Gudhi::coxeter_triangulation::Cell_complex< Out_simplex_map_ > Class Template Reference
A class that constructs the cell complex from the output provided by the class Gudhi::coxeter_triangulation::Manifold_tracing. More...
Public Types
using Simplex_handle = typename Out_simplex_map_::key_type
 Type of a simplex in the ambient triangulation. Is a model of the concept SimplexInCoxeterTriangulation.
using Hasse_cell = Gudhi::Hasse_diagram::Hasse_diagram_cell< int, double, bool >
 Type of a cell in the cell complex. Always is Gudhi::Hasse_cell from the Hasse diagram module. The additional information is the boolean that is true if and only if the cell lies on the boundary.
using Simplex_cell_map = std::map< Simplex_handle, Hasse_cell *, Simplex_comparator< Simplex_handle > >
 Type of a map from permutahedral representations of simplices in the ambient triangulation to the corresponding cells in the cell complex of some specific dimension.
using Simplex_cell_maps = std::vector< Simplex_cell_map >
 Type of a vector of maps from permutahedral representations of simplices in the ambient triangulation to the corresponding cells in the cell complex of various dimensions.
using Cell_simplex_map = std::map< Hasse_cell *, Simplex_handle >
 Type of a map from cells in the cell complex to the permutahedral representations of the corresponding simplices in the ambient triangulation.
using Cell_point_map = std::map< Hasse_cell *, Eigen::VectorXd >
 Type of a map from vertex cells in the cell complex to the permutahedral representations of their Cartesian coordinates.
Public Member Functions
void construct_complex (const Out_simplex_map_ &out_simplex_map)
 Constructs the the cell complex that approximates an \(m\)-dimensional manifold without boundary embedded in the \( d \)-dimensional Euclidean space from the output of the class Gudhi::Manifold_tracing. More...
void construct_complex (const Out_simplex_map_ &out_simplex_map, std::size_t limit_dimension)
 Constructs the skeleton of the cell complex that approximates an \(m\)-dimensional manifold without boundary embedded in the \(d\)-dimensional Euclidean space up to a limit dimension from the output of the class Gudhi::Manifold_tracing. More...
void construct_complex (const Out_simplex_map_ &interior_simplex_map, const Out_simplex_map_ &boundary_simplex_map)
 Constructs the the cell complex that approximates an \(m\)-dimensional manifold with boundary embedded in the \( d \)-dimensional Euclidean space from the output of the class Gudhi::Manifold_tracing. More...
void construct_complex (const Out_simplex_map_ &interior_simplex_map, const Out_simplex_map_ &boundary_simplex_map, std::size_t limit_dimension)
 Constructs the skeleton of the cell complex that approximates an \(m\)-dimensional manifold with boundary embedded in the \(d\)-dimensional Euclidean space up to a limit dimension from the output of the class Gudhi::Manifold_tracing. More...
std::size_t intrinsic_dimension () const
 Returns the dimension of the cell complex.
const Simplex_cell_maps & interior_simplex_cell_maps () const
 Returns a vector of maps from the cells of various dimensions in the interior of the cell complex of type Gudhi::Hasse_cell to the permutahedral representations of the corresponding simplices in the ambient triangulation.
const Simplex_cell_maps & boundary_simplex_cell_maps () const
 Returns a vector of maps from the cells of various dimensions on the boundary of the cell complex of type Gudhi::Hasse_cell to the permutahedral representations of the corresponding simplices in the ambient triangulation.
const Simplex_cell_map & interior_simplex_cell_map (std::size_t cell_d) const
 Returns a map from the cells of a given dimension in the interior of the cell complex of type Gudhi::Hasse_cell to the permutahedral representations of the corresponding simplices in the ambient triangulation. More...
const Simplex_cell_map & boundary_simplex_cell_map (std::size_t cell_d) const
 Returns a map from the cells of a given dimension on the boundary of the cell complex of type Gudhi::Hasse_cell to the permutahedral representations of the corresponding simplices in the ambient triangulation. More...
const Cell_simplex_map & cell_simplex_map () const
 Returns a map from the cells in the cell complex of type Gudhi::Hasse_cell to the permutahedral representations of the corresponding simplices in the ambient triangulation.
const Cell_point_map & cell_point_map () const
 Returns a map from the vertex cells in the cell complex of type Gudhi::Hasse_cell to their Cartesian coordinates.
 Cell_complex (std::size_t intrinsic_dimension)
 Constructor for the class Cell_complex. More...
Detailed Description
template<class Out_simplex_map_>
class Gudhi::coxeter_triangulation::Cell_complex< Out_simplex_map_ >
The use and interfaces of this cell complex is limited to the Coxeter triangulation implementation.
Template Parameters
Out_simplex_map_The type of a map from a simplex type that is a model of SimplexInCoxeterTriangulation to Eigen::VectorXd.
Constructor & Destructor Documentation
◆ Cell_complex()
template<class Out_simplex_map_ >
Gudhi::coxeter_triangulation::Cell_complex< Out_simplex_map_ >::Cell_complex ( std::size_t  intrinsic_dimension)
inline
Parameters
[in]intrinsic_dimensionThe dimension of the cell complex.
Member Function Documentation
◆ boundary_simplex_cell_map()
const Simplex_cell_map& Gudhi::coxeter_triangulation::Cell_complex< Out_simplex_map_ >::boundary_simplex_cell_map ( std::size_t  cell_d) const
inline
Parameters
[in]cell_dThe dimension of the cells.
◆ construct_complex() [1/4]
void Gudhi::coxeter_triangulation::Cell_complex< Out_simplex_map_ >::construct_complex ( const Out_simplex_map_ &  interior_simplex_map,
const Out_simplex_map_ &  boundary_simplex_map
inline
Parameters
[in]interior_simplex_mapA map from simplices of dimension \((d-m)\) in the ambient triangulation that intersect the relative interior of the manifold to the intersection points.
[in]boundary_simplex_mapA map from simplices of dimension \((d-m+1)\) in the ambient triangulation that intersect the boundary of the manifold to the intersection points.
◆ construct_complex() [2/4]
const Out_simplex_map_ &  boundary_simplex_map,
inline
Parameters
[in]limit_dimensionThe dimension of the constructed skeleton.
◆ construct_complex() [3/4]
void Gudhi::coxeter_triangulation::Cell_complex< Out_simplex_map_ >::construct_complex ( const Out_simplex_map_ &  out_simplex_map)
inline
Parameters
[in]out_simplex_mapA map from simplices of dimension \((d-m)\) in the ambient triangulation that intersect the relative interior of the manifold to the intersection points.
◆ construct_complex() [4/4]
void Gudhi::coxeter_triangulation::Cell_complex< Out_simplex_map_ >::construct_complex ( const Out_simplex_map_ &  out_simplex_map,
inline
Parameters
◆ interior_simplex_cell_map()
const Simplex_cell_map& Gudhi::coxeter_triangulation::Cell_complex< Out_simplex_map_ >::interior_simplex_cell_map ( std::size_t  cell_d) const
inline
Parameters
The documentation for this class was generated from the following file:
