The concept IntersectionOracle describes the requirements for a type to implement an intersection oracle class used for example in Manifold_tracing.
More...
std::size_t | amb_d () const |
| | Returns the domain (ambient) dimension of the underlying manifold.
std::size_t | cod_d () const |
| | Returns the codomain dimension of the underlying manifold.
| template<class Simplex_handle , class Triangulation > |
| Query_result< Simplex_handle > | intersects (const Simplex_handle &simplex, const Triangulation &triangulation) const |
| | Intersection query with the relative interior of the manifold. More...
| Query_result< Simplex_handle > | intersects_boundary (const Simplex_handle &simplex, const Triangulation &triangulation) const |
| | Intersection query with the boundary of the manifold. More...
| template<class Triangulation > |
| bool | lies_in_domain (const Eigen::VectorXd &p, const Triangulation &triangulation) const |
| | Returns true if the input point lies inside the piecewise-linear domain induced by the given ambient triangulation that defines the relative interior of the piecewise-linear approximation of the manifold. More...
const Function_ & | function () const |
| | Returns the function that defines the interior of the manifold.
◆ intersects()
| Query_result<Simplex_handle> Gudhi::coxeter_triangulation::IntersectionOracle::intersects |
const Simplex_handle & |
simplex, |
const Triangulation & |
triangulation |
| const |
The returned structure Query_result contains the boolean value that is true only if the intersection point of the query simplex and the relative interior of the manifold exists, the intersection point and the face of the query simplex that contains the intersection point.
- Template Parameters
- Parameters
| [in] | simplex | The query simplex. The dimension of the simplex should be the same as the codimension of the manifold (the codomain dimension of the function). |
| [in] | triangulation | The ambient triangulation. The dimension of the triangulation should be the same as the ambient dimension of the manifold (the domain dimension of the function). |
◆ intersects_boundary()
| Query_result<Simplex_handle> Gudhi::coxeter_triangulation::IntersectionOracle::intersects_boundary |
simplex, |
triangulation |
| const |
The returned structure Query_result contains the boolean value that is true only if the intersection point of the query simplex and the boundary of the manifold exists, the intersection point and the face of the query simplex that contains the intersection point.
- Parameters
| [in] | simplex | The query simplex. The dimension of the simplex should be the same as the codimension of the boundary of the manifold (the codomain dimension of the function + 1). |
◆ lies_in_domain()
| bool Gudhi::coxeter_triangulation::IntersectionOracle::lies_in_domain |
const Eigen::VectorXd & |
p, |
triangulation |
| const |
inline |
- Parameters
| p | The input point. Needs to have the same dimension as the ambient dimension of the manifold (the domain dimension of the function). |
| triangulation | The ambient triangulation. Needs to have the same dimension as the ambient dimension of the manifold (the domain dimension of the function). |
The documentation for this struct was generated from the following file:
