boost::transform_iterator< return_first, Dictionary_const_it > Complex_vertex_iterator
 Iterator over the vertices of the simplicial complex. More...
typedef boost::iterator_range< Complex_vertex_iterator > Complex_vertex_range
 Range over the vertices of the simplicial complex.
typedef Simplex_tree_simplex_vertex_iterator< Simplex_tree > Simplex_vertex_iterator
 Iterator over the vertices of a simplex. More...
typedef boost::iterator_range< Simplex_vertex_iterator > Simplex_vertex_range
 Range over the vertices of a simplex.
typedef std::conditional< Options::link_nodes_by_label, Optimized_cofaces_simplex_filtered_range, std::vector< Simplex_handle > >::type Cofaces_simplex_range
 Range over the cofaces of a simplex.
typedef Simplex_tree_boundary_simplex_iterator< Simplex_tree > Boundary_simplex_iterator
 Iterator over the simplices of the boundary of a simplex. More...
typedef boost::iterator_range< Boundary_simplex_iterator > Boundary_simplex_range
 Range over the simplices of the boundary of a simplex.
typedef Simplex_tree_boundary_opposite_vertex_simplex_iterator< Simplex_tree > Boundary_opposite_vertex_simplex_iterator
 Iterator over the simplices of the boundary of a simplex and their opposite vertices. More...
typedef boost::iterator_range< Boundary_opposite_vertex_simplex_iterator > Boundary_opposite_vertex_simplex_range
 Range over the simplices of the boundary of a simplex and their opposite vertices.
typedef Simplex_tree_complex_simplex_iterator< Simplex_tree > Complex_simplex_iterator
 Iterator over the simplices of the simplicial complex. More...
typedef boost::iterator_range< Complex_simplex_iterator > Complex_simplex_range
 Range over the simplices of the simplicial complex.
typedef Simplex_tree_skeleton_simplex_iterator< Simplex_tree > Skeleton_simplex_iterator
 Iterator over the simplices of the skeleton of the simplicial complex, for a given dimension. More...
typedef boost::iterator_range< Skeleton_simplex_iterator > Skeleton_simplex_range
 Range over the simplices of the skeleton of the simplicial complex, for a given dimension.
typedef std::vector< Simplex_handle > Filtration_simplex_range
 Range over the simplices of the simplicial complex, ordered by the filtration.
typedef Filtration_simplex_range::const_iterator Filtration_simplex_iterator
 Iterator over the simplices of the simplicial complex, ordered by the filtration. More...
Detailed Description
template<typename SimplexTreeOptions = Simplex_tree_options_default>
class Gudhi::Simplex_tree< SimplexTreeOptions >
Every simplex \([v_0, \cdots ,v_d]\) admits a canonical orientation induced by the order relation on vertices \( v_0 < \cdots < v_d \).
Details may be found in [7].
Examples
Alpha_complex_3d_from_points.cpp, Alpha_complex_from_off.cpp, Alpha_complex_from_points.cpp, CoordGIC.cpp, Fast_alpha_complex_from_off.cpp, FuncGIC.cpp, Nerve.cpp, VoronoiGIC.cpp, Weighted_alpha_complex_3d_from_points.cpp, Weighted_alpha_complex_from_points.cpp, alpha_complex_persistence.cpp, cech_complex_cgal_mini_sphere_3d.cpp, custom_persistence_sort.cpp, edge_collapse_conserve_persistence.cpp, example_alpha_shapes_3_simplex_tree_from_off_file.cpp, example_basic.cpp, example_nearest_landmark_table.cpp, example_one_skeleton_rips_from_correlation_matrix.cpp, example_one_skeleton_rips_from_distance_matrix.cpp, example_rips_complex_from_csv_distance_matrix_file.cpp, example_rips_complex_from_off_file.cpp, example_simplex_tree_to_matrix.cpp, example_strong_witness_complex_off.cpp, example_with_perturb.cpp, example_witness_complex_off.cpp, example_witness_complex_sphere.cpp, graph_expansion_with_blocker.cpp, mini_simplex_tree.cpp, persistence_from_simple_simplex_tree.cpp, plain_homology.cpp, point_cloud_edge_collapse_rips_persistence.cpp, rips_persistence_via_boundary_matrix.cpp, simple_simplex_tree.cpp, strong_witness_persistence.cpp, and weak_witness_persistence.cpp.
Member Typedef Documentation
◆ Boundary_opposite_vertex_simplex_iterator
typedef Simplex_tree_boundary_opposite_vertex_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< SimplexTreeOptions >::Boundary_opposite_vertex_simplex_iterator
'value_type' is std::pair<Simplex_handle, Vertex_handle>.
◆ Boundary_simplex_iterator
typedef Simplex_tree_boundary_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< SimplexTreeOptions >::Boundary_simplex_iterator
'value_type' is Simplex_handle.
◆ Complex_simplex_iterator
typedef Simplex_tree_complex_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< SimplexTreeOptions >::Complex_simplex_iterator
◆ Complex_vertex_iterator
typedef boost::transform_iterator<return_first, Dictionary_const_it> Gudhi::Simplex_tree< SimplexTreeOptions >::Complex_vertex_iterator
'value_type' is Vertex_handle.
◆ Filtration_simplex_iterator
typedef Filtration_simplex_range::const_iterator Gudhi::Simplex_tree< SimplexTreeOptions >::Filtration_simplex_iterator
◆ Filtration_value
typedef Options::Filtration_value Gudhi::Simplex_tree< SimplexTreeOptions >::Filtration_value
Must be comparable with <.
Examples
◆ Simplex_data
typedef Get_simplex_data_type<Options>::type Gudhi::Simplex_tree< SimplexTreeOptions >::Simplex_data
When extra data type is defined by the user, the extra data gets a default-initialization behaviour, which may mean an indeterminate value.
◆ Simplex_handle
typedef Dictionary::const_iterator Gudhi::Simplex_tree< SimplexTreeOptions >::Simplex_handle
They are essentially pointers into internal vectors, and any insertion or removal of a simplex may invalidate any other Simplex_handle in the complex, unless Options::stable_simplex_handles == true.
◆ Simplex_key
typedef Options::Simplex_key Gudhi::Simplex_tree< SimplexTreeOptions >::Simplex_key
Must be an integer type.
◆ Simplex_vertex_iterator
typedef Simplex_tree_simplex_vertex_iterator<Simplex_tree> Gudhi::Simplex_tree< SimplexTreeOptions >::Simplex_vertex_iterator
◆ Skeleton_simplex_iterator
typedef Simplex_tree_skeleton_simplex_iterator<Simplex_tree> Gudhi::Simplex_tree< SimplexTreeOptions >::Skeleton_simplex_iterator
◆ Vertex_handle
typedef Options::Vertex_handle Gudhi::Simplex_tree< SimplexTreeOptions >::Vertex_handle
Must be a signed integer type. It admits a total order <.
Constructor & Destructor Documentation
◆ Simplex_tree() [1/2]
Gudhi::Simplex_tree< SimplexTreeOptions >::Simplex_tree ( const Simplex_tree< OtherSimplexTreeOptions > &  complex_source,
F &&  translate_filtration_value
inline
Template Parameters
OtherSimplexTreeOptionsOptions of the given simplex tree.
FMethod taking an OtherSimplexTreeOptions::Filtration_value as input and returning an Options::Filtration_value.
Parameters
complex_sourceSimplex tree to copy.
translate_filtration_valueMethod taking an OtherSimplexTreeOptions::Filtration_value from the source tree as input and returning the corresponding Options::Filtration_value in the new tree.
◆ Simplex_tree() [2/2]
Gudhi::Simplex_tree< SimplexTreeOptions >::Simplex_tree ( Simplex_tree< SimplexTreeOptions > &&  complex_source)
inline
Exceptions
std::invalid_argumentIn debug mode, if the complex_source is invalid.
Member Function Documentation
◆ assign_filtration()
void Gudhi::Simplex_tree< SimplexTreeOptions >::assign_filtration ( Simplex_handle  sh,
Filtration_value  fv
inline
Exceptions
std::invalid_argumentIn debug mode, if sh is a null_simplex.
◆ boundary_opposite_vertex_simplex_range()
Boundary_opposite_vertex_simplex_range Gudhi::Simplex_tree< SimplexTreeOptions >::boundary_opposite_vertex_simplex_range ( SimplexHandle  sh) const
inline
The boundary of a simplex is the set of codimension \(1\) subsimplices of the simplex. If the simplex is \([v_0, \cdots ,v_d]\), with canonical orientation induced by \( v_0 < \cdots < v_d \), the iterator enumerates the simplices of the boundary in the order: \([v_0,\cdots,\widehat{v_i},\cdots,v_d]\) for \(i\) from \(d\) to \(0\), where \(\widehat{v_i}\) means that the vertex \(v_i\), known as the opposite vertex, is omitted from boundary, but returned as the second element of a pair.
Parameters
[in]shSimplex for which the boundary is computed.
◆ boundary_simplex_range()
Boundary_simplex_range Gudhi::Simplex_tree< SimplexTreeOptions >::boundary_simplex_range ( SimplexHandle  sh) const
inline
The boundary of a simplex is the set of codimension \(1\) subsimplices of the simplex. If the simplex is \([v_0, \cdots ,v_d]\), with canonical orientation induced by \( v_0 < \cdots < v_d \), the iterator enumerates the simplices of the boundary in the order: \([v_0,\cdots,\widehat{v_i},\cdots,v_d]\) for \(i\) from \(0\) to \(d\), where \(\widehat{v_i}\) means that the vertex \(v_i\) is omitted.
We note that the alternate sum of the simplices given by the iterator gives \((-1)^{\text{dim} \sigma}\) the chains corresponding to the boundary of the simplex.
Parameters
◆ clear_filtration()
void Gudhi::Simplex_tree< SimplexTreeOptions >::clear_filtration ( ) const
inline
Useful when initialize_filtration() has already been called and we perform an operation (say an insertion) that invalidates the cache.
Note
Not thread safe
◆ cofaces_simplex_range()
Cofaces_simplex_range Gudhi::Simplex_tree< SimplexTreeOptions >::cofaces_simplex_range ( const Simplex_handle  simplex,
int  codimension
) const
inline
Parameters
simplexrepresent the n-simplex of which we search the n+codimension cofaces
codimensionThe function returns the n+codimension-cofaces of the n-simplex. If codimension = 0, return all cofaces (equivalent of star function)
Returns
Vector of Simplex_tree::Simplex_handle (empty vector if no cofaces found) when SimplexTreeOptions::link_nodes_by_label is false.
Simplex_tree::Simplex_handle range for an optimized search for the coface of a simplex when SimplexTreeOptions::link_nodes_by_label is true.
Examples
mini_simplex_tree.cpp.
◆ complex_simplex_range()
Complex_simplex_range Gudhi::Simplex_tree< SimplexTreeOptions >::complex_simplex_range ( ) const
inline
In the Simplex_tree, the tree is traverse in a depth-first fashion. Consequently, simplices are ordered according to lexicographic order on the list of Vertex_handles of a simplex, read in increasing < order for Vertex_handles.
◆ decode_extended_filtration()
std::pair< Filtration_value, Extended_simplex_type > Gudhi::Simplex_tree< SimplexTreeOptions >::decode_extended_filtration ( Filtration_value  f,
const Extended_filtration_data &  efd
) const
inline
Precondition
This function should be called only if extend_filtration() has been called first!
Postcondition
The output filtration value is supposed to be the same, but might be a little different, than the original filtration value, due to the internal transformation (scaling to [-2,-1]) that is performed on the original filtration values during the computation of extended persistence.
Parameters
[in]fFiltration value of the simplex in the extended (i.e., modified) filtration.
[in]efdStructure containing the minimum and maximum values of the original filtration. This the output of extend_filtration().
Returns
A pair containing the original filtration value of the simplex as well as the simplex type.
◆ dimension() [1/2]
int Gudhi::Simplex_tree< SimplexTreeOptions >::dimension ( ) const
inline
This function is not constant time because it can recompute dimension if required (can be triggered by remove_maximal_simplex() or prune_above_filtration()).
Note
Not thread safe
◆ dimension() [2/2]
int Gudhi::Simplex_tree< SimplexTreeOptions >::dimension ( Simplex_handle  sh) const
inline
Must be different from null_simplex().
◆ edge_with_same_filtration()
Simplex_handle Gudhi::Simplex_tree< SimplexTreeOptions >::edge_with_same_filtration ( Simplex_handle  sh) const
inline
For a flag-complex built with expansion(), this is a way to invert the process and find out which edge had its filtration value propagated to sh. If several edges have the same filtration value, the one it returns is arbitrary.
Precondition
sh must have dimension at least 1.
◆ endpoints()
std::pair< Simplex_handle, Simplex_handle > Gudhi::Simplex_tree< SimplexTreeOptions >::endpoints ( Simplex_handle  sh) const
inline
Returns the two Simplex_handle corresponding to the endpoints of and edge. sh must point to a 1-dimensional simplex. This is an optimized version of the boundary computation.
◆ expansion()
void Gudhi::Simplex_tree< SimplexTreeOptions >::expansion ( int  max_dim)
inline
The expanded simplicial complex until dimension \(d\) attached to a graph \(G\) is the maximal simplicial complex of dimension at most \(d\) admitting the graph \(G\) as \(1\)-skeleton. The filtration value assigned to a simplex is the maximal filtration value of one of its edges.
The Simplex_tree must contain no simplex of dimension bigger than 1 when calling the method.
◆ expansion_with_blockers()
void Gudhi::Simplex_tree< SimplexTreeOptions >::expansion_with_blockers ( int  max_dim,
inline
Parameters
[in]max_dimExpansion maximal dimension value.
[in]block_simplexBlocker oracle. Its concept is bool block_simplex(Simplex_handle sh)
The function identifies a candidate simplex whose faces are all already in the complex, inserts it with a filtration value corresponding to the maximum of the filtration values of the faces, then calls block_simplex on a Simplex_handle for this new simplex. If block_simplex returns true, the simplex is removed, otherwise it is kept. Note that the evaluation of block_simplex is a good time to update the filtration value of the simplex if you want a customized value. The algorithm then proceeds with the next candidate.
Warning
several candidates of the same dimension may be inserted simultaneously before calling block_simplex, so if you examine the complex in block_simplex, you may hit a few simplices of the same dimension that have not been vetted by block_simplex yet, or have already been rejected but not yet removed.
◆ extend_filtration()
Extended_filtration_data Gudhi::Simplex_tree< SimplexTreeOptions >::extend_filtration ( )
inline
Postcondition
Note that after calling this function, the filtration values are actually modified. The function decode_extended_filtration() retrieves the original values and outputs the extended simplex type.
Exceptions
std::invalid_argumentIn debug mode if the Simplex tree contains a vertex with the largest Vertex_handle, as this method requires to create an extra vertex internally.
Returns
A data structure containing the maximum and minimum values of the original filtration. It is meant to be provided as input to decode_extended_filtration() in order to retrieve the original filtration values for each simplex.
◆ filtration()
static Filtration_value Gudhi::Simplex_tree< SimplexTreeOptions >::filtration ( Simplex_handle  sh)
inlinestatic
◆ filtration_simplex_range()
Filtration_simplex_range const & Gudhi::Simplex_tree< SimplexTreeOptions >::filtration_simplex_range ( Indexing_tag  = Indexing_tag()) const
inline
The filtration is a monotonic function \( f: \mathbf{K} \rightarrow \mathbb{R} \), i.e. if two simplices \(\tau\) and \(\sigma\) satisfy \(\tau \subseteq \sigma\) then \(f(\tau) \leq f(\sigma)\).
The method returns simplices ordered according to increasing filtration values. Ties are resolved by considering inclusion relation (subsimplices appear before their cofaces). If two simplices have same filtration value but are not comparable w.r.t. inclusion, lexicographic order is used.
The filtration must be valid. If the filtration has not been initialized yet, the method initializes it (i.e. order the simplices). If the complex has changed since the last time the filtration was initialized, please call clear_filtration() or initialize_filtration() to recompute it.
Note
Not thread safe
Examples
Alpha_complex_3d_from_points.cpp, Alpha_complex_from_off.cpp, Alpha_complex_from_points.cpp, CoordGIC.cpp, Fast_alpha_complex_from_off.cpp, FuncGIC.cpp, Nerve.cpp, VoronoiGIC.cpp, Weighted_alpha_complex_3d_from_points.cpp, and Weighted_alpha_complex_from_points.cpp.
◆ find()
Simplex_handle Gudhi::Simplex_tree< SimplexTreeOptions >::find ( const InputVertexRange &  s) const
inline
The type InputVertexRange must be a range of Vertex_handle on which we can call std::begin() function
Examples
◆ for_each_simplex()
void Gudhi::Simplex_tree< SimplexTreeOptions >::for_each_simplex ( Fun &&  fun) const
inline
Calls a function on each simplex. The order ensures that faces are visited before cofaces. While it is fine to modify the data of a simplex (filtration, key) in the function, modifying the structure itself (insertion, removal) is not supported.
Parameters
[in]funFunction that takes as argument a Simplex_handle and an int (representing the dimension of this simplex). It may return void or bool, and in the second case returning true means that the iteration will skip the children of this simplex (a subset of the cofaces).
◆ initialize_filtration()
void Gudhi::Simplex_tree< SimplexTreeOptions >::initialize_filtration ( bool  ignore_infinite_values = false) const
inline
It always recomputes the cache, even if one already exists.
Any insertion, deletion or change of filtration value invalidates this cache, which can be cleared with clear_filtration().
Note
Not thread safe
Examples
◆ insert_batch_vertices()
void Gudhi::Simplex_tree< SimplexTreeOptions >::insert_batch_vertices ( VertexRange const &  vertices,
Filtration_value  filt = 0
inline
Parameters
[in]verticesA range of Vertex_handle
[in]filtfiltration value of the new vertices (the same for all)
This may be faster than inserting the vertices one by one, especially in a random order. The complex does not need to be empty before calling this function. However, if a vertex is already present, its filtration value is not modified, unlike with other insertion functions.
◆ insert_edge_as_flag()
void Gudhi::Simplex_tree< SimplexTreeOptions >::insert_edge_as_flag ( Vertex_handle  u,
Vertex_handle  v,
int  dim_max,
std::vector< Simplex_handle > &  added_simplices
inline
Parameters
[in]u,vVertex_handle representing the new edge (v != u) or the new vertex (v == u).
[in]filFiltration value of the edge.
[in]dim_maxMaximal dimension of the expansion. If set to -1, the expansion goes as far as possible.
[out]added_simplicesContains at the end all new simplices induced by the insertion of the edge. The container is not emptied and new simplices are appended at the end.
Precondition
SimplexTreeOptions::link_nodes_by_label must be true.
When inserting the edge [u,v], the vertices u and v have to be already inserted in the simplex tree.
Warning
If the edges and vertices are not inserted in the order of their filtration values, the method make_filtration_non_decreasing() has to be called at the end of the insertions to restore the intended filtration. Note that even then, an edge has to be inserted after its vertices.
The method assumes that the given edge or vertex was not already contained in the simplex tree, so the behaviour is undefined if called on an existing simplex.
In term of edges in the graph, inserting edge [u,v] only affects the subtree rooted at u.
For a new node with label v, we first do a local expansion for computing the children of this new node, and then a standard expansion for its children. Nodes with label v (and their subtrees) already in the tree do not get affected.
Nodes with label u get affected only if a Node with label v is in their same siblings set. We then try to insert "punctually" v all over the subtree rooted at Node(u). Each insertion of a Node with v label induces a local expansion at this Node (as explained above) and a sequence of "punctual" insertion of Node(v) in the subtree rooted at sibling nodes of the new node, on its left.
◆ insert_graph()
void Gudhi::Simplex_tree< SimplexTreeOptions >::insert_graph ( const OneSkeletonGraph &  skel_graph)
inline
The Simplex_tree must contain no simplex when the method is called.
Inserts all vertices and edges given by a OneSkeletonGraph. OneSkeletonGraph must be a model of boost::VertexAndEdgeListGraph and boost::PropertyGraph.
The vertex filtration value is accessible through the property tag vertex_filtration_t. The edge filtration value is accessible through the property tag edge_filtration_t.
boost::graph_traits<OneSkeletonGraph>::vertex_descriptor must be Vertex_handle. boost::graph_traits<OneSkeletonGraph>::directed_category can be directed_tag (the fastest, the least RAM use), undirected_tag or even bidirected_tag.
If an edge appears with multiplicity, the function will arbitrarily pick one representative to read the filtration value.
◆ insert_simplex()
std::pair< Simplex_handle, bool > Gudhi::Simplex_tree< SimplexTreeOptions >::insert_simplex ( const InputVertexRange &  simplex,
Filtration_value  filtration = 0
inline
Parameters
[in]simplexrange of Vertex_handles, representing the vertices of the new simplex
[in]filtrationthe filtration value assigned to the new simplex.
Returns
If the new simplex is inserted successfully (i.e. it was not in the simplicial complex yet) the bool is set to true and the Simplex_handle is the handle assigned to the new simplex. If the insertion fails (the simplex is already there), the bool is set to false. If the insertion fails and the simplex already in the complex has a filtration value strictly bigger than 'filtration', we assign this simplex with the new value 'filtration', and set the Simplex_handle field of the output pair to the Simplex_handle of the simplex. Otherwise, we set the Simplex_handle part to null_simplex.
All subsimplices do not necessary need to be already in the simplex tree to proceed to an insertion. However, the property of being a simplicial complex will be violated. This allows us to insert a stream of simplices contained in a simplicial complex without considering any order on them.
The filtration value assigned to the new simplex must preserve the monotonicity of the filtration.
The type InputVertexRange must be a range for which .begin() and .end() return input iterators, with 'value_type' Vertex_handle.
Examples
plain_homology.cpp.
◆ insert_simplex_and_subfaces()
std::pair< Simplex_handle, bool > Gudhi::Simplex_tree< SimplexTreeOptions >::insert_simplex_and_subfaces ( const InputVertexRange &  Nsimplex,
inline
Parameters
[in]Nsimplexrange of Vertex_handles, representing the vertices of the new N-simplex
[in]filtrationthe filtration value assigned to the new N-simplex.
Returns
Examples
mini_simplex_tree.cpp, and plain_homology.cpp.
◆ key()
static Simplex_key Gudhi::Simplex_tree< SimplexTreeOptions >::key ( Simplex_handle  sh)
inlinestatic
If no key has been assigned, returns null_key().
Precondition
SimplexTreeOptions::store_key
◆ make_filtration_non_decreasing()
bool Gudhi::Simplex_tree< SimplexTreeOptions >::make_filtration_non_decreasing ( )
inline
Returns
True if any filtration value was modified, false if the filtration was already non-decreasing.
If a simplex has a NaN filtration value, it is considered lower than any other defined filtration value.
◆ maybe_initialize_filtration()
void Gudhi::Simplex_tree< SimplexTreeOptions >::maybe_initialize_filtration ( ) const
inline
Automatically called by filtration_simplex_range().
Note
Not thread safe
◆ minimal_simplex_with_same_filtration()
Simplex_handle Gudhi::Simplex_tree< SimplexTreeOptions >::minimal_simplex_with_same_filtration ( Simplex_handle  sh) const
inline
For a filtration built with make_filtration_non_decreasing(), this is a way to invert the process and find out which simplex had its filtration value propagated to sh. If several minimal (for inclusion) simplices have the same filtration value, the one it returns is arbitrary, and it is not guaranteed to be the one with smallest dimension.
◆ null_simplex()
static Simplex_handle Gudhi::Simplex_tree< SimplexTreeOptions >::null_simplex ( )
inlinestatic
One can call filtration(null_simplex()).
◆ num_simplices()
◆ operator=()
Simplex_tree & Gudhi::Simplex_tree< SimplexTreeOptions >::operator= ( Simplex_tree< SimplexTreeOptions > &&  complex_source)
inline
Exceptions
◆ print_hasse()
void Gudhi::Simplex_tree< SimplexTreeOptions >::print_hasse ( std::ostream &  os) const
inline
Each row in the file correspond to a simplex. A line is written: dim idx_1 ... idx_k fil where dim is the dimension of the simplex, idx_1 ... idx_k are the row index (starting from 0) of the simplices of the boundary of the simplex, and fil is its filtration value.
Note
Not thread safe
◆ prune_above_dimension()
bool Gudhi::Simplex_tree< SimplexTreeOptions >::prune_above_dimension ( int  dimension)
inline
Parameters
[in]dimensionMaximum dimension value.
Returns
True if any simplex was removed, false if all simplices already had a value below the dimension.
◆ prune_above_filtration()
bool Gudhi::Simplex_tree< SimplexTreeOptions >::prune_above_filtration ( Filtration_value  filtration)
inline
Parameters
[in]filtrationMaximum threshold value.
Returns
True if any simplex was removed, false if all simplices already had a value below the threshold.
Postcondition
Note that the dimension of the simplicial complex may be lower after calling prune_above_filtration() than it was before. However, upper_bound_dimension() will return the old value, which remains a valid upper bound. If you care, you can call dimension() to recompute the exact dimension.
◆ remove_maximal_simplex()
void Gudhi::Simplex_tree< SimplexTreeOptions >::remove_maximal_simplex ( Simplex_handle  sh)
inline
Parameters
[in]shSimplex handle on the maximal simplex to remove.
Precondition
Please check the simplex has no coface before removing it.
Exceptions
std::invalid_argumentIn debug mode, if sh has children.
Postcondition
Note that the dimension of the simplicial complex may be lower after calling remove_maximal_simplex() than it was before. However, upper_bound_dimension() will return the old value, which remains a valid upper bound. If you care, you can call dimension() to recompute the exact dimension.
◆ reset_filtration()
void Gudhi::Simplex_tree< SimplexTreeOptions >::reset_filtration ( Filtration_value  filt_value,
int  min_dim = 0
inline
Parameters
[in]filt_valueThe new filtration value.
[in]min_dimThe minimal dimension. Default value is 0.
◆ root() [1/2]
Siblings * Gudhi::Simplex_tree< SimplexTreeOptions >::root ( )
inline
Returns a pointer to the root nodes of the simplex tree.
◆ root() [2/2]
const Siblings * Gudhi::Simplex_tree< SimplexTreeOptions >::root ( ) const
inline
◆ self_siblings() [1/2]
Siblings * Gudhi::Simplex_tree< SimplexTreeOptions >::self_siblings ( SimplexHandle  sh)
inline
Returns the Siblings containing a simplex.
◆ self_siblings() [2/2]
Siblings const * Gudhi::Simplex_tree< SimplexTreeOptions >::self_siblings ( SimplexHandle  sh) const
inline
◆ set_dimension()
void Gudhi::Simplex_tree< SimplexTreeOptions >::set_dimension ( int  dimension,
bool  exact = true
inline
If exact is false, dimension is only an upper bound on the dimension of the complex. This function must be used with caution because it disables or limits the on-demand recomputation of the dimension (the need for recomputation can be caused by remove_maximal_simplex() or prune_above_filtration()).
◆ simplex()
Simplex_handle Gudhi::Simplex_tree< SimplexTreeOptions >::simplex ( Simplex_key  idx) const
inline
The filtration must be initialized.
Note
Not thread safe
◆ simplex_vertex_range()
Simplex_vertex_range Gudhi::Simplex_tree< SimplexTreeOptions >::simplex_vertex_range ( Simplex_handle  sh) const
inline
The order in which the vertices are visited is the decreasing order for < on Vertex_handles, which is consequently equal to \((-1)^{\text{dim} \sigma}\) the canonical orientation on the simplex.
Examples
Alpha_complex_3d_from_points.cpp, Alpha_complex_from_off.cpp, Alpha_complex_from_points.cpp, CoordGIC.cpp, Fast_alpha_complex_from_off.cpp, FuncGIC.cpp, Nerve.cpp, VoronoiGIC.cpp, Weighted_alpha_complex_3d_from_points.cpp, Weighted_alpha_complex_from_points.cpp, and mini_simplex_tree.cpp.
◆ skeleton_simplex_range()
Skeleton_simplex_range Gudhi::Simplex_tree< SimplexTreeOptions >::skeleton_simplex_range ( int  dim) const
inline
The \(d\)-skeleton of a simplicial complex \(\mathbf{K}\) is the simplicial complex containing the simplices of \(\mathbf{K}\) of dimension at most \(d\).
Parameters
[in]dimThe maximal dimension of the simplices in the skeleton.
The simplices are ordered according to lexicographic order on the list of Vertex_handles of a simplex, read in increasing < order for Vertex_handles.
◆ star_simplex_range()
Cofaces_simplex_range Gudhi::Simplex_tree< SimplexTreeOptions >::star_simplex_range ( const Simplex_handle  simplex) const
inline
Parameters
simplexrepresent the simplex of which we search the star
Returns
Vector of Simplex_tree::Simplex_handle (empty vector if no star found) when SimplexTreeOptions::link_nodes_by_label is false.
Simplex_tree::Simplex_handle range for an optimized search for the star of a simplex when SimplexTreeOptions::link_nodes_by_label is true.
◆ upper_bound_dimension()
int Gudhi::Simplex_tree< SimplexTreeOptions >::upper_bound_dimension ( ) const
inline
Note
Not thread safe
◆ vertex_with_same_filtration()
Vertex_handle Gudhi::Simplex_tree< SimplexTreeOptions >::vertex_with_same_filtration ( Simplex_handle  sh) const
inline
For a lower-star filtration built with make_filtration_non_decreasing(), this is a way to invert the process and find out which vertex had its filtration value propagated to sh. If several vertices have the same filtration value, the one it returns is arbitrary.
The documentation for this class was generated from the following file:
