- Author
- Vincent Rouvreau
Definition
Alpha_complex is a simplicial complex constructed from the finite cells of a Delaunay Triangulation.
The filtration value of each simplex is computed as the square of the circumradius of the simplex if the circumsphere is empty (the simplex is then said to be Gabriel), and as the minimum of the filtration values of the codimension 1 cofaces that make it not Gabriel otherwise.
All simplices that have a filtration value \( > \alpha^2 \) are removed from the Delaunay complex when creating the simplicial complex if it is specified.
Alpha-complex representation
Alpha_complex is constructing a Delaunay Triangulation [24] from CGAL (the Computational Geometry Algorithms Library [44]) and is able to create a SimplicialComplexForAlpha.
The complex is a template class requiring an Epick_d dD Geometry Kernel [42] from CGAL as template parameter.
Example from points
This example builds the Delaunay triangulation from the given points in a 2D static kernel, and creates a Simplex_tree with it.
Then, it is asked to display information about the simplicial complex.
#include <gudhi/Alpha_complex.h>
#include <gudhi/Simplex_tree.h>
#include <CGAL/Epeck_d.h>
#include <iostream>
#include <vector>
using Kernel = CGAL::Epeck_d< CGAL::Dimension_tag<2> >;
using Point = Kernel::Point_d;
using Vector_of_points = std::vector<Point>;
int main() {
Vector_of_points points;
points.push_back(Point(1.0, 1.0));
points.push_back(Point(7.0, 0.0));
points.push_back(Point(4.0, 6.0));
points.push_back(Point(9.0, 6.0));
points.push_back(Point(0.0, 14.0));
points.push_back(Point(2.0, 19.0));
points.push_back(Point(9.0, 17.0));
if (alpha_complex_from_points.create_complex(simplex)) {
std::clog << "Alpha complex is of dimension " << simplex.dimension() <<
std::clog << "Iterator on alpha complex simplices in the filtration order, with [filtration value]:" << std::endl;
std::clog << " ( ";
std::clog << vertex << " ";
std::clog <<
"[" << simplex.
filtration(f_simplex) <<
std::clog << std::endl;
return 0;
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:95
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:338
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:349
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:614
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:651
size_t num_simplices()
Returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:664
Alpha complex data structure.
Definition: Alpha_complex.h:103
When launching:
$> ./Alpha_complex_example_from_points
the program output is:
Alpha complex is of dimension 2 - 25 simplices - 7 vertices.
( 0 ) -> [0]
( 1 ) -> [0]
( 2 ) -> [0]
( 3 ) -> [0]
( 4 ) -> [0]
( 5 ) -> [0]
( 6 ) -> [0]
( 3 2 ) -> [6.25]
( 5 4 ) -> [7.25]
( 2 0 ) -> [8.5]
( 1 0 ) -> [9.25]
( 3 1 ) -> [10]
( 2 1 ) -> [11.25]
( 3 2 1 ) -> [12.5]
( 2 1 0 ) -> [12.9959]
( 6 5 ) -> [13.25]
( 4 2 ) -> [20]
( 6 4 ) -> [22.7367]
( 6 5 4 ) -> [22.7367]
( 6 3 ) -> [30.25]
( 6 2 ) -> [36.5]
( 6 3 2 ) -> [36.5]
( 6 4 2 ) -> [37.2449]
( 4 0 ) -> [59.7107]
( 4 2 0 ) -> [59.7107]
Create complex algorithm
Data structure
In order to create the simplicial complex, first, it is built from the cells of the Delaunay Triangulation. The filtration values are set to NaN, which stands for unknown value.
In example, :
Simplicial complex structure construction example
Filtration value computation algorithm
\begin{array}{l}
\textbf{for } \text{i : dimension } \rightarrow 0 \textbf{ do}\\
\quad \textbf{for all } \sigma \text{ of dimension i}\\
\quad\quad \textbf{if } \text{filtration(} \sigma ) \text{ is NaN} \textbf{ then}\\
\quad\quad\quad \text{filtration(} \sigma ) = \alpha^2( \sigma )\\
\quad\quad \textbf{end if}\\
\quad\quad \textbf{for all } \tau \text{ face of } \sigma \textbf{ do}\quad\quad
\textit{// propagate alpha filtration value}\\
\quad\quad\quad \textbf{if } \text{filtration(} \tau ) \text{ is not NaN} \textbf{ then}\\
\quad\quad\quad\quad \text{filtration(} \tau \text{) = min( filtration(} \tau \text{), filtration(} \sigma
\text{) )}\\
\quad\quad\quad \textbf{else}\\
\quad\quad\quad\quad \textbf{if } \tau \text{ is not Gabriel for } \sigma \textbf{ then}\\
\quad\quad\quad\quad\quad \text{filtration(} \tau \text{) = filtration(} \sigma \text{)}\\
\quad\quad\quad\quad \textbf{end if}\\
\quad\quad \textbf{end for}\\
\textbf{end for}\\
\text{make_filtration_non_decreasing()}\\
\text{prune_above_filtration()}\\
\end{array}
Dimension 2
From the example above, it means the algorithm looks into each triangle ([0,1,2], [0,2,4], [1,2,3], ...), computes the filtration value of the triangle, and then propagates the filtration value as described here :
Filtration value propagation example
Dimension 1
Then, the algorithm looks into each edge ([0,1], [0,2], [1,2], ...), computes the filtration value of the edge (in this case, propagation will have no effect).
Dimension 0
Finally, the algorithm looks into each vertex ([0], [1], [2], [3], [4], [5] and [6]) and sets the filtration value (0 in case of a vertex - propagation will have no effect).
Non decreasing filtration values
As the squared radii computed by CGAL are an approximation, it might happen that these \( \alpha^2 \) values do not quite define a proper filtration (i.e. non-decreasing with respect to inclusion). We fix that up by calling SimplicialComplexForAlpha::make_filtration_non_decreasing().
- Note
- This is not the case in
exact version, this is the reason why it is not called in this case.
Prune above given filtration value
The simplex tree is pruned from the given maximum \( \alpha^2 \) value (cf. SimplicialComplexForAlpha::prune_above_filtration()). In the following example, the value is given by the user as argument of the program.
Weighted specific version
Requires: Eigen ≥ 3.1.0 and CGAL ≥ 5.1.0.
A weighted version for Alpha complex is available (cf. Alpha_complex). It is like a usual Alpha complex, but based on a CGAL regular triangulation instead of Delaunay.
This example builds the CGAL weighted alpha shapes from a small molecule, and initializes the alpha complex with it. This example is taken from CGAL 3d weighted alpha shapes.
Then, it is asked to display information about the alpha complex.
#include <iostream>
#include <vector>
using Kernel = CGAL::Epeck_d< CGAL::Dimension_tag<3> >;
using Bare_point = Kernel::Point_d;
using Weighted_point = Kernel::Weighted_point_d;
using Vector_of_points = std::vector<Weighted_point>;
int main() {
points.emplace_back(Bare_point(1, -1, -1), 4.);
points.emplace_back(Bare_point(-1, 1, -1), 4.);
points.emplace_back(Bare_point(-1, -1, 1), 4.);
points.emplace_back(Bare_point(1, 1, 1), 4.);
points.emplace_back(Bare_point(2, 2, 2), 1.);
if (alpha_complex_from_weighted_points.create_complex(simplex)) {
std::clog << "Weighted alpha complex is of dimension " << simplex.dimension() <<
std::clog << "Iterator on weighted alpha complex simplices in the filtration order, with [filtration value]:" << std::endl;
std::clog << " ( ";
std::clog <<
"[" << simplex.
return 0;
When launching:
$> ./Weighted_alpha_complex_example_from_points
Weighted alpha complex is of dimension 3 - 29 simplices - 5 vertices.
( 0 ) -> [-4]
( 1 ) -> [-4]
( 2 ) -> [-4]
( 3 ) -> [-4]
( 1 0 ) -> [-2]
( 2 0 ) -> [-2]
( 2 1 ) -> [-2]
( 3 0 ) -> [-2]
( 3 1 ) -> [-2]
( 3 2 ) -> [-2]
( 2 1 0 ) -> [-1.33333]
( 3 1 0 ) -> [-1.33333]
( 3 2 0 ) -> [-1.33333]
( 3 2 1 ) -> [-1.33333]
( 3 2 1 0 ) -> [-1]
( 4 ) -> [-1]
( 4 2 ) -> [-1]
( 4 0 ) -> [23]
( 4 1 ) -> [23]
( 4 2 0 ) -> [23]
( 4 2 1 ) -> [23]
( 4 3 ) -> [23]
( 4 3 2 ) -> [23]
( 4 1 0 ) -> [95]
( 4 2 1 0 ) -> [95]
( 4 3 0 ) -> [95]
( 4 3 1 ) -> [95]
( 4 3 2 0 ) -> [95]
( 4 3 2 1 ) -> [95]
Example from OFF file
This example builds the Delaunay triangulation in a dynamic kernel, and initializes the alpha complex with it.
#include <iostream>
#include <string>
void usage(int nbArgs, char * const progName) {
std::cerr << "Error: Number of arguments (" << nbArgs << ") is not correct\n";
std::cerr << "Usage: " << progName << " filename.off alpha_square_max_value [ouput_file.txt]\n";
std::cerr << " i.e.: " << progName << " ../../data/points/alphacomplexdoc.off 60.0\n";
exit(-1);
int main(int argc, char **argv) {
if ((argc != 3) && (argc != 4)) usage(argc, (argv[0] - 1));
std::string off_file_name {argv[1]};
double alpha_square_max_value {atof(argv[2])};
std::streambuf* streambuffer;
std::ofstream ouput_file_stream;
if (argc == 4) {
ouput_file_stream.open(std::string(argv[3]));
streambuffer = ouput_file_stream.rdbuf();
} else {
streambuffer = std::clog.rdbuf();
if (alpha_complex_from_file.create_complex(simplex, alpha_square_max_value)) {
std::ostream output_stream(streambuffer);
output_stream << "Alpha complex is of dimension " << simplex.dimension() <<
output_stream << "Iterator on alpha complex simplices in the filtration order, with [filtration value]:" <<
std::endl;
output_stream << " ( ";
output_stream << vertex << " ";
output_stream <<
"[" << simplex.
output_stream << std::endl;
ouput_file_stream.close();
return 0;
When launching:
$> ./Alpha_complex_example_from_off ../../data/points/alphacomplexdoc.off 32.0
Alpha complex is of dimension 2 - 20 simplices - 7 vertices.
( 0 ) -> [0]
( 1 ) -> [0]
( 2 ) -> [0]
( 3 ) -> [0]
( 4 ) -> [0]
( 5 ) -> [0]
( 6 ) -> [0]
( 3 2 ) -> [6.25]
( 5 4 ) -> [7.25]
( 2 0 ) -> [8.5]
( 1 0 ) -> [9.25]
( 3 1 ) -> [10]
( 2 1 ) -> [11.25]
( 3 2 1 ) -> [12.5]
( 6 5 ) -> [13.25]
( 4 2 ) -> [20]
( 6 3 ) -> [30.25]
3d specific version
A specific module for Alpha complex is available in 3d (cf. Alpha_complex_3d) and allows to construct standard, weighted, periodic or weighted and periodic versions of alpha complexes. Alpha values computation can be Gudhi::alpha_complex::complexity::FAST, Gudhi::alpha_complex::complexity::SAFE (default value) or Gudhi::alpha_complex::complexity::EXACT.
This example builds the CGAL 3d weighted alpha shapes from a small molecule, and initializes the alpha complex with it. This example is taken from CGAL 3d weighted alpha shapes.
#include <gudhi/Alpha_complex_3d.h>
#include <iostream>
#include <string>
#include <vector>
#include <limits>
std::vector<Weighted_point> weighted_points;
weighted_points.emplace_back(Bare_point(1, -1, -1), 4.);
weighted_points.emplace_back(Bare_point(-1, 1, -1), 4.);
weighted_points.emplace_back(Bare_point(-1, -1, 1), 4.);
weighted_points.emplace_back(Bare_point(1, 1, 1), 4.);
weighted_points.emplace_back(Bare_point(2, 2, 2), 1.);
std::clog <<
" - " << simplex.
num_simplices()
" simplices - " << simplex.
num_vertices() <<
" vertices." << std::endl;
std::clog << " ( ";
std::clog << ") -> "
return 0;
Alpha complex data structure for 3d specific case.
Definition: Alpha_complex_3d.h:118
typename Kernel::Point_3 Bare_point_3
Gives public access to the Bare_point_3 (bare aka. unweighed) type. Here is a Bare_point_3 constructo...
Definition: Alpha_complex_3d.h:230
typename Triangulation_3< Kernel, Tds, Weighted, Periodic >::Weighted_point_3 Weighted_point_3
Gives public access to the Weighted_point_3 type. A Weighted point can be constructed as follows:
Definition: Alpha_complex_3d.h:243
The results will be the same as in Weighted specific version .
◆ complexity
Alpha complex complexity template parameter possible values.
| Enumerator |
| FAST | Fast version.
| SAFE | Safe version.
| EXACT | Exact version.
