Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::coxeter_triangulation::Permutahedral_representation< Vertex_, Ordered_set_partition_ > Class Template Reference
A class that stores the permutahedral representation of a simplex in a Coxeter triangulation or a Freudenthal-Kuhn triangulation. More...
Public Types
typedef Vertex_ Vertex
 Type of the vertex.
typedef Ordered_set_partition_ OrderedSetPartition
 Type of the ordered partition.
Public Member Functions
 Permutahedral_representation (const Vertex &vertex, const OrderedSetPartition &partition)
 Permutahedral_representation constructor from a vertex and an ordered set partition. More...
 Permutahedral_representation ()
 Constructor for an empty permutahedral representation that does not correspond to any simplex.
std::size_t dimension () const
 Dimension of the simplex.
Vertexvertex ()
 Lexicographically-minimal vertex.
const Vertexvertex () const
OrderedSetPartitionpartition ()
 Ordered set partition.
const OrderedSetPartitionpartition () const
 Identifying vertex.
bool operator== (const Permutahedral_representation &other) const
 Equality operator. Returns true if an only if both vertex and the ordered set partition coincide.
bool operator!= (const Permutahedral_representation &other) const
 Inequality operator. Returns true if an only if either vertex or the ordered set partition are different.
Vertex_range vertex_range () const
 Returns a range of vertices of the simplex. The type of vertices is Vertex.
Face_range face_range (std::size_t value_dim) const
 Returns a range of permutahedral representations of faces of the simplex. More...
Face_range facet_range () const
 Returns a range of permutahedral representations of facets of the simplex. The dimension of the simplex must be strictly positive.
Coface_range coface_range (std::size_t value_dim) const
 Returns a range of permutahedral representations of cofaces of the simplex. More...
Coface_range cofacet_range () const
 Returns a range of permutahedral representations of cofacets of the simplex. The dimension of the simplex must be strictly different from the ambient dimension (the size of the vertex).
bool is_face_of (const Permutahedral_representation &other) const
 Returns true, if the simplex is a face of other simplex. More...
Detailed Description
template<class Vertex_, class Ordered_set_partition_>
class Gudhi::coxeter_triangulation::Permutahedral_representation< Vertex_, Ordered_set_partition_ >
The data structure is a record consisting of a range that represents the vertex and a range that represents the ordered set partition, both of which identify the simplex in the triangulation.
Template Parameters
Vertex_needs to be a random-access range.
Ordered_set_partition_needs to be a a random-access range that consists of random-access ranges.
Constructor & Destructor Documentation
◆ Permutahedral_representation()
template<class Vertex_ , class Ordered_set_partition_ >
Gudhi::coxeter_triangulation::Permutahedral_representation< Vertex_, Ordered_set_partition_ >::Permutahedral_representation ( const Vertex vertex,
const OrderedSetPartition partition
inline
Parameters
[in]vertexVertex.
[in]partitionOrdered set partition.
If the size of vertex is d, the ranges in partition must consist of the integers 0,...,d without repetition or collision between the ranges.
Member Function Documentation
◆ coface_range()
Coface_range Gudhi::coxeter_triangulation::Permutahedral_representation< Vertex_, Ordered_set_partition_ >::coface_range ( std::size_t  value_dim) const
inline
Parameters
[in]value_dimThe dimension of the cofaces. Must be between the dimension of the simplex and the ambient dimension (the size of the vertex).
◆ face_range()
Face_range Gudhi::coxeter_triangulation::Permutahedral_representation< Vertex_, Ordered_set_partition_ >::face_range ( std::size_t  value_dim) const
inline
Parameters
[in]value_dimThe dimension of the faces. Must be between 0 and the dimension of the simplex.
◆ is_face_of()
bool Gudhi::coxeter_triangulation::Permutahedral_representation< Vertex_, Ordered_set_partition_ >::is_face_of ( const Permutahedral_representation< Vertex_, Ordered_set_partition_ > &  other) const
inline
Parameters
[in]otherA simplex that is potential a coface of the current simplex.
The documentation for this class was generated from the following file:
