add_blocker(const Simplex_handle &blocker) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
add_edge(Vertex_handle a, Vertex_handle b) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
add_edges(const Simplex_handle &sigma) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
add_simplex(const Simplex_handle &sigma) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
add_vertex() | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Blocker_handle typedef | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
blocker_range(Vertex_handle v) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
blocker_range() | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
clear() | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
Complex_simplex_around_vertex_range typedef | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
const_blocker_range(Vertex_handle v) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
const_blocker_range() const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains(const Simplex_handle &s) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
contains_blocker(const Blocker_handle s) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains_blocker(const Simplex_handle &s) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains_edge(Vertex_handle a, Vertex_handle b) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains_edges(const Simplex_handle &sigma) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains_vertices(const Simplex_handle &sigma) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contract_edge(Edge_handle edge) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contract_edge(Vertex_handle a, Vertex_handle b) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
convert_handle_from_another_complex(const Skeleton_blocker_complex &other, Vertex_handle vh_in_other) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
degree(Vertex_handle local) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
delete_blocker(Blocker_handle sigma) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Edge_handle typedef | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
edge_range() const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
edge_range(Vertex_handle v) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
first_vertex(Edge_handle edge_handle) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
get_address(Root_vertex_handle id) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
get_id(Vertex_handle local) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
get_id(const Simplex_handle &local_simplex) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
get_simplex_address(const Root_simplex_handle &s) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
get_vertices(Edge_handle edge_handle) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Graph_edge typedef | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
Graph_vertex typedef | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
is_cone() const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
is_contractible() const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
is_popable_blocker(Blocker_handle sigma) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
keep_only_vertices() | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link(Vertex_handle v) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link(Edge_handle edge) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link(const Simplex_handle &simplex) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link_condition(Vertex_handle a, Vertex_handle b, bool ignore_popable_blockers=false) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link_condition(Edge_handle e, bool ignore_popable_blockers=false) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
num_connected_components() const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator==(const Skeleton_blocker_complex &other) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Root_vertex_handle global) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Vertex_handle address) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Vertex_handle address) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](const std::pair< Vertex_handle, Vertex_handle > &ab) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Edge_handle edge_handle) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Edge_handle edge_handle) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
remove_all_popable_blockers(Vertex_handle v) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_blocker(const Blocker_handle sigma) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
remove_blockers() | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
remove_edge(Vertex_handle a, Vertex_handle b) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
remove_edge(Edge_handle edge) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
remove_popable_blockers() | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_popable_blockers(Vertex_handle v) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_star(Vertex_handle v) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_star(Vertex_handle a, Vertex_handle b) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_star(Edge_handle e) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_star(const Simplex_handle &sigma) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_vertex(Vertex_handle address) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
second_vertex(Edge_handle edge_handle) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
set_visitor(Visitor *other_visitor) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Simplex_handle typedef | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
simplex_range(Vertex_handle v) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
simplex_range() const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Skeleton_blocker_complex(int num_vertices_=0, Visitor *visitor_=NULL) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inlineexplicit |
Skeleton_blocker_complex(SimpleHandleOutputIterator simplex_begin, SimpleHandleOutputIterator simplex_end, bool is_flag_complex=false, Visitor *visitor_=NULL) | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
triangle_range(Vertex_handle v) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
triangle_range() const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Vertex_handle typedef | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | |
vertex_range() const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
vertex_range(Vertex_handle v) const | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
~Skeleton_blocker_complex() | Gudhi::skbl::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
