Strong witness complex reference manual
class gudhi.StrongWitnessComplex
Bases: object
Constructs (strong) witness complex for a given table of nearest landmarks with respect to witnesses.
__init__()
StrongWitnessComplex constructor.
Parameters:nearest_landmark_table (list of list of pair of unsigned and double) – A list of nearest landmark.
create_simplex_tree()
Parameters:max_alpha_square (float) – The maximum alpha square threshold the simplices shall not exceed. Default is set to infinity.
Returns:A simplex tree created from the Delaunay Triangulation.
Return type:SimplexTree
