Loading [MathJax]/extensions/tex2jax.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::rips_complex::SimplicialComplexForRips Struct Reference
The concept SimplicialComplexForRips describes the requirements for a type to implement a simplicial complex, that can be created from a Rips_complex. The only available model for the moment is the Simplex_tree. More...
Public Types
typedef unspecified Filtration_value
 Type used to store the filtration values of the simplicial complex.
typedef unspecified Simplex_handle
 Handle type to a simplex contained in the simplicial complex.
Public Member Functions
template<class OneSkeletonGraph >
void insert_graph (const OneSkeletonGraph &skel_graph)
 Inserts a given Gudhi::rips_complex::Rips_complex::OneSkeletonGraph in the simplicial complex.
void expansion (int max_dim)
 Expands the simplicial complex containing only its one skeleton until a given maximal dimension as explained in Rips complex definition.
template<typename Blocker >
void expansion_with_blockers (int max_dim, Blocker block_simplex)
 Expands a simplicial complex containing only a graph. Simplices corresponding to cliques in the graph are added incrementally, faces before cofaces, unless the simplex has dimension larger than max_dim or block_simplex returns true for this simplex. More...
unspecified simplex_vertex_range (Simplex_handle sh)
 Returns a range over the vertices of a simplex.
std::size_t num_vertices ()
 Returns the number of vertices in the simplicial complex.
Detailed Description
Member Function Documentation
◆ expansion_with_blockers()
void Gudhi::rips_complex::SimplicialComplexForRips::expansion_with_blockers ( int  max_dim,
Parameters
[in]max_dimExpansion maximal dimension value.
[in]block_simplexBlocker oracle. Its concept is bool block_simplex(Simplex_handle sh)
The function identifies a candidate simplex whose faces are all already in the complex, inserts it with a filtration value corresponding to the maximum of the filtration values of the faces, then calls block_simplex on a Simplex_handle for this new simplex. If block_simplex returns true, the simplex is removed, otherwise it is kept.
The documentation for this struct was generated from the following file:
GUDHI  Version 3.1.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13
