column_utilities.h
Go to the documentation of this file.
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Hannah Schreiber
4  *
5  * Copyright (C) 2024 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
17 #ifndef PM_COLUMN_UTILITIES_H
18 #define PM_COLUMN_UTILITIES_H
19
20 #include <cstddef>
21 #include <stdexcept>
22
24
25 namespace Gudhi {
26 namespace persistence_matrix {
27
28 template <class Cell, typename Cell_iterator>
29 Cell* _get_cell(const Cell_iterator& itTarget)
30 {
31  if constexpr (Cell::Master::Option_list::column_type == Column_types::INTRUSIVE_LIST ||
32  Cell::Master::Option_list::column_type == Column_types::INTRUSIVE_SET) {
33  return &*itTarget;
34  } else {
35  return *itTarget;
36  }
37 }
38
39 // works only for ordered columns
40 template <class Column_type, class Cell_iterator, typename F1, typename F2, typename F3, typename F4>
41 void _generic_merge_cell_to_column(Column_type& targetColumn,
42  Cell_iterator& itSource,
43  typename Column_type::Column_type::iterator& itTarget,
44  F1&& process_target,
45  F2&& process_source,
46  F3&& update_target1,
47  F4&& update_target2,
48  bool& pivotIsZeroed)
49 {
50  typename Column_type::Cell* targetCell = _get_cell<typename Column_type::Cell>(itTarget);
51
52  if (targetCell->get_row_index() < itSource->get_row_index()) {
53  process_target(targetCell);
54  ++itTarget;
55  } else if (targetCell->get_row_index() > itSource->get_row_index()) {
56  process_source(itSource, itTarget);
57  ++itSource;
58  } else {
59  if constexpr (Column_type::Master::Option_list::is_z2) {
60  //_multiply_*_and_add never enters here so not treated
61  if constexpr (Column_type::Master::isNonBasic && !Column_type::Master::Option_list::is_of_boundary_type) {
62  if (targetCell->get_row_index() == targetColumn.get_pivot()) pivotIsZeroed = true;
63  }
64  targetColumn._delete_cell(itTarget);
65  } else {
66  update_target1(targetCell->get_element(), itSource);
67  if (targetCell->get_element() == Column_type::Field_operators::get_additive_identity()) {
68  if constexpr (Column_type::Master::isNonBasic && !Column_type::Master::Option_list::is_of_boundary_type) {
69  if (targetCell->get_row_index() == targetColumn.get_pivot()) pivotIsZeroed = true;
70  }
71  targetColumn._delete_cell(itTarget);
72  } else {
73  update_target2(targetCell);
74  if constexpr (Column_type::Master::Option_list::has_row_access)
75  targetColumn.update_cell(*targetCell);
76  ++itTarget;
77  }
78  }
79  ++itSource;
80  }
81 }
82
83 // works only for ordered columns
84 template <class Column_type, class Cell_range, typename F1, typename F2, typename F3, typename F4, typename F5>
85 bool _generic_add_to_column(const Cell_range& source,
86  Column_type& targetColumn,
87  F1&& process_target,
88  F2&& process_source,
89  F3&& update_target1,
90  F4&& update_target2,
91  F5&& finish_target)
92 {
93  bool pivotIsZeroed = false;
94
95  auto& target = targetColumn.column_;
96  auto itTarget = target.begin();
97  auto itSource = source.begin();
98  while (itTarget != target.end() && itSource != source.end()) {
99  _generic_merge_cell_to_column(targetColumn, itSource, itTarget,
100  process_target, process_source, update_target1, update_target2,
101  pivotIsZeroed);
102  }
103
104  finish_target(itTarget);
105
106  while (itSource != source.end()) {
107  process_source(itSource, target.end());
108  ++itSource;
109  }
110
111  return pivotIsZeroed;
112 }
113
114 template <class Column_type, class Cell_range>
115 bool _add_to_column(const Cell_range& source, Column_type& targetColumn)
116 {
117  return _generic_add_to_column(
118  source,
119  targetColumn, [&]([[maybe_unused]] typename Column_type::Cell* cellTarget) {},
120  [&](typename Cell_range::const_iterator& itSource, const typename Column_type::Column_type::iterator& itTarget) {
121  if constexpr (Column_type::Master::Option_list::is_z2) {
122  targetColumn._insert_cell(itSource->get_row_index(), itTarget);
123  } else {
124  targetColumn._insert_cell(itSource->get_element(), itSource->get_row_index(), itTarget);
125  }
126  },
127  [&](typename Column_type::Field_element_type& targetElement, typename Cell_range::const_iterator& itSource) {
128  if constexpr (!Column_type::Master::Option_list::is_z2)
129  targetColumn.operators_->add_inplace(targetElement, itSource->get_element());
130  },
131  [&]([[maybe_unused]] typename Column_type::Cell* cellTarget) {},
132  [&]([[maybe_unused]] typename Column_type::Column_type::iterator& itTarget) {});
133 }
134
135 template <class Column_type, class Cell_range>
136 bool _multiply_target_and_add_to_column(const typename Column_type::Field_element_type& val,
137  const Cell_range& source,
138  Column_type& targetColumn)
139 {
140  if (val == 0u) {
141  if constexpr (Column_type::Master::isNonBasic && !Column_type::Master::Option_list::is_of_boundary_type) {
142  throw std::invalid_argument("A chain column should not be multiplied by 0.");
143  // this would not only mess up the base, but also the pivots stored.
144  } else {
145  targetColumn.clear();
146  }
147  }
148
149  return _generic_add_to_column(
150  source,
151  targetColumn,
152  [&](typename Column_type::Cell* cellTarget) {
153  targetColumn.operators_->multiply_inplace(cellTarget->get_element(), val);
154  // targetColumn.ra_opt::update_cell(*itTarget) produces an internal compiler error
155  // even though it works in _generic_add_to_column... Probably because of the lambda.
156  if constexpr (Column_type::Master::Option_list::has_row_access)
157  targetColumn.update_cell(*cellTarget);
158  },
159  [&](typename Cell_range::const_iterator& itSource, const typename Column_type::Column_type::iterator& itTarget) {
160  targetColumn._insert_cell(itSource->get_element(), itSource->get_row_index(), itTarget);
161  },
162  [&](typename Column_type::Field_element_type& targetElement, typename Cell_range::const_iterator& itSource) {
163  targetColumn.operators_->multiply_and_add_inplace_front(targetElement, val, itSource->get_element());
164  },
165  [&]([[maybe_unused]] typename Column_type::Cell* cellTarget) {},
166  [&](typename Column_type::Column_type::iterator& itTarget) {
167  while (itTarget != targetColumn.column_.end()) {
168  typename Column_type::Cell* targetCell = _get_cell<typename Column_type::Cell>(itTarget);
169  targetColumn.operators_->multiply_inplace(targetCell->get_element(), val);
170  if constexpr (Column_type::Master::Option_list::has_row_access)
171  targetColumn.update_cell(*targetCell);
172  itTarget++;
173  }
174  });
175 }
176
177 template <class Column_type, class Cell_range>
178 bool _multiply_source_and_add_to_column(const typename Column_type::Field_element_type& val, const Cell_range& source,
179  Column_type& targetColumn)
180 {
181  if (val == 0u) {
182  return false;
183  }
184
185  return _generic_add_to_column(
186  source,
187  targetColumn, []([[maybe_unused]] typename Column_type::Cell* cellTarget) {},
188  [&](typename Cell_range::const_iterator& itSource, const typename Column_type::Column_type::iterator& itTarget) {
189  typename Column_type::Cell* cell =
190  targetColumn._insert_cell(itSource->get_element(), itSource->get_row_index(), itTarget);
191  targetColumn.operators_->multiply_inplace(cell->get_element(), val);
192  if constexpr (Column_type::Master::Option_list::has_row_access)
193  targetColumn.update_cell(*cell);
194  },
195  [&](typename Column_type::Field_element_type& targetElement, typename Cell_range::const_iterator& itSource) {
196  targetColumn.operators_->multiply_and_add_inplace_back(itSource->get_element(), val, targetElement);
197  },
198  [&]([[maybe_unused]] typename Column_type::Cell* cellTarget) {},
199  []([[maybe_unused]] typename Column_type::Column_type::iterator& itTarget) {});
200 }
201
202 // column has to be ordered (ie. not suited for unordered_map and heap) and contain the exact values
203 // (ie. not suited for vector and heap). A same colonne but ordered differently will have another hash value.
204 template <class Column_type>
205 std::size_t hash_column(const Column_type& column) {
206  std::size_t seed = 0;
207  for (auto& cell : column) {
208  seed ^= std::hash<unsigned int>()(cell.get_row_index() * static_cast<unsigned int>(cell.get_element())) +
209  0x9e3779b9 + (seed << 6) + (seed >> 2);
210  }
211  return seed;
212 }
213
214 } // namespace persistence_matrix
215 } // namespace Gudhi
216
217 #endif // PM_COLUMN_UTILITIES_H
@ INTRUSIVE_LIST
Definition: persistence_matrix_options.h:39
@ INTRUSIVE_SET
Definition: persistence_matrix_options.h:40
Gudhi namespace.
Definition: SimplicialComplexForAlpha.h:14
Contains the options for the matrix template.
