Witness complex reference manual¶
class
gudhi.
WitnessComplex
¶ Bases:
object
Constructs (weak) witness complex for a given table of nearest landmarks with respect to witnesses.
__init__
()¶ WitnessComplex constructor.
Parameters: nearest_landmark_table (list of list of pair of unsigned and double) – A list of nearest landmark.
create_simplex_tree
()¶ Parameters: max_alpha_square (float) – The maximum alpha square threshold the simplices shall not exceed. Default is set to infinity. Returns: A simplex tree created from the Delaunay Triangulation. Return type: SimplexTree
