Gudhi::persistence_fields::Z2_field_element Class Reference
Class representing an element of the \( \mathbb{F}_2 \) field. More...
Public Types
using element_type = bool
Public Member Functions
 Z2_field_element ()
 Default constructor.
template<typename Integer_type , class = isInteger<Integer_type>>
 Z2_field_element (Integer_type element)
 Constructor setting the element to the given value. More...
 Z2_field_element (const Z2_field_element &toCopy)
 Copy constructor. More...
 Z2_field_element (Z2_field_element &&toMove) noexcept
 Move constructor. More...
Z2_field_elementoperator= (Z2_field_element other)
 Assign operator.
Z2_field_elementoperator= (const unsigned int value)
 Assign operator.
 operator unsigned int () const
 Casts the element into an unsigned int.
Z2_field_element get_inverse () const
 Returns the inverse of the element. More...
std::pair< Z2_field_element, unsigned int > get_partial_inverse (unsigned int productOfCharacteristics) const
 For interface purposes with multi-fields. Returns the inverse together with the second argument. More...
element_type get_value () const
 Returns the value of the element. More...
Static Public Member Functions
static Z2_field_element get_additive_identity ()
 Returns the additive identity of the field. More...
static Z2_field_element get_multiplicative_identity ()
 Returns the multiplicative identity of the field. More...
static Z2_field_element get_partial_multiplicative_identity ([[maybe_unused]] unsigned int productOfCharacteristics)
 For interface purposes with multi-fields. Returns the multiplicative identity of the field. More...
static constexpr unsigned int get_characteristic ()
 Returns the characteristic of the field, that is 2. More...
Friends
void operator+= (Z2_field_element &f1, Z2_field_element const &f2)
 operator+=
Z2_field_element operator+ (Z2_field_element f1, Z2_field_element const &f2)
 operator+
void operator+= (Z2_field_element &f, const Integer_type &v)
 operator+= More...
Z2_field_element operator+ (Z2_field_element f, const Integer_type &v)
 operator+ More...
Integer_type operator+ (const Integer_type &v, const Z2_field_element &f)
 operator+ More...
void operator-= (Z2_field_element &f1, Z2_field_element const &f2)
 operator-=
Z2_field_element operator- (Z2_field_element f1, Z2_field_element const &f2)
 operator-
void operator-= (Z2_field_element &f, const Integer_type &v)
 operator-= More...
Z2_field_element operator- (Z2_field_element f, const Integer_type &v)
 operator- More...
Integer_type operator- (const Integer_type v, Z2_field_element const &f)
 operator- More...
void operator*= (Z2_field_element &f1, Z2_field_element const &f2)
 operator*=
Z2_field_element operator* (Z2_field_element f1, Z2_field_element const &f2)
 operator*
void operator*= (Z2_field_element &f, const Integer_type &v)
 operator*= More...
Z2_field_element operator* (Z2_field_element f, const Integer_type &v)
 operator* More...
Integer_type operator* (const Integer_type &v, Z2_field_element const &f)
 operator* More...
bool operator== (const Z2_field_element &f1, const Z2_field_element &f2)
 operator==
bool operator== (const Integer_type &v, const Z2_field_element &f)
 operator== More...
bool operator== (const Z2_field_element &f, const Integer_type &v)
 operator== More...
bool operator!= (const Z2_field_element &f1, const Z2_field_element &f2)
 operator!=
bool operator!= (const Integer_type v, const Z2_field_element &f)
 operator!= More...
bool operator!= (const Z2_field_element &f, const Integer_type v)
 operator!= More...
void swap (Z2_field_element &f1, Z2_field_element &f2)
 Swap operator.
Detailed Description
Examples
example_field_operations.cpp.
Member Typedef Documentation
◆ element_type
Type for the elements in the field.
Constructor & Destructor Documentation
◆ Z2_field_element() [1/3]
template<typename Integer_type , class >
Gudhi::persistence_fields::Z2_field_element::Z2_field_element ( Integer_type  element)
inline
Template Parameters
Integer_typeA native integer type. Should be able to contain the characteristic.
Parameters
elementValue of the element.
◆ Z2_field_element() [2/3]
Gudhi::persistence_fields::Z2_field_element::Z2_field_element ( const Z2_field_element toCopy)
inline
Copy constructor.
Parameters
toCopyElement to copy.
◆ Z2_field_element() [3/3]
Gudhi::persistence_fields::Z2_field_element::Z2_field_element ( Z2_field_element &&  toMove)
inlinenoexcept
Move constructor.
Parameters
toMoveElement to move.
Member Function Documentation
◆ get_additive_identity()
Z2_field_element Gudhi::persistence_fields::Z2_field_element::get_additive_identity ( )
inlinestatic
Returns
false.
◆ get_characteristic()
constexpr unsigned int Gudhi::persistence_fields::Z2_field_element::get_characteristic ( )
inlinestaticconstexpr
Returns
2.
◆ get_inverse()
Z2_field_element Gudhi::persistence_fields::Z2_field_element::get_inverse ( ) const
inline
Returns
The inverse.
◆ get_multiplicative_identity()
Z2_field_element Gudhi::persistence_fields::Z2_field_element::get_multiplicative_identity ( )
inlinestatic
Returns
true.
◆ get_partial_inverse()
std::pair< Z2_field_element, unsigned int > Gudhi::persistence_fields::Z2_field_element::get_partial_inverse ( unsigned int  productOfCharacteristics) const
inline
Parameters
productOfCharacteristicsSome value.
Returns
Pair whose first element is the inverse of e and the second element is productOfCharacteristics.
◆ get_partial_multiplicative_identity()
Z2_field_element Gudhi::persistence_fields::Z2_field_element::get_partial_multiplicative_identity ( [[maybe_unused] ] unsigned int  productOfCharacteristics)
inlinestatic
Parameters
Returns
true.
◆ get_value()
Z2_field_element::element_type Gudhi::persistence_fields::Z2_field_element::get_value ( ) const
inline
Returns
Friends And Related Function Documentation
◆ operator!= [1/2]
bool operator!= ( const Integer_type  v,
const Z2_field_element f
friend
operator!=
Template Parameters
Integer_typeA native integer type: int, unsigned int, long int, bool, etc.
◆ operator!= [2/2]
bool operator!= ( const Z2_field_element f,
friend
operator!=
Template Parameters
◆ operator* [1/2]
Integer_type operator* ( const Integer_type &  v,
Z2_field_element const &  f
friend
operator*
Template Parameters
◆ operator* [2/2]
Z2_field_element operator* ( Z2_field_element  f,
friend
operator*
Template Parameters
◆ operator*=
void operator*= ( Z2_field_element f,
friend
operator*=
Template Parameters
◆ operator+ [1/2]
Integer_type operator+ ( const Integer_type &  v,
friend
operator+
Template Parameters
◆ operator+ [2/2]
Z2_field_element operator+ ( Z2_field_element  f,
friend
operator+
Template Parameters
◆ operator+=
void operator+= ( Z2_field_element f,
friend
operator+=
Template Parameters
◆ operator- [1/2]
Integer_type operator- ( const Integer_type  v,
friend
operator-
Template Parameters
◆ operator- [2/2]
Z2_field_element operator- ( Z2_field_element  f,
friend
operator-
Template Parameters
◆ operator-=
void operator-= ( Z2_field_element f,
friend
operator-=
Template Parameters
◆ operator== [1/2]
bool operator== ( const Integer_type &  v,
friend
operator==
Template Parameters
◆ operator== [2/2]
bool operator== ( const Z2_field_element f,
friend
operator==
Template Parameters
The documentation for this class was generated from the following file:
