All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
reader_utils.h File Reference
This file includes common file reader for GUDHI. More...
Go to the source code of this file.
Functions
void Gudhi::read_points (std::string file_name, std::vector< std::vector< double > > &points)
 Read a set of points to turn it into a vector< vector<double> > by filling points. More...
template<typename Graph_t , typename Filtration_value , typename Vertex_handle >
Graph_t Gudhi::read_graph (std::string file_name)
 Read a graph from a file. More...
template<typename Vertex_handle , typename Filtration_value >
bool Gudhi::read_simplex (std::istream &in_, std::vector< Vertex_handle > &simplex, Filtration_value &fil)
 Read a face from a file. More...
template<typename Simplex_key , typename Filtration_value >
bool Gudhi::read_hasse_simplex (std::istream &in_, std::vector< Simplex_key > &boundary, Filtration_value &fil)
 Read a hasse simplex from a file. More...
template<typename Filtration_value >
std::vector< std::vector< Filtration_value > > Gudhi::read_lower_triangular_matrix_from_csv_file (const std::string &filename, const char separator=';')
 Read a lower triangular distance matrix from a csv file. We assume that the .csv store the whole (square) matrix. More...
template<typename OutputIterator >
void Gudhi::read_persistence_intervals_and_dimension (std::string const &filename, OutputIterator out)
std::map< int, std::vector< std::pair< double, double > > > Gudhi::read_persistence_intervals_grouped_by_dimension (std::string const &filename)
std::vector< std::pair< double, double > > Gudhi::read_persistence_intervals_in_dimension (std::string const &filename, int only_this_dim=-1)
Detailed Description
Function Documentation
◆ read_graph()
Graph_t Gudhi::read_graph ( std::string  file_name)
Template Parameters
Graph_tType for the return graph. Must be constructible from iterators on pairs of Vertex_handle
Filtration_valueType for the value of the read filtration
Vertex_handleType for the value of the read vertices
File format: 1 simplex per line
Dim1 X11 X12 ... X1d Fil1
Dim2 X21 X22 ... X2d Fil2
etc
The vertices must be labeled from 0 to n-1. Every simplex must appear exactly once. Simplices of dimension more than 1 are ignored.
◆ read_hasse_simplex()
bool Gudhi::read_hasse_simplex ( std::istream &  in_,
std::vector< Simplex_key > &  boundary,
Filtration_value fil
Dim1 k11 k12 ... k1Dim1 Fil1
Dim2 k21 k22 ... k2Dim2 Fil2
etc
The key of a simplex is its position in the filtration order and also the number of its row in the file. Dimi ki1 ki2 ... kiDimi Fili means that the ith simplex in the filtration has dimension Dimi, filtration value fil1 and simplices with key ki1 ... kiDimi in its boundary.
◆ read_lower_triangular_matrix_from_csv_file()
std::vector< std::vector< Filtration_value > > Gudhi::read_lower_triangular_matrix_from_csv_file ( const std::string &  filename,
const char  separator = ';'
Author
Pawel Dlotko
Square matrix file format:
0;D12;...;D1j
D21;0;...;D2j
Dj1;Dj2;...;0
lower matrix file format:
D21;
D31;D32;
Dj1;Dj2;...;Dj(j-1);
◆ read_persistence_intervals_and_dimension()
void Gudhi::read_persistence_intervals_and_dimension ( std::string const &  filename,
OutputIterator  out
Reads a file containing persistence intervals. Each line might contain 2, 3 or 4 values: [[field] dimension] birth death The output iterator out is used this way: *out++ = std::make_tuple(dim, birth, death); where dim is an int, birth a double, and death a double. Note: the function does not check that birth <= death.
◆ read_persistence_intervals_grouped_by_dimension()
std::map< int, std::vector< std::pair< double, double > > > Gudhi::read_persistence_intervals_grouped_by_dimension ( std::string const &  filename)
inline
Reads a file containing persistence intervals. Each line might contain 2, 3 or 4 values: [[field] dimension] birth death The return value is an std::map<dim, std::vector<std::pair<birth, death>>> where dim is an int, birth a double, and death a double. Note: the function does not check that birth <= death.
◆ read_persistence_intervals_in_dimension()
std::vector< std::pair< double, double > > Gudhi::read_persistence_intervals_in_dimension ( std::string const &  filename,
int  only_this_dim = -1
inline
Reads a file containing persistence intervals. Each line might contain 2, 3 or 4 values: [[field] dimension] birth death If only_this_dim = -1, dimension is ignored and all lines are returned. If only_this_dim is >= 0, only the lines where dimension = only_this_dim (or where dimension is not specified) are returned. The return value is an std::vector<std::pair<birth, death>> where dim is an int, birth a double, and death a double. Note: the function does not check that birth <= death.
Examples
bottleneck_distance.cpp.
◆ read_points()
void Gudhi::read_points ( std::string  file_name,
std::vector< std::vector< double > > &  points
inline
File format: 1 point per line
X11 X12 ... X1d
X21 X22 ... X2d
etc
◆ read_simplex()
bool Gudhi::read_simplex ( std::istream &  in_,
std::vector< Vertex_handle > &  simplex,
etc
