Gudhi  1.2.0
 All Classes Functions Variables Typedefs Friends Groups Pages
Gudhi::skbl::SkeletonBlockerDS Struct Reference
Concept for the template class passed for Skeleton_blocker_complex. Most importantly, it contains the nodes for vertices and edges (Graph_vertex and Graph_edge) that are stored in the simplicial complex. The user can redefine these classes to attach additional information to vertices and edges. More...
#include <SkeletonBlockerDS.h>
Classes
struct  Graph_edge
 The type of edges that are stored the boost graph. An Edge must be Default Constructible and Equality Comparable. More...
struct  Graph_vertex
 The type of vertices that are stored the boost graph. A Vertex must be Default Constructible and Equality Comparable. More...
struct  Root_vertex_handle
 Root_vertex_handle and Vertex_handle are similar to global and local vertex descriptor used in boost subgraphs and allow to localize a vertex of a subcomplex on its parent root complex. More...
struct  Vertex_handle
Public Types
typedef int boost_vertex_handle
 index that allows to find the vertex in the boost graph
Detailed Description
The documentation for this struct was generated from the following file:
