Multi_field_shared.h File Reference
Contains the Gudhi::persistence_fields::Shared_multi_field_element class. More...
Go to the source code of this file.
Classes
class  Gudhi::persistence_fields::Shared_multi_field_element
 Class representing an element of a multi-field. If each instantiation of the class can represent another element, they all share the same characteristics. That is if the characteristics are set for one, they will be set for all the others. The characteristics can be set before instantiating the elements with the static Shared_multi_field_element::initialize method. More...
Namespaces
namespace  Gudhi
 Gudhi namespace.
namespace  Gudhi::persistence_fields
 Field namespace.
Detailed Description
Author
Hannah Schreiber, Clément Maria
