Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_fields Namespace Reference
Field namespace. More...
Classes
class  Multi_field_element
 Class representing an element of a multi-field. The characteristics will corresponds to all prime numbers in the interval given as template. More...
class  Multi_field_operators
 Class defining operators for a multi-field with "consecutive" charateristic range. More...
class  Shared_multi_field_element
 Class representing an element of a multi-field. If each instanciation of the class can represent another element, they all share the same characteritics. That is if the characteristics are set for one, they will be set for all the others. The characteristics can be set before instianciating the elements with the static Shared_multi_field_element::initialize method. More...
class  Multi_field_element_with_small_characteristics
 Class representing an element of a multi-field, such that the product of all characteristics fits into the given Unsigned_integer_type template argument. The characteristics will corresponds to all prime numbers in the interval given as other template arguments. More...
class  Multi_field_operators_with_small_characteristics
 Class defining operators for a multi-field with "consecutive" charateristic range, such that productOfAllCharacteristics ^ 2 fits into an unsigned int. More...
class  Shared_multi_field_element_with_small_characteristics
 Class representing an element of a multi-field, such that productOfAllCharacteristics ^ 2 fits into the given Unsigned_integer_type template argument. If each instanciation of the class can represent another element, they all share the same characteritics. That is if the characteristics are set for one, they will be set for all the others. The characteristics can be set before instanciating the elements with the static Shared_multi_field_element_with_small_characteristics::initialize method. More...
class  Z2_field_element
 Class representing an element of the \( \mathbb{F}_2 \) field. More...
class  Z2_field_operators
 Class defining operators for the \( \mathbb{F}_2 \) field. More...
class  Zp_field_element
 Class representing an element of the \( \mathbb{F}_p \) field for any prime number \( p \). More...
class  Zp_field_operators
 Class defining operators for the \( \mathbb{F}_p \) field for any prime number \( p \). More...
class  Shared_Zp_field_element
 Class representing an element of the \( \mathbb{F}_p \) field for any prime number \( p \). If each instanciation of the class can represent another element, they all share the same characteritics. That is if the characteristics are set for one, they will be set for all the others. The characteristics can be set before instianciating the elements with the static Shared_Zp_field_element::initialize method. More...
Detailed Description
Field namespace.
