Gudhi  1.2.0
 All Classes Functions Variables Typedefs Friends Groups Pages
Gudhi::skbl::SkeletonBlockerGeometricDS< GeometryTrait > Struct Template Reference
Concept for template class of Skeleton_blocker_geometric_complex . It must specify a GeometryTrait which contains a Point definition. More...
#include <SkeletonBlockerGeometricDS.h>
Classes
class  Graph_Edge
 Edge that allows to access to an index. The indices of the edges are used to store heap information in the edge contraction algorithm. More...
class  Graph_vertex
 Vertex that stores a point. More...
Public Types
typedef GeometryTrait GT
typedef GeometryTrait::Point Point
- Public Types inherited from Gudhi::skbl::SkeletonBlockerDS
typedef int boost_vertex_handle
 index that allows to find the vertex in the boost graph
Detailed Description
template<typename GeometryTrait>
struct Gudhi::skbl::SkeletonBlockerGeometricDS< GeometryTrait >
Graph_vertex must specify how to access to a point. Graph_edge must specify how to access to an index.
Member Typedef Documentation
template<typename GeometryTrait >
typedef GeometryTrait Gudhi::skbl::SkeletonBlockerGeometricDS< GeometryTrait >::GT
Geometry information.
typedef GeometryTrait::Point Gudhi::skbl::SkeletonBlockerGeometricDS< GeometryTrait >::Point
Type of point (should be the same as GT::Point).
The documentation for this struct was generated from the following file:
