All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
Gudhi::Toplex_map Class Reference
Toplex map data structure for representing unfiltered simplicial complexes. More...
#include <include/gudhi/Toplex_map.h>
Public Types
using Vertex = std::size_t
using Simplex = std::set< Vertex >
using Simplex_ptr = std::shared_ptr< Toplex_map::Simplex >
using Simplex_ptr_set = std::unordered_set< Toplex_map::Simplex_ptr, Sptr_hash, Sptr_equal >
Public Member Functions
template<typename Input_vertex_range >
void insert_simplex (const Input_vertex_range &vertex_range)
 Adds the given simplex to the complex. Nothing happens if the simplex is already in the complex (i.e. it is a face of one of the toplices).
void remove_simplex (const Input_vertex_range &vertex_range)
 Removes the given simplex and its cofaces from the complex. Its faces are kept inside.
bool membership (const Input_vertex_range &vertex_range) const
bool maximality (const Input_vertex_range &vertex_range) const
Toplex_map::Simplex_ptr_set maximal_cofaces (const Input_vertex_range &vertex_range, const std::size_t max_number=0) const
Toplex_map::Simplex_ptr_set maximal_simplices (const std::size_t max_number=0) const
Vertex contraction (const Vertex x, const Vertex y)
void remove_vertex (const Vertex x)
std::size_t num_maximal_simplices () const
 Number of maximal simplices.
std::size_t num_vertices () const
 Number of vertices.
void insert_independent_simplex (const Input_vertex_range &vertex_range)
Detailed Description
A Toplex_map is an unordered map from vertices to maximal simplices (aka. toplices).
Examples
simple_toplex_map.cpp.
Member Typedef Documentation
◆ Simplex
Simplex is the type of simplices.
Examples
◆ Simplex_ptr
The type of the pointers to maximal simplices.
◆ Simplex_ptr_set
using Gudhi::Toplex_map::Simplex_ptr_set = std::unordered_set<Toplex_map::Simplex_ptr, Sptr_hash, Sptr_equal>
The type of the sets of Toplex_map::Simplex_ptr.
◆ Vertex
using Gudhi::Toplex_map::Vertex = std::size_t
Vertex is the type of vertices.
Member Function Documentation
◆ contraction()
Toplex_map::Vertex Gudhi::Toplex_map::contraction ( const Vertex  x,
const Vertex  y
Contracts one edge in the complex. The edge has to verify the link condition if you want to preserve topology. Returns the remaining vertex.
Examples
◆ insert_independent_simplex()
void Gudhi::Toplex_map::insert_independent_simplex ( const Input_vertex_range &  vertex_range)
Adds the given simplex to the complex. The simplex must not be in the complex already, and it must not contain one of the current toplices.
◆ maximal_cofaces()
Toplex_map::Simplex_ptr_set Gudhi::Toplex_map::maximal_cofaces ( const Input_vertex_range &  vertex_range,
const std::size_t  max_number = 0
) const
Gives a set of pointers to the maximal cofaces of a simplex. Gives all the toplices if given the empty simplex. Gives not more than max_number maximal cofaces if max_number is strictly positive.
Examples
◆ maximal_simplices()
Toplex_map::Simplex_ptr_set Gudhi::Toplex_map::maximal_simplices ( const std::size_t  max_number = 0) const
inline
Gives a set of pointers to the maximal simplices. Gives not more than max_number maximal cofaces if max_number is strictly positive.
Examples
◆ maximality()
bool Gudhi::Toplex_map::maximality ( const Input_vertex_range &  vertex_range) const
Does a simplex is a toplex ?
◆ membership()
bool Gudhi::Toplex_map::membership ( const Input_vertex_range &  vertex_range) const
Does a simplex belong to the complex ?
Examples
◆ remove_vertex()
void Gudhi::Toplex_map::remove_vertex ( const Vertex  x)
Remove the vertex and all its cofaces from the complex.
Examples
The documentation for this class was generated from the following file:
