Gudhi::contraction::Valid_contraction_policy< EdgeProfile > Class Template Referenceabstract
Policy to specify if an edge contraction is valid or not. More...
Detailed Description
template<typename EdgeProfile>
class Gudhi::contraction::Valid_contraction_policy< EdgeProfile >
The documentation for this class was generated from the following file:
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:57 for GUDHI by Doxygen 1.8.13
