Gudhi  1.2.0
 All Classes Functions Variables Typedefs Friends Groups Pages
Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > Class Template Reference
Abstract Simplicial Complex represented with a skeleton/blockers pair. More...
#include <Skeleton_blocker_complex.h>
Public Types
typedef
SkeletonBlockerDS::Graph_vertex
Graph_vertex
 The type of stored vertex node, specified by the template SkeletonBlockerDS.
typedef
SkeletonBlockerDS::Graph_edge
Graph_edge
 The type of stored edge node, specified by the template SkeletonBlockerDS.
typedef
SkeletonBlockerDS::Vertex_handle
Vertex_handle
 The type of an handle to a vertex of the complex.
typedef
Skeleton_blocker_simplex
< Vertex_handle
Simplex_handle
 A ordered set of integers that represents a simplex.
typedef Simplex_handleBlocker_handle
 Handle to a blocker of the complex.
typedef boost::graph_traits
< Graph >::edge_descriptor
Edge_handle
 Handle to an edge of the complex.
Public Member Functions
Link_complex link (Vertex_handle v) const
Link_complex link (Edge_handle edge) const
Link_complex link (const Simplex_handle &simplex) const
boost::optional< Simplex_handleget_simplex_address (const Root_simplex_handle &s) const
 Compute the local vertices of 's' in the current complex If one of them is not present in the complex then the return value is uninitialized.
Root_simplex_handle get_id (const Simplex_handle &local_simplex) const
 returns a simplex with vertices which are the id of vertices of the argument.
virtual bool contains (const Simplex_handle &s) const
 returns true iff the simplex s belongs to the simplicial complex.
int num_connected_components () const
 returns the number of connected components in the graph of the 1-skeleton.
bool is_cone () const
 Test if the complex is a cone. More...
Vertices operations
Vertex_handle operator[] (Root_vertex_handle global) const
 Return a local Vertex_handle of a vertex given a global one. More...
Graph_vertexoperator[] (Vertex_handle address)
 Return the vertex node associated to local Vertex_handle. More...
const Graph_vertexoperator[] (Vertex_handle address) const
Vertex_handle add_vertex ()
 Adds a vertex to the simplicial complex and returns its Vertex_handle.
void remove_vertex (Vertex_handle address)
 Remove a vertex from the simplicial complex. More...
bool contains_vertex (Vertex_handle u) const
bool contains_vertex (Root_vertex_handle u) const
bool contains_vertices (const Simplex_handle &sigma) const
virtual boost::optional
< Vertex_handle
get_address (Root_vertex_handle id) const
 Given an Id return the address of the vertex having this Id in the complex. More...
Root_vertex_handle get_id (Vertex_handle local) const
Vertex_handle convert_handle_from_another_complex (const Skeleton_blocker_complex &other, Vertex_handle vh_in_other) const
 Convert an address of a vertex of a complex to the address in the current complex. More...
int degree (Vertex_handle local) const
 return the graph degree of a vertex.
Edges operations
boost::optional< Edge_handleoperator[] (const std::pair< Vertex_handle, Vertex_handle > &ab) const
 return an edge handle if the two vertices forms an edge in the complex
Graph_edgeoperator[] (Edge_handle edge_handle)
 returns the stored node associated to an edge
const Graph_edgeoperator[] (Edge_handle edge_handle) const
Vertex_handle first_vertex (Edge_handle edge_handle) const
 returns the first vertex of an edge More...
Vertex_handle second_vertex (Edge_handle edge_handle) const
Simplex_handle get_vertices (Edge_handle edge_handle) const
 returns the simplex made with the two vertices of the edge More...
Edge_handle add_edge (Vertex_handle a, Vertex_handle b)
 Adds an edge between vertices a and b and all its cofaces.
void add_edges (const Simplex_handle &sigma)
 Adds all edges and their cofaces of a simplex to the simplicial complex.
virtual Edge_handle remove_edge (Vertex_handle a, Vertex_handle b)
 Removes an edge from the simplicial complex and all its cofaces. More...
void remove_edge (Edge_handle edge)
 Removes edge and its cofaces from the simplicial complex.
void keep_only_vertices ()
 The complex is reduced to its set of vertices. All the edges and blockers are removed.
bool contains_edge (Vertex_handle a, Vertex_handle b) const
bool contains_edges (const Simplex_handle &sigma) const
Print and IO methods
std::string to_string () const
std::string vertices_to_string () const
std::string edges_to_string () const
std::string blockers_to_string () const
Constructors, Destructors
 Skeleton_blocker_complex (int num_vertices_=0, Visitor *visitor_=NULL)
 constructs a simplicial complex with a given number of vertices and a visitor.
template<typename SimpleHandleOutputIterator >
 Skeleton_blocker_complex (SimpleHandleOutputIterator simplex_begin, SimpleHandleOutputIterator simplex_end, bool is_flag_complex=false, Visitor *visitor_=NULL)
 Constructor with a list of simplices. More...
 Skeleton_blocker_complex (const Skeleton_blocker_complex &copy)
Skeleton_blocker_complexoperator= (const Skeleton_blocker_complex &copy)
bool operator== (const Skeleton_blocker_complex &other) const
bool operator!= (const Skeleton_blocker_complex &other) const
virtual ~Skeleton_blocker_complex ()
virtual void clear ()
void set_visitor (Visitor *other_visitor)
 allows to change the visitor.
Blockers operations
Blocker_handle add_blocker (const Simplex_handle &blocker)
 Adds the simplex to the set of blockers and returns a Blocker_handle toward it if was not present before and 0 otherwise.
void remove_blocker (const Blocker_handle sigma)
 Removes the simplex from the set of blockers. More...
void remove_blockers ()
 Remove all blockers, in other words, it expand the simplicial complex to the smallest flag complex that contains it.
void delete_blocker (Blocker_handle sigma)
bool contains_blocker (const Blocker_handle s) const
bool contains_blocker (const Simplex_handle &s) const
Simplification operations
enum  simplifiable_status
enum  contractible_status
bool is_popable_blocker (Blocker_handle sigma) const
void remove_popable_blockers ()
void remove_popable_blockers (Vertex_handle v)
void remove_all_popable_blockers (Vertex_handle v)
 Removes all the popable blockers of the complex passing through v and delete them. Also remove popable blockers in the neighborhood if they became popable.
void remove_star (Vertex_handle v)
void remove_star (Vertex_handle a, Vertex_handle b)
void remove_star (Edge_handle e)
void remove_star (const Simplex_handle &sigma)
void add_simplex (const Simplex_handle &sigma)
 add a maximal simplex plus all its cofaces. More...
simplifiable_status is_remove_star_homotopy_preserving (const Simplex_handle &simplex)
virtual contractible_status is_contractible () const
 Test if the complex is reducible using a strategy defined in the class (by default it tests if the complex is a cone) More...
Edge contraction operations
bool link_condition (Vertex_handle a, Vertex_handle b, bool ignore_popable_blockers=false) const
bool link_condition (Edge_handle e, bool ignore_popable_blockers=false) const
void contract_edge (Edge_handle edge)
void contract_edge (Vertex_handle a, Vertex_handle b)
Vertex iterators
typedef Vertex_iterator
< Skeleton_blocker_complex
Complex_vertex_iterator
typedef boost::iterator_range
< Complex_vertex_iterator
Complex_vertex_range
typedef
Neighbors_vertices_iterator
Complex_neighbors_vertices_iterator
< Complex_neighbors_vertices_iterator >
Complex_neighbors_vertices_range
Complex_vertex_range vertex_range () const
 Returns a Complex_vertex_range over all vertices of the complex.
Complex_neighbors_vertices_range vertex_range (Vertex_handle v) const
 Returns a Complex_edge_range over all edges of the simplicial complex that passes trough v.
Edge iterators
typedef Edge_iterator
Complex_edge_iterator
< Complex_edge_iterator
Complex_edge_range
typedef
Edge_around_vertex_iterator
Complex_edge_around_vertex_iterator
< Complex_edge_around_vertex_iterator >
Complex_edge_around_vertex_range
Complex_edge_range edge_range () const
 Returns a Complex_edge_range over all edges of the simplicial complex.
Complex_edge_around_vertex_range edge_range (Vertex_handle v) const
 Returns a Complex_edge_range over all edges of the simplicial complex that passes through 'v'.
Triangles iterators
typedef
Triangle_around_vertex_iterator
< Skeleton_blocker_complex,
Superior_link
Superior_triangle_around_vertex_iterator
< Triangle_around_vertex_iterator
Link > >
Complex_triangle_around_vertex_range
< Triangle_iterator
< Skeleton_blocker_complex > >
Complex_triangle_range
typedef Triangle_iterator
Complex_triangle_iterator
Complex_triangle_around_vertex_range triangle_range (Vertex_handle v) const
 Range over triangles around a vertex of the simplicial complex. Methods .begin() and .end() return a Triangle_around_vertex_iterator.
Complex_triangle_range triangle_range () const
 Range over triangles of the simplicial complex. Methods .begin() and .end() return a Triangle_around_vertex_iterator.
Simplices iterators
typedef
Simplex_around_vertex_iterator
Link
Complex_simplex_around_vertex_iterator
< Complex_simplex_around_vertex_iterator
Complex_simplex_around_vertex_range
 Range over the simplices of the simplicial complex around a vertex. Methods .begin() and .end() return a Complex_simplex_around_vertex_iterator.
typedef Simplex_iterator
Complex_simplex_iterator
< Complex_simplex_iterator >
Complex_simplex_range
Complex_simplex_around_vertex_range simplex_range (Vertex_handle v) const
 Returns a Complex_simplex_around_vertex_range over all the simplices around a vertex of the complex.
Complex_simplex_range simplex_range () const
 Returns a Complex_simplex_range over all the simplices of the complex.
Blockers iterators
Complex_blocker_around_vertex_range blocker_range (Vertex_handle v)
 Returns a range of the blockers of the complex passing through a vertex.
Const_complex_blocker_around_vertex_range const_blocker_range (Vertex_handle v) const
Complex_blocker_range blocker_range ()
 Returns a range of the blockers of the complex.
Const_complex_blocker_range const_blocker_range () const
Detailed Description
template<class SkeletonBlockerDS>
class Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >
Constructor & Destructor Documentation
Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::Skeleton_blocker_complex ( SimpleHandleOutputIterator  simplex_begin,
bool  is_flag_complex = false,
Visitor visitor_ = NULL
inline
is_flag_complex indicates if the complex is a flag complex or not (to know if blockers have to be computed or not).
virtual Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::~Skeleton_blocker_complex ( )
inlinevirtual
The destructor delete all blockers allocated.
Member Function Documentation
template<typename SkeletonBlockerDS >
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::add_simplex ( const Simplex_handle sigma)
add a maximal simplex plus all its cofaces. All vertices lower than the higher vertex of sigma must already be present.
the simplex must have dimension greater than one (otherwise use add_vertex or add_edge).
virtual void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::clear ( )
inlinevirtual
Clears the simplicial complex. After a call to this function, blockers are destroyed. The 1-skeleton and the set of blockers are both empty.
Reimplemented in Gudhi::skbl::Skeleton_blocker_sub_complex< ComplexType >.
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::contains_blocker ( const Blocker_handle  s) const
inline
Returns
true iff s is a blocker of the simplicial complex
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::contains_blocker ( const Simplex_handle s) const
inline
Returns
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::contains_edge ( Vertex_handle  a,
Vertex_handle  b
) const
inline
Returns
true iff the simplicial complex contains an edge between vertices a and b
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::contains_edges ( const Simplex_handle sigma) const
inline
Returns
true iff the simplicial complex contains all vertices and all edges of simplex sigma
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::contains_vertices ( const Simplex_handle sigma) const
inline
Returns
true iff the simplicial complex contains all vertices of simplex sigma
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::contract_edge ( Edge_handle  edge)
inline
Contracts the edge.
Remarks
If the link condition Link(ab) = Link(a) inter Link(b) is not satisfied, it removes first all blockers passing through 'ab'
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::contract_edge ( Vertex_handle  a,
Vertex_handle  b
Contracts the edge connecting vertices a and b.
Remarks
Vertex_handle Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::convert_handle_from_another_complex ( const Skeleton_blocker_complex< SkeletonBlockerDS > &  other,
) const
inline
If the current complex is a sub (or sup) complex of 'other', it converts the address of a vertex v expressed in 'other' to the address of the vertex v in the current one.
Remarks
this methods uses Root_vertex_handle to identify the vertex and assumes the vertex is present in the current complex.
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::delete_blocker ( Blocker_handle  sigma)
inline
Removes the simplex s from the set of blockers and desallocate s.
Vertex_handle Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::first_vertex ( Edge_handle  edge_handle) const
inline
it assumes that the edge is present in the complex
virtual boost::optional<Vertex_handle> Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::get_address ( Root_vertex_handle  id) const
inlinevirtual
Remarks
For a simplicial complex, the address is the id but it may not be the case for a SubComplex.
Root_vertex_handle Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::get_id ( Vertex_handle  local) const
inline
return the id of a vertex of adress local present in the graph
Simplex_handle Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::get_vertices ( Edge_handle  edge_handle) const
inline
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::is_cone ( ) const
inline
Runs in O(n) where n is the number of vertices.
virtual contractible_status Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::is_contractible ( ) const
inlinevirtual
Note that NO could be returned if some invariant ensures that the complex is not a point (for instance if the euler characteristic is different from 1). This function will surely have to return MAYBE in some case because the associated problem is undecidable but it in practice, it can often be solved with the help of geometry.
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::is_popable_blocker ( Blocker_handle  sigma) const
Returns true iff the blocker 'sigma' is popable. To define popable, let us call 'L' the complex that consists in the current complex without the blocker 'sigma'. A blocker 'sigma' is then "popable" if the link of 'sigma' in L is reducible.
Link_complex Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::link ( Vertex_handle  v) const
inline
Constructs the link of 'simplex' with points coordinates.
Link_complex Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::link ( Edge_handle  edge) const
inline
Link_complex Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::link ( const Simplex_handle simplex) const
inline
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::link_condition ( Vertex_handle  a,
Vertex_handle  b,
bool  ignore_popable_blockers = false
) const
inline
Returns
If ignore_popable_blockers is true then the result is true iff the link condition at edge ab is satisfied or equivalently iff no blocker contains ab. If ignore_popable_blockers is false then the result is true iff all blocker containing ab are popable.
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::link_condition ( Edge_handle  e,
) const
inline
Returns
bool Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::operator== ( const Skeleton_blocker_complex< SkeletonBlockerDS > &  other) const
inline
return true if both complexes have the same simplices.
Vertex_handle Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::operator[] ( Root_vertex_handle  global) const
inline
Remarks
Assume that the vertex is present in the complex.
Graph_vertex& Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::operator[] ( Vertex_handle  address)
inline
Remarks
const Graph_vertex& Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::operator[] ( Vertex_handle  address) const
inline
Remarks
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::remove_blocker ( const Blocker_handle  sigma)
inline
Remarks
sigma has to belongs to the set of blockers
virtual Edge_handle Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::remove_edge ( Vertex_handle  a,
Vertex_handle  b
inlinevirtual
returns the former Edge_handle representing the edge
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::remove_popable_blockers ( )
Removes all the popable blockers of the complex and delete them.
Returns
the number of popable blockers deleted
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::remove_popable_blockers ( Vertex_handle  v)
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::remove_star ( Vertex_handle  v)
Remove the star of the vertex 'v'
Remove the star of the vertice 'v'
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::remove_star ( Vertex_handle  a,
Vertex_handle  b
Remove the star of the edge connecting vertices a and b.
Returns
the number of blocker that have been removed
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::remove_star ( Edge_handle  e)
Remove the star of the edge 'e'.
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::remove_star ( const Simplex_handle sigma)
Remove the star of the simplex 'sigma' which needs to belong to the complex
void Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::remove_vertex ( Vertex_handle  address)
inline
Remarks
It just deactivates the vertex with a boolean flag but does not remove it from vertices from complexity issues.
Vertex_handle Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS >::second_vertex ( Edge_handle  edge_handle) const
inline
The documentation for this class was generated from the following files:
