Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Alpha_complex_3d.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Vincent Rouvreau
4  *
5  * Copyright (C) 2018 Inria
6  *
7  * Modification(s):
8  * - 2019/08 Vincent Rouvreau: Fix issue #10 for CGAL and Eigen3
9  * - YYYY/MM Author: Description of the modification
10  */
11
12 #ifndef ALPHA_COMPLEX_3D_H_
13 #define ALPHA_COMPLEX_3D_H_
14
15 #include <boost/variant.hpp>
16 #include <boost/range/size.hpp>
17 #include <boost/range/combine.hpp>
18 #include <boost/range/adaptor/transformed.hpp>
19
20 #include <gudhi/Debug_utils.h>
21 #include <gudhi/Alpha_complex_options.h>
22
23 #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
24 #include <CGAL/Exact_predicates_exact_constructions_kernel.h>
25 #include <CGAL/Delaunay_triangulation_3.h>
26 #include <CGAL/Periodic_3_Delaunay_triangulation_traits_3.h>
27 #include <CGAL/Periodic_3_Delaunay_triangulation_3.h>
28 #include <CGAL/Periodic_3_regular_triangulation_traits_3.h>
29 #include <CGAL/Periodic_3_regular_triangulation_3.h>
30 #include <CGAL/Regular_triangulation_3.h>
31 #include <CGAL/Alpha_shape_3.h>
32 #include <CGAL/Alpha_shape_cell_base_3.h>
33 #include <CGAL/Alpha_shape_vertex_base_3.h>
34
35 #include <CGAL/Object.h>
36 #include <CGAL/tuple.h>
37 #include <CGAL/iterator.h>
38 #include <CGAL/version.h> // for CGAL_VERSION_NR
39
40 #include <boost/container/static_vector.hpp>
41
42 #include <iostream>
43 #include <vector>
44 #include <unordered_map>
45 #include <stdexcept>
46 #include <cstddef> // for std::size_t
47 #include <memory> // for std::unique_ptr
48 #include <type_traits> // for std::conditional and std::enable_if
49 #include <limits> // for numeric_limits<>
50
51 // Make compilation fail - required for external projects - https://github.com/GUDHI/gudhi-devel/issues/10
52 #if CGAL_VERSION_NR < 1041101000
53 # error Alpha_complex_3d is only available for CGAL >= 4.11
54 #endif
55
56 namespace Gudhi {
57
58 namespace alpha_complex {
59
60 // Value_from_iterator returns the filtration value from an iterator on alpha shapes values
61 //
62 // FAST SAFE EXACT
63 // CGAL::to_double(*iterator) CGAL::to_double(*iterator) CGAL::to_double(iterator->exact())
64
65 template <complexity Complexity>
66 struct Value_from_iterator {
67  template <typename Iterator>
68  static double perform(Iterator it) {
69  // Default behaviour
70  return CGAL::to_double(*it);
71  }
72 };
73
74 template <>
75 struct Value_from_iterator<complexity::EXACT> {
76  template <typename Iterator>
77  static double perform(Iterator it) {
78  return CGAL::to_double(it->exact());
79  }
80 };
81
117 template <complexity Complexity = complexity::SAFE, bool Weighted = false, bool Periodic = false>
119  // Epick = Exact_predicates_inexact_constructions_kernel
120  // Epeck = Exact_predicates_exact_constructions_kernel
121  // Exact_alpha_comparison_tag = exact version of CGAL Alpha_shape_3 and of its objects (Alpha_shape_vertex_base_3 and
122  // Alpha_shape_cell_base_3). Not available if weighted or periodic.
123  // Can be CGAL::Tag_false or CGAL::Tag_true. Default is False.
124  // cf. https://doc.cgal.org/latest/Alpha_shapes_3/classCGAL_1_1Alpha__shape__3.html
125  //
126  // We could use Epick + CGAL::Tag_true for not weighted nor periodic, but during benchmark, we found a bug
127  // https://github.com/CGAL/cgal/issues/3460
128  // This is the reason we only use Epick + CGAL::Tag_false, or Epeck
129  //
130  // FAST SAFE EXACT
131  // Epick + CGAL::Tag_false Epeck Epeck
132  using Predicates = typename std::conditional<(Complexity == complexity::FAST),
133  CGAL::Exact_predicates_inexact_constructions_kernel,
134  CGAL::Exact_predicates_exact_constructions_kernel>::type;
135
136  // The other way to do a conditional type. Here there are 3 possibilities
137  template <typename Predicates, bool Weighted_version, bool Periodic_version>
138  struct Kernel_3 {};
139
140  template <typename Predicates, bool Is_periodic>
141  struct Kernel_3<Predicates, Is_periodic, false> {
142  using Kernel = Predicates;
143  };
144
145  template <typename Predicates>
146  struct Kernel_3<Predicates, false, true> {
147  using Kernel = CGAL::Periodic_3_Delaunay_triangulation_traits_3<Predicates>;
148  };
149  template <typename Predicates>
150  struct Kernel_3<Predicates, true, true> {
151  using Kernel = CGAL::Periodic_3_regular_triangulation_traits_3<Predicates>;
152  };
153
154  public:
155  using Kernel = typename Kernel_3<Predicates, Weighted, Periodic>::Kernel;
156
157  private:
158  using TdsVb = typename std::conditional<Periodic, CGAL::Periodic_3_triangulation_ds_vertex_base_3<>,
159  CGAL::Triangulation_ds_vertex_base_3<>>::type;
160
161  using Tvb = typename std::conditional<Weighted, CGAL::Regular_triangulation_vertex_base_3<Kernel, TdsVb>,
162  CGAL::Triangulation_vertex_base_3<Kernel, TdsVb>>::type;
163
164  using Vb = CGAL::Alpha_shape_vertex_base_3<Kernel, Tvb>;
165
166  using TdsCb = typename std::conditional<Periodic, CGAL::Periodic_3_triangulation_ds_cell_base_3<>,
167  CGAL::Triangulation_ds_cell_base_3<>>::type;
168
169  using Tcb = typename std::conditional<Weighted, CGAL::Regular_triangulation_cell_base_3<Kernel, TdsCb>,
170  CGAL::Triangulation_cell_base_3<Kernel, TdsCb>>::type;
171
172  using Cb = CGAL::Alpha_shape_cell_base_3<Kernel, Tcb>;
173  using Tds = CGAL::Triangulation_data_structure_3<Vb, Cb>;
174
175  // The other way to do a conditional type. Here there 4 possibilities, cannot use std::conditional
176  template <typename Kernel, typename Tds, bool Weighted_version, bool Periodic_version>
177  struct Triangulation_3 {};
178
179  template <typename Kernel, typename Tds>
180  struct Triangulation_3<Kernel, Tds, false, false> {
181  using Dt = CGAL::Delaunay_triangulation_3<Kernel, Tds>;
182  using Weighted_point_3 = void;
183  };
184  template <typename Kernel, typename Tds>
185  struct Triangulation_3<Kernel, Tds, true, false> {
186  using Dt = CGAL::Regular_triangulation_3<Kernel, Tds>;
187  using Weighted_point_3 = typename Dt::Weighted_point;
188  };
189  template <typename Kernel, typename Tds>
190  struct Triangulation_3<Kernel, Tds, false, true> {
191  using Dt = CGAL::Periodic_3_Delaunay_triangulation_3<Kernel, Tds>;
192  using Weighted_point_3 = void;
193  };
194  template <typename Kernel, typename Tds>
195  struct Triangulation_3<Kernel, Tds, true, true> {
196  using Dt = CGAL::Periodic_3_regular_triangulation_3<Kernel, Tds>;
197  using Weighted_point_3 = typename Dt::Weighted_point;
198  };
199
207  using Dt = typename Triangulation_3<Kernel, Tds, Weighted, Periodic>::Dt;
208
209  public:
215  using Alpha_shape_3 = CGAL::Alpha_shape_3<Dt>;
216
219  using FT = typename Alpha_shape_3::FT;
220
230  using Bare_point_3 = typename Kernel::Point_3;
231
243  using Weighted_point_3 = typename Triangulation_3<Kernel, Tds, Weighted, Periodic>::Weighted_point_3;
244
248  using Point_3 = typename Alpha_shape_3::Point;
249
250  private:
251  using Dispatch =
252  CGAL::Dispatch_output_iterator<CGAL::cpp11::tuple<CGAL::Object, FT>,
253  CGAL::cpp11::tuple<std::back_insert_iterator<std::vector<CGAL::Object>>,
254  std::back_insert_iterator<std::vector<FT>>>>;
255
256  using Cell_handle = typename Alpha_shape_3::Cell_handle;
257  using Facet = typename Alpha_shape_3::Facet;
258  using Edge = typename Alpha_shape_3::Edge;
259  using Alpha_vertex_handle = typename Alpha_shape_3::Vertex_handle;
260  using Vertex_list = boost::container::static_vector<Alpha_vertex_handle, 4>;
261
262  public:
272  template <typename InputPointRange>
273  Alpha_complex_3d(const InputPointRange& points) {
274  static_assert(!Periodic, "This constructor is not available for periodic versions of Alpha_complex_3d");
275
276  alpha_shape_3_ptr_ = std::make_unique<Alpha_shape_3>(
277  std::begin(points), std::end(points), 0, Alpha_shape_3::GENERAL);
278  }
279
294  template <typename InputPointRange, typename WeightRange>
295  Alpha_complex_3d(const InputPointRange& points, WeightRange weights) {
296  static_assert(Weighted, "This constructor is not available for non-weighted versions of Alpha_complex_3d");
297  static_assert(!Periodic, "This constructor is not available for periodic versions of Alpha_complex_3d");
298  // FIXME: this test is only valid if we have a forward range
299  GUDHI_CHECK(boost::size(weights) == boost::size(points),
300  std::invalid_argument("Points number in range different from weights range number"));
301
302  auto weighted_points_3 = boost::range::combine(points, weights)
303  | boost::adaptors::transformed([](auto const&t){return Weighted_point_3(boost::get<0>(t), boost::get<1>(t));});
304
305  alpha_shape_3_ptr_ = std::make_unique<Alpha_shape_3>(
306  std::begin(weighted_points_3), std::end(weighted_points_3), 0, Alpha_shape_3::GENERAL);
307  }
308
329  template <typename InputPointRange>
330  Alpha_complex_3d(const InputPointRange& points, FT x_min, FT y_min,
331  FT z_min, FT x_max, FT y_max, FT z_max) {
332  static_assert(Periodic, "This constructor is not available for non-periodic versions of Alpha_complex_3d");
333  // Checking if the cuboid is the same in x,y and z direction. If not, CGAL will not process it.
334  GUDHI_CHECK(
335  (x_max - x_min == y_max - y_min) && (x_max - x_min == z_max - z_min) && (z_max - z_min == y_max - y_min),
336  std::invalid_argument("The size of the cuboid in every directions is not the same."));
337
338  // Define the periodic cube
339  Dt pdt(typename Kernel::Iso_cuboid_3(x_min, y_min, z_min, x_max, y_max, z_max));
340  // Heuristic for inserting large point sets (if pts is reasonably large)
341  pdt.insert(std::begin(points), std::end(points), true);
342  // As pdt won't be modified anymore switch to 1-sheeted cover if possible
343  if (!pdt.is_triangulation_in_1_sheet()) {
344  throw std::invalid_argument("Unable to construct a triangulation within a single periodic domain.");
345  }
346  pdt.convert_to_1_sheeted_covering();
347
348  // alpha shape construction from points. CGAL has a strange behavior in REGULARIZED mode. This is the default mode
349  // Maybe need to set it to GENERAL mode
350  alpha_shape_3_ptr_ = std::make_unique<Alpha_shape_3>(pdt, 0, Alpha_shape_3::GENERAL);
351  }
352
377  template <typename InputPointRange, typename WeightRange>
378  Alpha_complex_3d(const InputPointRange& points, WeightRange weights, FT x_min, FT y_min,
379  FT z_min, FT x_max, FT y_max, FT z_max) {
380  static_assert(Weighted, "This constructor is not available for non-weighted versions of Alpha_complex_3d");
381  static_assert(Periodic, "This constructor is not available for non-periodic versions of Alpha_complex_3d");
382  // FIXME: this test is only valid if we have a forward range
383  GUDHI_CHECK(boost::size(weights) == boost::size(points),
384  std::invalid_argument("Points number in range different from weights range number"));
385  // Checking if the cuboid is the same in x,y and z direction. If not, CGAL will not process it.
386  GUDHI_CHECK(
387  (x_max - x_min == y_max - y_min) && (x_max - x_min == z_max - z_min) && (z_max - z_min == y_max - y_min),
388  std::invalid_argument("The size of the cuboid in every directions is not the same."));
389
390 #ifdef GUDHI_DEBUG
391  // Defined in GUDHI_DEBUG to avoid unused variable warning for GUDHI_CHECK
392  FT maximal_possible_weight = 0.015625 * (x_max - x_min) * (x_max - x_min);
393 #endif
394
395  auto weighted_points_3 = boost::range::combine(points, weights)
396  | boost::adaptors::transformed([=](auto const&t){
397  auto w = boost::get<1>(t);
398  GUDHI_CHECK((w < maximal_possible_weight) && (w >= 0),
399  std::invalid_argument("Invalid weight " + std::to_string(w) +
400  ". Must be non-negative and less than maximal possible weight = 1/64*cuboid length squared."));
401  return Weighted_point_3(boost::get<0>(t), w);
402  });
403
404  // Define the periodic cube
405  Dt pdt(typename Kernel::Iso_cuboid_3(x_min, y_min, z_min, x_max, y_max, z_max));
406  // Heuristic for inserting large point sets (if pts is reasonably large)
407  pdt.insert(std::begin(weighted_points_3), std::end(weighted_points_3), true);
408  // As pdt won't be modified anymore switch to 1-sheeted cover if possible
409  if (!pdt.is_triangulation_in_1_sheet()) {
410  throw std::invalid_argument("Unable to construct a triangulation within a single periodic domain.");
411  }
412  pdt.convert_to_1_sheeted_covering();
413
414  // alpha shape construction from points. CGAL has a strange behavior in REGULARIZED mode. This is the default mode
415  // Maybe need to set it to GENERAL mode
416  alpha_shape_3_ptr_ = std::make_unique<Alpha_shape_3>(pdt, 0, Alpha_shape_3::GENERAL);
417  }
418
433  template <typename SimplicialComplexForAlpha3d,
436  Filtration_value max_alpha_square = std::numeric_limits<Filtration_value>::infinity()) {
437  if (complex.num_vertices() > 0) {
438  std::cerr << "Alpha_complex_3d create_complex - complex is not empty\n";
439  return false; // ----- >>
440  }
441
442  using Complex_vertex_handle = typename SimplicialComplexForAlpha3d::Vertex_handle;
443  using Simplex_tree_vector_vertex = std::vector<Complex_vertex_handle>;
444
445 #ifdef DEBUG_TRACES
446  std::size_t count_vertices = 0;
447  std::size_t count_edges = 0;
448  std::size_t count_facets = 0;
449  std::size_t count_cells = 0;
450 #endif // DEBUG_TRACES
451  std::vector<CGAL::Object> objects;
452  std::vector<FT> alpha_values;
453
454  Dispatch dispatcher = CGAL::dispatch_output<CGAL::Object, FT>(std::back_inserter(objects),
455  std::back_inserter(alpha_values));
456
457  alpha_shape_3_ptr_->filtration_with_alpha_values(dispatcher);
458 #ifdef DEBUG_TRACES
459  std::clog << "filtration_with_alpha_values returns : " << objects.size() << " objects" << std::endl;
460 #endif // DEBUG_TRACES
461  if (objects.size() == 0) {
462  std::cerr << "Alpha_complex_3d create_complex - no triangulation as points are on a 2d plane\n";
463  return false; // ----- >>
464  }
465
466  using Alpha_value_iterator = typename std::vector<FT>::const_iterator;
467  Alpha_value_iterator alpha_value_iterator = alpha_values.begin();
468  for (auto object_iterator : objects) {
469  Vertex_list vertex_list;
470
471  // Retrieve Alpha shape vertex list from object
472  if (const Cell_handle* cell = CGAL::object_cast<Cell_handle>(&object_iterator)) {
473  for (auto i = 0; i < 4; i++) {
474 #ifdef DEBUG_TRACES
475  std::clog << "from cell[" << i << "] - Point coordinates (" << (*cell)->vertex(i)->point() << ")"
476  << std::endl;
477 #endif // DEBUG_TRACES
478  vertex_list.push_back((*cell)->vertex(i));
479  }
480 #ifdef DEBUG_TRACES
481  count_cells++;
482 #endif // DEBUG_TRACES
483  } else if (const Facet* facet = CGAL::object_cast<Facet>(&object_iterator)) {
484  for (auto i = 0; i < 4; i++) {
485  if ((*facet).second != i) {
486 #ifdef DEBUG_TRACES
487  std::clog << "from facet=[" << i << "] - Point coordinates (" << (*facet).first->vertex(i)->point() << ")"
488  << std::endl;
489 #endif // DEBUG_TRACES
490  vertex_list.push_back((*facet).first->vertex(i));
491  }
492  }
493 #ifdef DEBUG_TRACES
494  count_facets++;
495 #endif // DEBUG_TRACES
496  } else if (const Edge* edge = CGAL::object_cast<Edge>(&object_iterator)) {
497  for (auto i : {(*edge).second, (*edge).third}) {
498 #ifdef DEBUG_TRACES
499  std::clog << "from edge[" << i << "] - Point coordinates (" << (*edge).first->vertex(i)->point() << ")"
500  << std::endl;
501 #endif // DEBUG_TRACES
502  vertex_list.push_back((*edge).first->vertex(i));
503  }
504 #ifdef DEBUG_TRACES
505  count_edges++;
506 #endif // DEBUG_TRACES
507  } else if (const Alpha_vertex_handle* vertex = CGAL::object_cast<Alpha_vertex_handle>(&object_iterator)) {
508 #ifdef DEBUG_TRACES
509  count_vertices++;
510  std::clog << "from vertex - Point coordinates (" << (*vertex)->point() << ")" << std::endl;
511 #endif // DEBUG_TRACES
512  vertex_list.push_back((*vertex));
513  }
514  // Construction of the vector of simplex_tree vertex from list of alpha_shapes vertex
515  Simplex_tree_vector_vertex the_simplex;
516  for (auto the_alpha_shape_vertex : vertex_list) {
517  auto the_map_iterator = map_cgal_simplex_tree.find(the_alpha_shape_vertex);
518  if (the_map_iterator == map_cgal_simplex_tree.end()) {
519  // alpha shape not found
520  Complex_vertex_handle vertex = map_cgal_simplex_tree.size();
521 #ifdef DEBUG_TRACES
522  std::clog << "Point (" << the_alpha_shape_vertex->point() << ") not found - insert new vertex id " << vertex
523  << std::endl;
524 #endif // DEBUG_TRACES
525  the_simplex.push_back(vertex);
526  map_cgal_simplex_tree.emplace(the_alpha_shape_vertex, vertex);
527  } else {
528  // alpha shape found
529  Complex_vertex_handle vertex = the_map_iterator->second;
530 #ifdef DEBUG_TRACES
531  std::clog << "Point (" << the_alpha_shape_vertex->point() << ") found as vertex id " << vertex << std::endl;
532 #endif // DEBUG_TRACES
533  the_simplex.push_back(vertex);
534  }
535  }
536  // Construction of the simplex_tree
537  Filtration_value filtr = Value_from_iterator<Complexity>::perform(alpha_value_iterator);
538
539 #ifdef DEBUG_TRACES
540  std::clog << "filtration = " << filtr << std::endl;
541 #endif // DEBUG_TRACES
542  complex.insert_simplex(the_simplex, static_cast<Filtration_value>(filtr));
543  GUDHI_CHECK(alpha_value_iterator != alpha_values.end(), "CGAL provided more simplices than values");
544  ++alpha_value_iterator;
545  }
546
547 #ifdef DEBUG_TRACES
548  std::clog << "vertices \t" << count_vertices << std::endl;
549  std::clog << "edges \t\t" << count_edges << std::endl;
550  std::clog << "facets \t\t" << count_facets << std::endl;
551  std::clog << "cells \t\t" << count_cells << std::endl;
552 #endif // DEBUG_TRACES
553  // --------------------------------------------------------------------------------------------
554  if (Complexity == complexity::FAST)
555  // As Alpha value is an approximation, we have to make filtration non decreasing while increasing the dimension
556  // Only in FAST version, cf. https://github.com/GUDHI/gudhi-devel/issues/57
558  // Remove all simplices that have a filtration value greater than max_alpha_square
559  complex.prune_above_filtration(max_alpha_square);
560  // --------------------------------------------------------------------------------------------
561  return true;
562  }
563
570  const Point_3& get_point(std::size_t vertex) {
571  if (map_cgal_simplex_tree.size() != cgal_vertex_iterator_vector.size()) {
572  cgal_vertex_iterator_vector.resize(map_cgal_simplex_tree.size());
573  for (auto map_iterator : map_cgal_simplex_tree) {
574  cgal_vertex_iterator_vector[map_iterator.second] = map_iterator.first;
575  }
576
577  }
578  auto cgal_vertex_iterator = cgal_vertex_iterator_vector.at(vertex);
579  return cgal_vertex_iterator->point();
580  }
581
582  private:
583  // use of a unique_ptr on cgal Alpha_shape_3, as copy and default constructor is not available - no need to be freed
584  std::unique_ptr<Alpha_shape_3> alpha_shape_3_ptr_;
585
586  // Map type to switch from CGAL vertex iterator to simplex tree vertex handle.
587  std::unordered_map<Alpha_vertex_handle, std::size_t> map_cgal_simplex_tree;
588  // Vector type to switch from simplex tree vertex handle to CGAL vertex iterator.
589  std::vector<Alpha_vertex_handle> cgal_vertex_iterator_vector;
590 };
591
592 } // namespace alpha_complex
593
594 } // namespace Gudhi
595
596 #endif // ALPHA_COMPLEX_3D_H_
Alpha complex data structure for 3d specific case.
Definition: Alpha_complex_3d.h:118
CGAL::Alpha_shape_3< Dt > Alpha_shape_3
The CGAL 3D Alpha Shapes type.
Definition: Alpha_complex_3d.h:215
Alpha_complex_3d(const InputPointRange &points)
Alpha_complex constructor from a list of points.
Definition: Alpha_complex_3d.h:273
bool create_complex(SimplicialComplexForAlpha3d &complex, Filtration_value max_alpha_square=std::numeric_limits< Filtration_value >::infinity())
Inserts all Delaunay triangulation into the simplicial complex. It also computes the filtration value...
Definition: Alpha_complex_3d.h:435
Alpha_complex_3d(const InputPointRange &points, WeightRange weights, FT x_min, FT y_min, FT z_min, FT x_max, FT y_max, FT z_max)
Alpha_complex constructor from a list of points, associated weights and an iso-cuboid coordinates.
Definition: Alpha_complex_3d.h:378
Alpha_complex_3d(const InputPointRange &points, WeightRange weights)
Alpha_complex constructor from a list of points and associated weights.
Definition: Alpha_complex_3d.h:295
typename Kernel::Point_3 Bare_point_3
Gives public access to the Bare_point_3 (bare aka. unweighed) type. Here is a Bare_point_3 constructo...
Definition: Alpha_complex_3d.h:230
const Point_3 & get_point(std::size_t vertex)
get_point returns the point corresponding to the vertex given as parameter.
Definition: Alpha_complex_3d.h:570
typename Triangulation_3< Kernel, Tds, Weighted, Periodic >::Weighted_point_3 Weighted_point_3
Gives public access to the Weighted_point_3 type. A Weighted point can be constructed as follows:
Definition: Alpha_complex_3d.h:243
typename Alpha_shape_3::Point Point_3
Alpha_complex_3d::Point_3 type is either a Alpha_complex_3d::Bare_point_3 (Weighted = false) or a Alp...
Definition: Alpha_complex_3d.h:248
typename Alpha_shape_3::FT FT
The alpha values type. Must be compatible with double.
Definition: Alpha_complex_3d.h:219
Alpha_complex_3d(const InputPointRange &points, FT x_min, FT y_min, FT z_min, FT x_max, FT y_max, FT z_max)
Alpha_complex constructor from a list of points and an iso-cuboid coordinates.
Definition: Alpha_complex_3d.h:330
complexity
Alpha complex complexity template parameter possible values.
Definition: Alpha_complex_options.h:23
Gudhi namespace.
Definition: SimplicialComplexForAlpha.h:14
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
The concept SimplicialComplexForAlpha3d describes the requirements for a type to implement a simplici...
Definition: SimplicialComplexForAlpha3d.h:21
void insert_simplex(std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
Inserts a simplex from a given simplex (represented by a vector of Vertex_handle) in the simplicial c...
unspecified Filtration_value
Definition: SimplicialComplexForAlpha3d.h:25
unspecified Vertex_handle
Definition: SimplicialComplexForAlpha3d.h:23
void prune_above_filtration(Filtration_value filtration)
