SimplicialComplexForRips.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Vincent Rouvreau
4  *
5  * Copyright (C) 2016 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
11 #ifndef CONCEPT_RIPS_COMPLEX_SIMPLICIAL_COMPLEX_FOR_RIPS_H_
12 #define CONCEPT_RIPS_COMPLEX_SIMPLICIAL_COMPLEX_FOR_RIPS_H_
13
14 namespace Gudhi {
15
16 namespace rips_complex {
17
23  typedef unspecified Filtration_value;
24
26  typedef unspecified Simplex_handle;
27
29  template<class OneSkeletonGraph>
30  void insert_graph(const OneSkeletonGraph& skel_graph);
31
34  void expansion(int max_dim);
35
48  template< typename Blocker >
49  void expansion_with_blockers(int max_dim, Blocker block_simplex);
50
52  unspecified simplex_vertex_range(Simplex_handle sh);
53
55  std::size_t num_vertices();
56
57 };
58
59 } // namespace rips_complex
60
61 } // namespace Gudhi
62
63 #endif // CONCEPT_RIPS_COMPLEX_SIMPLICIAL_COMPLEX_FOR_RIPS_H_
Expands the simplicial complex containing only its one skeleton until a given maximal dimension as ex...
void insert_graph(const OneSkeletonGraph &skel_graph)
Inserts a given Gudhi::rips_complex::Rips_complex::OneSkeletonGraph in the simplicial complex...
The concept SimplicialComplexForRips describes the requirements for a type to implement a simplicial ...
Definition: SimplicialComplexForRips.h:21
Definition: SimplicialComplexForAlpha.h:14
Expands a simplicial complex containing only a graph. Simplices corresponding to cliques in the graph...
Type used to store the filtration values of the simplicial complex.
Definition: SimplicialComplexForRips.h:23
Returns the number of vertices in the simplicial complex.
Handle type to a simplex contained in the simplicial complex.
Definition: SimplicialComplexForRips.h:26
Returns a range over the vertices of a simplex.
GUDHI  Version 3.1.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13
