Euclidean witness complex reference manual¶
class
gudhi.
EuclideanWitnessComplex
¶ Bases:
object
Constructs (weak) witness complex for given sets of witnesses and landmarks in Euclidean space.
__init__
()¶ WitnessComplex constructor.
Parameters: - landmarks (list of list of double) – A list of landmarks (in the point cloud).
- witnesses (list of list of double) – The point cloud.
create_simplex_tree
()¶ Parameters: max_alpha_square (float) – The maximum alpha square threshold the simplices shall not exceed. Default is set to infinity. Returns: A simplex tree created from the Delaunay Triangulation. Return type: SimplexTree
get_point
()¶ This function returns the point corresponding to a given vertex.
Parameters: vertex (int.) – The vertex. Returns: The point. Return type: list of float
