Cubical complex reference manual¶
class
gudhi.CubicalComplex¶ Bases:
objectThe CubicalComplex is an example of a structured complex useful in computational mathematics (specially rigorous numerics) and image analysis.
__init__()¶ CubicalComplex constructor from dimensions and top_dimensional_cells or from a Perseus-style file name.
- Parameters
Or
- Parameters
top_dimensional_cells¶ (anything convertible to a numpy ndarray) – A multidimensional array of cells filtration values.
Or
- Parameters
perseus_file¶ (string) – A Perseus-style file name.
betti_numbers()¶ This function returns the Betti numbers of the complex.
- Returns
list of int – The Betti numbers ([B0, B1, …, Bn]).
- Note
betti_numbers function requires persistence function to be launched first.
- Note
betti_numbers function always returns [1, 0, 0, …] as infinity filtration cubes are not removed from the complex.
dimension()¶ This function returns the dimension of the complex.
- Returns
int – the complex dimension.
num_simplices()¶ This function returns the number of all cubes in the complex.
- Returns
int – the number of all cubes in the complex.
persistence()¶ This function returns the persistence of the complex.
- Parameters
- Returns
list of pairs(dimension, pair(birth, death)) – the persistence of the complex.
persistence_intervals_in_dimension()¶ This function returns the persistence intervals of the complex in a specific dimension.
- Parameters
dimension¶ (int.) – The specific dimension.
- Returns
The persistence intervals.
- Return type
numpy array of dimension 2
- Note
intervals_in_dim function requires persistence function to be launched first.
persistent_betti_numbers()¶ This function returns the persistent Betti numbers of the complex.
- Parameters
- Returns
list of int – The persistent Betti numbers ([B0, B1, …, Bn]).
- Note
persistent_betti_numbers function requires persistence function to be launched first.
