Point cloud utilities manual¶
File Readers¶
gudhi.read_points_from_off_file()¶ Read points from OFF file.
- Parameters
off_file¶ (string) – An OFF file style name.
- Returns
The point set.
- Return type
List[List[float]]
gudhi.read_lower_triangular_matrix_from_csv_file()¶ Read lower triangular matrix from a CSV style file.
Subsampling¶
gudhi.subsampling.choose_n_farthest_points()¶ Subsample by a greedy strategy of iteratively adding the farthest point from the current chosen point set to the subsampling. The iteration starts with the landmark starting point.
- Parameters
points¶ (Iterable[Iterable[float]]) – The input point set.
Or
- Parameters
And in both cases
- Parameters
- Returns
The subsample point set.
- Return type
List[List[float]]
gudhi.subsampling.pick_n_random_points()¶ Subsample a point set by picking random vertices.
- Parameters
Or
- Parameters
And in both cases
- Parameters
nb_points¶ (unsigned.) – Number of points of the subsample.
- Returns
- Return type
List[List[float]]
gudhi.subsampling.sparsify_point_set()¶ Outputs a subset of the input points so that the squared distance between any two points is greater than or equal to min_squared_dist.
- Parameters
Or
- Parameters
And in both cases
- Parameters
min_squared_dist¶ (float.) – Minimum squared distance separating the output points.
- Returns
- Return type
List[List[float]]
