The concept SimplexInCoxeterTriangulation describes the requirements for a type to implement a representation of simplices in Freudenthal_triangulation or in Coxeter_triangulation.
More...
unsigned | dimension () const |
| | Dimension of the simplex.
Vertex_range | vertex_range () const |
| | Returns a range of vertices of the simplex.
Face_range | face_range (std::size_t k) const |
| | Returns a range of permutahedral representations of k-dimensional faces of the simplex for some given integer parameter 'k'.
Face_range | facet_range () const |
| | Returns a range of permutahedral representations of facets of the simplex. The dimension of the simplex must be strictly positive.
Coface_range | coface_range (std::size_t k) const |
| | Returns a range of permutahedral representations of k-dimensional cofaces of the simplex for some given integer parameter 'k'.
Coface_range | cofacet_range () const |
| | Returns a range of permutahedral representations of cofacets of the simplex. The dimension of the simplex must be strictly different from the ambient dimension.
bool | is_face_of (const Permutahedral_representation &other) const |
| | Returns true, if the simplex is a face of other simplex.
The documentation for this struct was generated from the following file:
