All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
graph_simplicial_complex.h File Reference
Graph simplicial complex methods. More...
Go to the source code of this file.
Typedefs
template<typename SimplicialComplexForProximityGraph >
using Gudhi::Proximity_graph = typename boost::adjacency_list< boost::vecS, boost::vecS, boost::directedS, boost::property< vertex_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value >, boost::property< edge_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value > >
 Proximity_graph contains the vertices and edges with their filtration values in order to store the result of Gudhi::compute_proximity_graph function. More...
Functions
template<typename SimplicialComplexForProximityGraph , typename ForwardPointRange , typename Distance >
Proximity_graph< SimplicialComplexForProximityGraph > Gudhi::compute_proximity_graph (const ForwardPointRange &points, typename SimplicialComplexForProximityGraph::Filtration_value threshold, Distance distance)
 Computes the proximity graph of the points. More...
Detailed Description
Typedef Documentation
◆ Proximity_graph
using Gudhi::Proximity_graph = typedef typename boost::adjacency_list < boost::vecS, boost::vecS, boost::directedS , boost::property < vertex_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value > , boost::property < edge_filtration_t, typename SimplicialComplexForProximityGraph::Filtration_value > >
Template Parameters
SimplicialComplexForProximityGraphfurnishes Filtration_value type definition.
Function Documentation
◆ compute_proximity_graph()
Proximity_graph< SimplicialComplexForProximityGraph > Gudhi::compute_proximity_graph ( const ForwardPointRange &  points,
Distance  distance
If points contains n elements, the proximity graph is the graph with n vertices, and an edge [u,v] iff the distance function between points u and v is smaller than threshold.
Template Parameters
SimplicialComplexForProximityGraphfurnishes Filtration_value and Vertex_handle type definitions.
ForwardPointRangefurnishes .begin() and .end() methods.
Distancefurnishes operator()(const Point& p1, const Point& p2), where Point is a point from the ForwardPointRange, and that returns a Filtration_value.
