Persistence graphical tools reference manual¶
gudhi.__min_birth_max_death()¶ This function returns (min_birth, max_death) from the persistence.
Parameters: - persistence (list of tuples(dimension, tuple(birth, death))) – The persistence to plot.
- band (float.) – band
Returns: (float, float) – (min_birth, max_death).
gudhi.plot_persistence_barcode()¶ This function plots the persistence bar code from persistence values list or from a persistence file.
Parameters: - persistence (list of tuples(dimension, tuple(birth, death))) – Persistence values list.
- persistence_file (string) – A persistence file style name (reset persistence if both are set).
- alpha (float.) – barcode transparency value (0.0 transparent through 1.0 opaque - default is 0.6).
- max_barcodes (int.) – number of maximal barcodes to be displayed. Set it to 0 to see all, Default value is 1000. (persistence will be sorted by life time if max_barcodes is set)
- inf_delta (float.) – Infinity is placed at ((max_death - min_birth) x inf_delta). A reasonable value is between 0.05 and 0.5 - default is 0.1.
Returns: A matplotlib object containing horizontal bar plot of persistence (launch show() method on it to display it).
gudhi.plot_persistence_diagram()¶ This function plots the persistence diagram from persistence values list or from a persistence file.
- alpha (float.) – plot transparency value (0.0 transparent through 1.0 opaque - default is 0.6).
- band (float.) – band (not displayed if \(\leq\) 0. - default is 0.)
- max_plots (int.) – number of maximal plots to be displayed Set it to 0 to see all, Default value is 1000. (persistence will be sorted by life time if max_plots is set)
Returns: A matplotlib object containing diagram plot of persistence (launch show() method on it to display it).
