Gudhi  1.2.0
 All Classes Functions Variables Typedefs Friends Groups Pages
Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS > Class Template Reference
Class that represents a geometric complex that can be simplified. The class allows access to points of vertices. More...
#include <Skeleton_blocker_geometric_complex.h>
Public Member Functions
template<typename PointIterator >
 Skeleton_blocker_geometric_complex (int num_vertices, PointIterator begin, PointIterator end)
template<typename SimpleHandleOutputIterator , typename PointIterator >
 Skeleton_blocker_geometric_complex (SimpleHandleOutputIterator simplex_begin, SimpleHandleOutputIterator simplex_end, PointIterator points_begin, PointIterator points_end, bool is_flag_complex=false)
 Constructor with a list of simplices. More...
template<typename SimpleHandleOutputIterator >
 Skeleton_blocker_geometric_complex (SimpleHandleOutputIterator simplex_begin, SimpleHandleOutputIterator simplex_end, bool is_flag_complex=false)
 Constructor with a list of simplices. Points of every vertex are the point constructed with default constructor. More...
Vertex_handle add_vertex ()
 Add a vertex to the complex with a default constructed associated point.
Vertex_handle add_vertex (const Point &point)
 Add a vertex to the complex with its associated point.
const Point & point (Vertex_handle v) const
 Returns the Point associated to the vertex v.
Geometric_link link (Vertex_handle v) const
Geometric_link link (const Simplex_handle &simplex) const
Geometric_link link (Edge_handle edge) const
Abstract_link abstract_link (Vertex_handle v) const
Abstract_link abstract_link (const Simplex_handle &simplex) const
Abstract_link abstract_link (Edge_handle edge) const
- Public Member Functions inherited from Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerGeometricDS >
Root_simplex_handle get_id (const Simplex_handle &local_simplex) const
 returns a simplex with vertices which are the id of vertices of the argument.
Link_complex link (Vertex_handle v) const
Link_complex link (Edge_handle edge) const
Link_complex link (const Simplex_handle &simplex) const
boost::optional< Simplex_handleget_simplex_address (const Root_simplex_handle &s) const
 Compute the local vertices of 's' in the current complex If one of them is not present in the complex then the return value is uninitialized.
virtual bool contains (const Simplex_handle &s) const
 returns true iff the simplex s belongs to the simplicial complex.
int num_connected_components () const
 returns the number of connected components in the graph of the 1-skeleton.
bool is_cone () const
 Test if the complex is a cone. More...
Vertex_handle operator[] (Root_vertex_handle global) const
 Return a local Vertex_handle of a vertex given a global one. More...
Graph_vertexoperator[] (Vertex_handle address)
 Return the vertex node associated to local Vertex_handle. More...
const Graph_vertexoperator[] (Vertex_handle address) const
 Adds a vertex to the simplicial complex and returns its Vertex_handle.
void remove_vertex (Vertex_handle address)
 Remove a vertex from the simplicial complex. More...
bool contains_vertex (Vertex_handle u) const
bool contains_vertex (Root_vertex_handle u) const
bool contains_vertices (const Simplex_handle &sigma) const
virtual boost::optional
< Vertex_handle
get_address (Root_vertex_handle id) const
 Given an Id return the address of the vertex having this Id in the complex. More...
Root_vertex_handle get_id (Vertex_handle local) const
Vertex_handle convert_handle_from_another_complex (const Skeleton_blocker_complex &other, Vertex_handle vh_in_other) const
 Convert an address of a vertex of a complex to the address in the current complex. More...
int degree (Vertex_handle local) const
 return the graph degree of a vertex.
boost::optional< Edge_handleoperator[] (const std::pair< Vertex_handle, Vertex_handle > &ab) const
 return an edge handle if the two vertices forms an edge in the complex
Graph_edgeoperator[] (Edge_handle edge_handle)
 returns the stored node associated to an edge
const Graph_edgeoperator[] (Edge_handle edge_handle) const
Vertex_handle first_vertex (Edge_handle edge_handle) const
 returns the first vertex of an edge More...
Vertex_handle second_vertex (Edge_handle edge_handle) const
Simplex_handle get_vertices (Edge_handle edge_handle) const
 returns the simplex made with the two vertices of the edge More...
Edge_handle add_edge (Vertex_handle a, Vertex_handle b)
 Adds an edge between vertices a and b and all its cofaces.
void add_edges (const Simplex_handle &sigma)
 Adds all edges and their cofaces of a simplex to the simplicial complex.
virtual Edge_handle remove_edge (Vertex_handle a, Vertex_handle b)
 Removes an edge from the simplicial complex and all its cofaces. More...
void remove_edge (Edge_handle edge)
 Removes edge and its cofaces from the simplicial complex.
void keep_only_vertices ()
 The complex is reduced to its set of vertices. All the edges and blockers are removed.
bool contains_edge (Vertex_handle a, Vertex_handle b) const
bool contains_edges (const Simplex_handle &sigma) const
std::string to_string () const
std::string vertices_to_string () const
std::string edges_to_string () const
std::string blockers_to_string () const
bool is_popable_blocker (Blocker_handle sigma) const
void remove_popable_blockers ()
void remove_popable_blockers (Vertex_handle v)
void remove_all_popable_blockers (Vertex_handle v)
 Removes all the popable blockers of the complex passing through v and delete them. Also remove popable blockers in the neighborhood if they became popable.
void remove_star (Vertex_handle v)
void remove_star (Vertex_handle a, Vertex_handle b)
void remove_star (Edge_handle e)
void remove_star (const Simplex_handle &sigma)
void add_simplex (const Simplex_handle &sigma)
 add a maximal simplex plus all its cofaces. More...
simplifiable_status is_remove_star_homotopy_preserving (const Simplex_handle &simplex)
virtual contractible_status is_contractible () const
 Test if the complex is reducible using a strategy defined in the class (by default it tests if the complex is a cone) More...
Complex_vertex_range vertex_range () const
 Returns a Complex_vertex_range over all vertices of the complex.
Complex_neighbors_vertices_range vertex_range (Vertex_handle v) const
 Returns a Complex_edge_range over all edges of the simplicial complex that passes trough v.
Complex_edge_range edge_range () const
 Returns a Complex_edge_range over all edges of the simplicial complex.
Complex_edge_around_vertex_range edge_range (Vertex_handle v) const
 Returns a Complex_edge_range over all edges of the simplicial complex that passes through 'v'.
Complex_triangle_around_vertex_range triangle_range (Vertex_handle v) const
 Range over triangles around a vertex of the simplicial complex. Methods .begin() and .end() return a Triangle_around_vertex_iterator.
Complex_triangle_range triangle_range () const
 Range over triangles of the simplicial complex. Methods .begin() and .end() return a Triangle_around_vertex_iterator.
Complex_simplex_around_vertex_range simplex_range (Vertex_handle v) const
 Returns a Complex_simplex_around_vertex_range over all the simplices around a vertex of the complex.
Complex_simplex_range simplex_range () const
 Returns a Complex_simplex_range over all the simplices of the complex.
 Skeleton_blocker_complex (int num_vertices_=0, Visitor *visitor_=NULL)
 constructs a simplicial complex with a given number of vertices and a visitor.
 Skeleton_blocker_complex (SimpleHandleOutputIterator simplex_begin, SimpleHandleOutputIterator simplex_end, bool is_flag_complex=false, Visitor *visitor_=NULL)
 Skeleton_blocker_complex (const Skeleton_blocker_complex &copy)
Skeleton_blocker_complexoperator= (const Skeleton_blocker_complex &copy)
bool operator== (const Skeleton_blocker_complex &other) const
bool operator!= (const Skeleton_blocker_complex &other) const
virtual ~Skeleton_blocker_complex ()
virtual void clear ()
void set_visitor (Visitor *other_visitor)
 allows to change the visitor.
Complex_blocker_around_vertex_range blocker_range (Vertex_handle v)
 Returns a range of the blockers of the complex passing through a vertex.
Complex_blocker_range blocker_range ()
 Returns a range of the blockers of the complex.
Const_complex_blocker_around_vertex_range const_blocker_range (Vertex_handle v) const
Const_complex_blocker_range const_blocker_range () const
Blocker_handle add_blocker (const Simplex_handle &blocker)
 Adds the simplex to the set of blockers and returns a Blocker_handle toward it if was not present before and 0 otherwise.
void remove_blocker (const Blocker_handle sigma)
 Removes the simplex from the set of blockers. More...
void remove_blockers ()
 Remove all blockers, in other words, it expand the simplicial complex to the smallest flag complex that contains it.
void delete_blocker (Blocker_handle sigma)
bool contains_blocker (const Blocker_handle s) const
bool contains_blocker (const Simplex_handle &s) const
bool link_condition (Vertex_handle a, Vertex_handle b, bool ignore_popable_blockers=false) const
bool link_condition (Edge_handle e, bool ignore_popable_blockers=false) const
void contract_edge (Edge_handle edge)
void contract_edge (Vertex_handle a, Vertex_handle b)
Additional Inherited Members
- Public Types inherited from Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerGeometricDS >
typedef
SkeletonBlockerGeometricDS::Graph_vertex
Graph_vertex
 The type of stored vertex node, specified by the template SkeletonBlockerDS.
typedef
SkeletonBlockerGeometricDS::Graph_edge
Graph_edge
 The type of stored edge node, specified by the template SkeletonBlockerDS.
typedef
SkeletonBlockerGeometricDS::Vertex_handle
Vertex_handle
 The type of an handle to a vertex of the complex.
typedef
Skeleton_blocker_simplex
< Vertex_handle
Simplex_handle
 A ordered set of integers that represents a simplex.
typedef Simplex_handleBlocker_handle
 Handle to a blocker of the complex.
typedef boost::graph_traits
< Graph >::edge_descriptor
Edge_handle
 Handle to an edge of the complex.
enum  simplifiable_status
enum  contractible_status
typedef Vertex_iterator
< Skeleton_blocker_complex
Complex_vertex_iterator
typedef boost::iterator_range
< Complex_vertex_iterator
typedef
Neighbors_vertices_iterator
Complex_neighbors_vertices_iterator
< Complex_neighbors_vertices_iterator >
typedef Edge_iterator
Complex_edge_iterator
< Complex_edge_iterator
Complex_edge_range
typedef
Edge_around_vertex_iterator
Complex_edge_around_vertex_iterator
< Complex_edge_around_vertex_iterator >
typedef
< Skeleton_blocker_complex,
Superior_link
Superior_triangle_around_vertex_iterator
< Triangle_around_vertex_iterator
Link > >
< Triangle_iterator
< Skeleton_blocker_complex > >
typedef Triangle_iterator
Complex_triangle_iterator
typedef
Simplex_around_vertex_iterator
Link
Complex_simplex_around_vertex_iterator
< Complex_simplex_around_vertex_iterator
 Range over the simplices of the simplicial complex around a vertex. Methods .begin() and .end() return a Complex_simplex_around_vertex_iterator.
typedef Simplex_iterator
Complex_simplex_iterator
< Complex_simplex_iterator >
Detailed Description
template<typename SkeletonBlockerGeometricDS>
class Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS >
Constructor & Destructor Documentation
Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS >::Skeleton_blocker_geometric_complex ( int  num_vertices,
PointIterator  end
inlineexplicit
constructor given a list of points
Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS >::Skeleton_blocker_geometric_complex ( SimpleHandleOutputIterator  simplex_begin,
bool  is_flag_complex = false
inline
is_flag_complex indicates if the complex is a flag complex or not (to know if blockers have to be computed or not).
inline
Member Function Documentation
Abstract_link Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS >::abstract_link ( Vertex_handle  v) const
inline
Constructs the abstract link of v (without points coordinates).
Abstract_link Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS >::abstract_link ( const Simplex_handle simplex) const
inline
Constructs the link of 'simplex' with points coordinates.
Abstract_link Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS >::abstract_link ( Edge_handle  edge) const
inline
Geometric_link Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS >::link ( Vertex_handle  v) const
inline
Geometric_link Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS >::link ( const Simplex_handle simplex) const
inline
Geometric_link Gudhi::skbl::Skeleton_blocker_geometric_complex< SkeletonBlockerGeometricDS >::link ( Edge_handle  edge) const
inline
The documentation for this class was generated from the following file:
