Contains the Base_swap class and Dummy_base_swap structure. More...
Go to the source code of this file.
Classes | |
| struct | Gudhi::persistence_matrix::Dummy_base_swap |
| Empty structure. Inheritated instead of Base_swap, when the column and row swaps are not enabled. More... | |
| class | Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix > |
| Class managing the column and row swaps in Base_matrix and Boundary_matrix. More... | |
Namespaces | |
| Gudhi | |
| Gudhi namespace. | |
| Gudhi::persistence_matrix | |
| Persistence matrix namespace. | |
