template<complexity Complexity = complexity::SAFE, bool Weighted = false, bool Periodic = false>
class Gudhi::alpha_complex::Alpha_complex_3d< Complexity, Weighted, Periodic >
Alpha complex data structure for 3d specific case.
The data structure is constructing a CGAL 3D Alpha Shapes from a range of points (can be read from an OFF file, cf. Points_off_reader). Duplicate points are inserted once in the Alpha_complex.
- Template Parameters
For the weighted version, weights values are explained on CGAL Alpha shapes 3d and Regular triangulation documentation.
For the periodic version, refer to the CGAL’s 3D Periodic Triangulations User Manual for more details. The periodicity is defined by an iso-oriented cuboid with diagonal opposite vertices (x_min, y_min, z_min) and (x_max, y_max, z_max).
Please refer to Alpha complex for examples.
- Examples
- Alpha_complex_3d_from_points.cpp, Weighted_alpha_complex_3d_from_points.cpp, and alpha_complex_3d_persistence.cpp.
template<typename InputPointRange , typename WeightRange >
Alpha_complex constructor from a list of points and associated weights.
- Exceptions
std::invalid_argument | In debug mode, if points and weights do not have the same size. |
- Parameters
[in] | points | Range of points to triangulate. Points must be in Alpha_complex_3d::Bare_point_3 . |
[in] | weights | Range of weights on points. Weights shall be in double. |
- Precondition
- Available if Alpha_complex_3d is Weighted and not Periodic.
The type InputPointRange must be a range for which std::begin and std::end return input iterators on a Alpha_complex_3d::Bare_point_3
. The type WeightRange must be a range for which std::begin and std::end return an input iterator on a double.
template<typename InputPointRange >
Alpha_complex constructor from a list of points and an iso-cuboid coordinates.
- Exceptions
std::invalid_argument | In debug mode, if the size of the cuboid in every directions is not the same. |
- Parameters
[in] | points | Range of points to triangulate. Points must be in Alpha_complex_3d::Point_3 . |
[in] | x_min | Iso-oriented cuboid x_min. |
[in] | y_min | Iso-oriented cuboid y_min. |
[in] | z_min | Iso-oriented cuboid z_min. |
[in] | x_max | Iso-oriented cuboid x_max. |
[in] | y_max | Iso-oriented cuboid y_max. |
[in] | z_max | Iso-oriented cuboid z_max. |
- Precondition
- Available if Alpha_complex_3d is Periodic.
The type InputPointRange must be a range for which std::begin and std::end return input iterators on a Alpha_complex_3d::Point_3
- Note
- In weighted version, please check weights are greater than zero, and lower than 1/64*cuboid length squared.
Alpha_complex constructor from a list of points, associated weights and an iso-cuboid coordinates.
- Exceptions
std::invalid_argument | In debug mode, if a weight is negative, zero, or greater than 1/64*cuboid length squared. |
- Parameters
- Precondition
- Available if Alpha_complex_3d is Weighted and Periodic.
. The type WeightRange must be a range for which std::begin and std::end return an input iterator on a double. The type of x_min, y_min, z_min, x_max, y_max and z_max must be a double.
